I have a vented DESA Fireplace with wall switch and a Damper switch. The pilot is lit but logs do not ignite and I am wondering if the Damper switch/wqll switch is not working. Thanks, Sondra
  • Heating & Co... Master
  • 3,182 Answers
Sounds like its the thermopile is not working .
Posted on Dec 11, 2016
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
Gas fireplace won't light
Your fireplace does have a pilot. It is either millivolt, where you manually light the pilot and use a remote or wall switch to light the logs
or is IPI where it still has a pilot light but the reote or wall switch lights the pilot first then the logs. The second version has a non-standing pilot. In either case, it sounds like a pilot assembly issue. When you "throw the switch", do you hear clicking inside the fireplace? If so and it does not light, you may have a pilot assembly issue. If there is no sound at all, then you may have a bigger issue with the control module. The only sure way to know which is the culprit is to have a certified technician come oput and examine your fireplace.
Feb 02, 2014 | White Mountain Hearth Empire Tahoe 36...
I have a vermont castings radiance 2600 fireplace, the pilot light is lit but the on switch isn't turning the fireplace on
desa is out gone but maybe pro com have a controller with the same controls as the desa check #on the control and see cross ref in Google search they can be 80.00 and up but can b found
Dec 10, 2013 | Rinnai Desa Vent-Free Infrared Gas Heater:...
How do I turn on my superior ventless fireplace
I'm not sure about that brand, but I finally figured out how to turn the one in the house I just moved into. The only visible control if you have not accessed the fireplace controls before is the switch on the wall. The wall switch is strictly an on off switch, but it only works if the pilot light is already lit, and the pilot light will not go out by turning off the wall switch. To access the controls, first pull out the vent covers, they are simply held in place with pressure buttons on each end. Behind the lower vent are the controls for the pilot light and fire intensity, mine also contained a metal plate with the instructions printed on it. Open the glass door by opening the four latches, two on top and two on bottom, and then swinging it out on its hinge. You will find the gas spout for the pilot light hidden between the logs. Turn on the main gas line by turning the straight edge of the red handle parallel with the gas line. Turn the gas control to pilot, by pushing in and turning, and then push in all the way to start gas flowing. I like to have a match already lit next to the valve when I start the gas. After the pilot light has been on for about 60 seconds let go of the button and it will return to its normal position. Then turn the control to on and turn on the wall switch, the main burners should start lighting. Close the glass and put the vent covers back in place and your ready to enjoy the fireplace :)
Nov 27, 2010 | Heating & Cooling
Gas fire place does not turn on with the remote but turns on only with the switch at the lower left corner. It seems to be a direct vent type gas fireplace. I wonder if the damper is not opening and the...
you have no damper, it was removed to put gas unit in. chcek batteries in remore and in RECEIVER, receiver is usually forgot about it is insdie the bottom door more than likely, the fan only comes on when unit is up to temp, it has a heat sensor on bottom of unit, check wires on a gas valve for remore receiver as well, usually go on top and bottom screws
Jan 29, 2010 | Desa International Wall/Window Air...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Jan 07, 2010 | Desa International Unvented Gas Space...
Need Instructions to use Fireplace Gas Logs
There should be a set of metal cards attached inside the fireplace.
First you should read everything there.
I know you have to first light the pilot light.
And then there should be a wall switch.
The problem I have currently is that it won't stay lit when the artificial logs are there.
Nov 03, 2008 | Heating & Cooling
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
