Question about Dryers
Electric dryer not heating. was a little and quit completely. Thermostats, thermal ?, and heating element ohm out good. Any ideas?
  • Dryers Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run
electric dryer not heating. was a little and quit  - 26394092-2c3mgo1ucomcxgarbvmsr4e2-1-0.jpg
26394092-2c3mgo1ucomcxgarbvmsr4e2-1-2.jpg electric dryer not heating. was a little and quit - 26394092-2c3mgo1ucomcxgarbvmsr4e2-1-5.jpgt/uploads/images/26394092-2c3mgo1ucomcxgarbvmsr4e2-1-5.jpg" alt="26394092electric dryer not heating. was a little and quit - 26394092-2c3mgo1ucomcxgarbvmsr4e2-1-9.jpg"h_mi" />
Posted on Dec 13, 2016
My Samsung electric dryer runs but doesn't get hot
Clothes dryers usually have one of three issues when they fail to heat.
Taking a good electrical meter ( with ohms readings), check first the heating element.
If it checks good, then try all of the thermostats and the fuse. (There may be as many as 5 thermostats.)
You will need to unplug the wires off of each of these items that you are testing before you test them.
Whilst you are looking, be sure to test the two hot leads from the circuit breaker box, because one of the two hot lugs is for the machine operation, one is for the heating element.
God bless your efforts.
Jan 19, 2016 | Samsung Dryers
Not Drying No Heat
Test for these first:
First of all, see if you have good voltage supply on the socket on which it is powered too.
(1) All venting is clear of lint, even disconnected from back of dryer.
(2) Breaker in house is not tripped. Cycle the breakers off and back on to make sure.
(3) Test continuity on all thermostats and thermal fuses, all have to measure 0 ohms when wires are disonnected and dryer unplugged. We tested the HiLimit Thermostat, Safety Thermostat, and Thermal fuse mounted to the heating element housing, all should have continuity. Also measure the two thermostats located near the exhaust duct in the rear of the dryer, get 0 ohms as well.
(4) Disconnect wires from heating elements. Test continuity from each terminal to the metal cage to make sure none of the elements were grounded. Good if theres no continuity there.
(5) Disconnect wires from heating elements. Test resistance between double coil and inner/outer coil. Each should measure around 19 ohms.
(6) Test the dryer temperature switch by removing wire from terminal 15, then took a reading between terminal 15 and terminal 16, should get 0 ohms there.
(7)Test the dryer timer by first setting the timer to 60 minutes. then remove the wire from terminal A. We then took a reading between terminal A and terminal B, and should get 0 ohms. then keet the leads on those two terminals and rotate the timer and had continuity throughout the 70 minute cycle.
Apr 14, 2008 | GE Profile Harmony DPGT750EC Electric...
Tip
Whirlpool or Kenmore Dryer Does Not Heat
Electric
First , check the circuit breaker to make sure they are on . Be sure to UNPLUG the dryer , while checking with an ohm meter . When checking WITH power , BEST to have another person available in case of emergency . I do know of 1 person killed while working on his dryer .
A dryer operating on 240 volts , sends 120 volts to the timer and 120 volts to the motor . In between these two , are the thermal cut-off , and the element ( this is the basic operation parts ) . The 120 volts from the motor , goes directly to the element if selected for heat . The timer circuit , sends the other 120 volts , thru the operating thermostats , then thermal fuse , then thermal cut-off , then high-limit thermostat , then to the element . Usually , not ALL the time , the thermal fuse ( number 1 ) is the problem . The heating element ( number 2 ) is usually the problem , if the thermal fuse is good .
If the thermostats , element , and thermal fuse check good with an ohm meter , remove 1 wire from the element and check with a meter , which side is NOT getting 120 volts . Trace the wire which will either go to the timer ( occasionally ) or to the motor ( extremely rare ) .
Gas
On a gas dryer , for no heat , or , heats for a short time then runs but no heat afterwords until cooled down , first check that the electronic igniter , glows red . If it does NOT glow red , then check power to the burner ( 2 wires ) . If no power , then the thermal fuse is bad . (On electric dryers , the thermal fuse keeps the dryer from starting . On gas dryers , it keeps the dryer from heating . The thermal fuse , is a 1" long , or oval , white piece , with 2 wires going to it ) . Also if it does not glow red , the igniter itself could be bad . Again , check with an ohm meter . If the igniter glows red and clicks off , but no gas , the sensor could be bad . This sensor , is mounted to the side of the burner box , and when the igniter gets hot enough to ignite the gas , the sensor opens , sending power to the coils , which open dispensing the gas to heat the dryer . To check the sensor , with the drum removed , start the dryer , and after the igniter gets red , pull one of the wires OFF the sensor , and the gas should ignite . Do this very carefully , as electricity WILL be in the wire pulled off . If the dryer heats for a short time then stops heating , the problem will be the burner coils . These coils will get warm from the electricity going thru them , and will " open " ( short ) internally , until they cool down . Then heat again for a short time , then open , until cooled .
Most of the time , either the thermal fuse ( 1 ) or the coils are bad ( 2 ) or the igniter is bad ( 3 ) .
........A thermal fuse is a white 1" long torpedo looking piece , or , a white oval shaped piece , with 2 wires going to it .
NOTE1 : The thermal fuse keeps an electric dryer from starting and keeps a gas dryer from heating .
NOTE2 : If your dryer heats but the clothes do not dry , then a venting problem is obvious , as a dryer either heats or doesn't heat . Pull the dryer out and disconnect the vent from the dryer . Dry a load of clothes and if/when they dry in the normal amount of time , this tells you either the vent hose is kinked , maybe pushed back too far , or , the outside vent is blocked , or , the vent in the wall is restricted to the outside .
Electric Dryers
NOTE3 : If your lint screen is on top of the dryer , the element , thermal fuse , and thermostats are behind the rear dryer panel ....If the lint screen is behind the dryer door , then the element , thermal fuse ( located behind the lint screen housing ( 2 screws ) , and thermostats , are located behind the lower front panel .
on Apr 17, 2010 | Dryers
Why is my dryer running, but not heating up or drying the clothes?
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Jun 23, 2014 | Kenmore Dryers
Hi, Our dryer runs but doesn't heat. We checked the power source, heating element with ohm meter but it was fine. What else should we check? Thanks.
Hi.
If the dryer runs there is no problem with power. If the appliance runs but does not heat the problem is one of the thermal devices. The dryer comprises one thermal fuse, several thermostats and the element. Thermal fuse and thermostats must be checked along with the element.
Start from the thermal fuse. The fuse can be tested reading impedance with a multimeter. If the fuse is open it will read Ohms infinity. In that case replace the fuse. Here the part: ASSY-BRACKET (THERMOSTAT) (Thermal Fuse with Bracket).
The fuse is part n.15 in Diagram one below. Click on the picture to enlarge:
If the fuse is OK, or if replacing the fuse did not help test the thermostats. You have the following parts:
THERMOSTAT - Part 11 in diagram
High Limit Thermostat -Part 13 in diagram
THERMISTOR - Part 27 in diagram
If the appliance is running the door switch should not be the problem. If you need test also the DOOR-SWITCH.
The thermostats can be tested reading impedance. If there is no heat, then one of the thermostats is open and will return Ohms infinity. Other way to test a thermostat is by jumping its contacts and running a controlled cycle to prevent overheating.
Regards.
Ginko
Aug 09, 2011 | Amana NED7200TW Electric Dryer
Dryer drum works but does not heat. Everything else works. I have checked the fuse and I have made sure it is not on air dry.
THERMAL FUSES MAY BE THE CAUSE OF THIS In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element. Follow the diagram below to see how to check the continuity of the switch, and look closely at the switch to see a fairly close idea of what you are looking for, ok
OR it could be a thermostat.
Cycle and safety thermostats-read them with an ohm meter. Should show continuity .
or lastly, it might be
the Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
IF you do not have an OHM-METER, then you can check these issues by following the directions below:
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
Do not forget to rate this answer!!
Jan 24, 2011 | Frigidaire Electric Dryer
Samsung DV218AEB/XAA won't heat.heat sensor on the control board?
Thermostats should be close to 0 ohms thermal cut outs also 0 ohms if not then the TCO is bad elements usually
10 to
40ohms
Apr 25, 2017 | Samsung DV218AEW Electric Dryer
The dryer is not heating
Hello there here is a list of things to check
Testing with an ohm meter checking on a dryer....
These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only. To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
Jan 09, 2010 | Dryers
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Dryers Experts
