Question about Garden
Sled dies whie riding and blow fuse - Garden
Why would a mdl 1035 john deere tractor keep blowing the starter fuse
There is a distinct possibility that this tractor was originally equipped with a 6 volt system. If it has been upgraded to a 12 volt starter, the ignition will need to have a resistor installed to bring it back to 6 volts.
I could be all wrong on this but it's worth checking.
Mar 06, 2015 | John Deere Garden
Blowing fuses
make sure fuses are setted tight
check for signal bulbs could be bad.
i had a case where filiment in bulb had come into.
it was shorting the bulb out
Aug 05, 2014 | kawasaki VN 1500 Vulcan Classic...
What kind of fuse do I need for the symbol 4 slot battery charger
The UBC 2000 Fuse part number: 217005 (5A 250v Quick Blow), orderable from Little Fuse (Phone: 847-824-1188).
Apr 27, 2014 | Symbol 4 Slot 4 Sled Universal Battery...
Battery goes dead sled dies
Sounds like you need a new voltage regulator.
Apr 01, 2014 | Ski-Doo 2011 Skandic SWT V-800
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
Had the seat recovered on my sled(tank/seat combo) and now cant get fuel from tank.sled fires up when fuel poured into cylinders but then dies when fuel is burnt off.sled is a 97 indy sport 440
take the fuel line from tank to fuel pump off the fuel pump blow air threw it and check for blockages no blockages? now the line from pump to carbs no blockages? rebuild the fuel pump cheap easy 20-30 dollars on ebay for the rebuild kit.
Feb 04, 2011 | Polaris ATV
My bike stopped running as I was riding. the fuses kept blowing. Put in a fuse, started the bike, got on, stood bike upright and the bike died, blowing another fuse. Took off the power commander and the...
check all wiring harnesses where the wires are tight together it sounds like you just have another cut wire that you cant seem to find, and please mention if its the same fuse that keeps blowing or is it a different one every time, and if you find no cut wires then double check all the grounds.
Sep 10, 2010 | Honda VTX 1800 R Motorcycles
Take the bike out for a 40 mile ride, new battery, rides great, all of a sudden it runs terrible, it dies out and blows fuses.
possible, rectifier problem , or stator problem.
put a multimeter on the battery, should read around 12v engine not running, with engine running should show 13v or more.
Apr 04, 2010 | 1979 Yamaha XS 650 SF
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
