Question about Canon imageRUNNER C2620 Color Copier
How to replace canon ir c2620 drum CHIP??? - Canon imageRUNNER C2620 Color Copier
4 Suggested Answers
  • 117 Answers
SOURCE: canon iR 2016 copier problem E019
Product : imageRUNNER 2200/2800/3300(i)/2220N(i)/3320N(i) Title : E019
Error :
E019-0000 is displayed on the control panel.
Workaround :
This error code is the indication of the waste toner container being full or a problem with the detection mechanism. Actions to be taken are:1. Turn the machine off and check the waste toner container. If the container is full, empty the container. Clean the inside and outside of the container's neck with alcohol. Be sure that the neck is clear and not soiled with toner before placing it back into the machine. Turn the machine on and check to see if the code went away.
2. If the container isempty and the code is still displayed, check the neck of the container. Turn the machine off and check the container,if the neck is dirty, clean the inside and outside with alcohol before placing it back into the machine. Turn the machine on and check to see if the code went away.
3. If the machine still displays the code after the bottle is emptied and the neck clean; check the sensor, the sensor connections to and from the DC controller PCB for continuity, and the proper positioning of the sensor. Replace the sensor if it is damaged or excessively soiled with toner.
Posted on May 07, 2009
  • 287 Answers
SOURCE: i just need to replace
Hi bos,
You have asked a straightforward and simple question. However in order to truly help you I have to start at square ONE in order to make sure I have helped you. Usually the color drums are replaced at the same time. I trust that you have a unique situation. The part number is 0256B001AA. I spent a few minutes looking and it appears (as I expected) that you can't purchase it directly from Canon, so that's on YOU as there are plenty of 3rd party vendors. Please make sure you get the real thing, not a knockoff. You don't need tools to replace it. The drum has a chip in it that tells the copier it has a new drum so there is no service mode or special instructions. Merely lower the front door, locate the large blue handle you would use to gain access to the waste toner bottle and lower it in a counterclockwise fashion. Now locate the smaller blue handle above and turn it counterclockwise as well. THIS handle will expose all 4 drums and toner cartridges. The magenta drum is the second from the left, of course just below the magenta toner. Slide it STRAIGHT out with as lttle tilt as possible. The new drum will have all kinds of packaging .Pull all that **** off except the gray cradle that protects the drum. The cradle actually has locating points that will help you insert the new drum and align it properly. Actually if you took your time and looked closely you would "just know" how the new one goes in without the protective cradle. Just use common sense as you slide the drum in making sure you slide it in STRAIGHT. Pull the tape that you may not have already pulled as a final stroke. Slap the blue levers back into their locked position. Close the front door and the copier will say "hello" to the new drum and warm up. It will do an "auto gradation" to calibrate itself. Congrats. Want my tool bag?
Posted on Jun 04, 2011
  • 34 Answers
SOURCE: how do I set the
Call for service & maintenance
Gaurav Pahuja
9811139117, 9990258388
Delhi & NCR
Posted on Aug 05, 2011
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
E000020 1360 canon error code after changing drum unit.
This has been fixed by replacing the memory chip on the drum. This may meaning replacing the drum. First though, try cleaning the laser and make sure all your drivers are upto date:
This may be a call to canon support unless you are very confident with these procedures.
Part number for the drum is Canon C-EXV34
May 23, 2013 | Office Equipment & Supplies
Canon iR Advanced 2030i error E000020-1160
I faced with this error when the all print drums have been replaced by new. Then I put old drums and had replaced one by one then I found that magenta drum had a factory defect. I solved this problem by replacing of the old chip to the new drum.
Feb 23, 2012 | Office Equipment & Supplies
My ir 2620 wont finish warming up
It maybe out of toner, sometimes the lite don't come on...nothing works perfectly all the time
Aug 20, 2011 | Canon imageRUNNER C2620 Color Copier
My canon ir c2620 says check the tcp ip
TCP IP setting are setting installed by the ISps, please contact your isp
Aug 12, 2011 | Computers & Internet
How do I set the ip address on the canon ir c2620
Gaurav Pahuja
Delhi & NCR
Aug 05, 2011 | Canon imageRUNNER C2620 Color Copier
Canon imageRUNNER C2620 Color Copier Logo
29 people viewed this question
old marine
old marine
