Question about Fahrenheat PLF1504 Baseboard Heater
Wiring a 240 to a heater.White wire goes to green ground screw. The black and red to the 2 wires on the heater. Where does the copper wire go?
  • Fahrenheat Master
  • 3,238 Answers
The copper wire is the ground .
Posted on Dec 11, 2016
I have a new heater with diferant terminals from the old one so not sure how to atach the wires
There is no need to rewire the internal of the heater!
Just bring in the electrical supply to the heater, it can be either 120 or 240 volts.
If the heater you have is like the picture associated with your post, then all then have to do is change the supplied plug from 240 to 120. It comes pre set for 240. That plug is inside the cabinet.
If any other brand, then you need to change the wires at the transformer of the heater. All heaters need to be supplied with primary voltage: 120 or 240. Then the control system is supplied with secondary voltage out of the transformer. The secondary voltage is no more than 28 volts. and these wires are normally colored as blue or yellow.
Secondary power is already wired within the heater. NO need to change where they are. You will only need to deal with the Primary wiring.
There are many varieties of transformers that transform high primary voltage to a low secondary voltage of 28 volts. and these transformers have many wires: primary & secondary.
I will try to make this easy to understand.
If you have a Gas Heater Transformer with these colors:
  • Red
  • Black
  • White
  • Green
Or...
  • Red
  • White with Red Stripe
  • Black
  • White with Black Stripe
  • Green
These are Dual Voltage Transformers, you can bring in either 120 Volts or 240 Volts
If you bring in only 120 Volts...
1st example:
The Red wire will not be used! Hot wire to the Black, and the Neutral/Common, to the white wire. Green to ground.
2nd example:
Connect the Red wire with the White with Red Stripe together and connect these to the incoming Neutral/Common wire, normally White.
Connect the Black Wire with the White with Black Stripe to your incoming Hot Wire, which is normally Black.
Green to ground
If you bring in 240 Volts...
1st example.
1 Hot wire to the Red, the Other Hot wire to the Black, and White wire is not used. Green to ground
2nd Example:
Wire nut the two Striped wires together. then one incoming Hot wire to the Black, the other incoming Hot wire to Red.
Green to ground
Or This is only a Low voltage - 120 Volts Only
  • Black
  • White
  • Green
Or either any of these combinations...
  • 2 Blacks w/Green
  • 2 Reds w/Green
  • 1 Black, 1 Red w/green
This type will only be a high voltage, 240 volts only
Picture below is what a transformer looks like and it is where your incoming supply wires go. The smaller leads with the spade connections will go to a specific location & is the 'Secondary" .
Good Luck
Mar 14, 2015 | Pool & Spa
Cooper Industries Cooper Wiring 274W Switch and Outlet I need help installing this switch/outlet combo...I have 3 wires...a black, a red, & a copper. I hooked the copper to the green terminal, the...
Switch-plug combo:
bare ground goes to green screw
dark screw goes to hot from breaker
silver screw to neutral
brass screw goes to load (light)
Add a comment any time
You are replacing single pole light switch?
Single pole switch has 3 wires: black and red and bare copper
New device has 4 different colored screws: green, dark, brass, silver
Bare copper goes to green screw.
Black wire goes to dark screw
Red wire to brass screw
Nothing on silver screw for a moment. Test circuit and make sure light turns on-off.
If lights works, then good so far.
Now let look at silver screw. Neutral wire has to connect to silver screw.
In back of your electrical box are white wires twisted together and covered with wire nut.
These are neutral wires.
You must connect another short piece of insulated wire to these neutral wires and run that wire to silver screw.
The neutral wire will complete circuit to receptacle.
If you do not have neutral wire, then receptacle will not work in that box without additional wiring.
Hook up neutral wire to silver screw.
Now turn on power and click switch again.
If circuit breaker trips, then reverse your red and black wires.
Otherwise this should be correct wiring.
Dec 08, 2010 | Cooper Industries Cooper Wiring 274W...
Haw do i hook up the wires corectly for a hot water heater
I am assuming this is a large 240 volt water heater and you are asking about the connection at the water heater. First thing is to turn the power to the water heater off at the service panel of disconnect if it has one. You will see three wires that connect to the heater. Normally a white, black, and a ground that is usually green or just a copper wire. On the water heater when you remove the plate on top you will have 2 wires. A red & black or a white & black. You will see a ground screw. Connect the green or copper ground wire to that screw. The 2 wires left you connect either one to either wire. Makes no difference as each wire is carrying 120 volts. When you connect these wires secure them tightly with a wire nut, no wire exposed, and then, with electrical tape, tape them up so as the wire nut cannot come off. Push the wires back into the hole an secure the cover on top.
Jan 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Wiring a 240 to a heater. Where do the black, red, and white wires connect to on the heater?
White wire to the green ground screw. the black and red to the two wires on the heater and it does not matter which one to which wire.
Nov 05, 2009 | Fahrenheat Electric Hydronic Baseboard...
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Residential Electrical Wiring Current NEC
On a 120/240Volt single phase system is:
Black = 1st phase
Red = 2nd phase
White = neutral
Green or Bare = ground
3 phase is the same with the third phase being blue.
Jul 28, 2008 | Motorola 3-Wire Surveillance Headset...
Electric Baseboard thermostat wiring
what is the make of the thermostat? are the heaters 240 volts?
Jan 27, 2008 | Heating & Cooling
Connecting 240 volt singer baseboard heater
Need front grill for singer model WJA-12 wall heater Cat # 9756-A
single phase 60 HZ
240 volts 5.2 Amps
1250 Watts
Where can I find it?
Nov 28, 2007 | Heating & Cooling
Fahrenheat PLF1504 Baseboard Heater Logo
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
