Question about Samsung Dishwashers
Samsung dishwasher leaking from vent under door
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Water Leak at vent area in door...
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
Posted on Oct 23, 2006
arikrom
  • 528 Answers
SOURCE: water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Posted on Jan 01, 2010
Testimonial: "Will check water source. Thanks."
arikrom
  • 528 Answers
SOURCE: leaking
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
  • 3247 Answers
SOURCE: My Kenmore dishwasher (665.13734K602) leaks water
Most likely the door vent gasket is leaking. Check item 9 on this diagram.
Hope this helps.
Posted on Jun 22, 2011
LG dishwasher leaking out the bottom of the door. It's that gasket that runs along the inside bottom of the door. How do you keep it in place? It keeps pushing in and then floods my kitchen.
My dishwasher was doing the same thing, but it was because of a clogged vent. The minerals in the water built up to a point that it was totally blocked and since it couldnt vent, the water ran down the inside of the door and leaked out the bottom. I just popped the vent cover off of the inside of the door and cleaned it out and it stopped leaking.
Nov 16, 2010 | LG LDF9810ST Built-in Dishwasher
Lg lds5811 leaking in front at bottom left of door. cleaned gasket and door, still leaking. any ideas, thanks
if its leaking down the vent out the bottom of the door when it runs.you need to replace the vent fan ***.the gasket on the vent door is bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 24, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Jan 16, 2010 | LG Dishwashers
My whirlpool Quiet Partner 1 leaks from the bottom of the door.
Some leaking around-under-from the door on dishwashers can be traced back to a split in the spray arm. If the lower spray arm develops a split in it, the spray arm can turn too fast, and shoot water directly at things that it is not suppose to spray water at....sprays water at the door vents or edges and can create water leaks. See if thats the problem
Nov 13, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Door leaks
This dishwasher has a vent at the bottom left of the door that blows out hot moist air during the drying cycle. Are you sure that you are not getting condensation build up from this vented air that is dripping on your floor?
Dec 29, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Oct 23, 2006 | Maytag 24 in. MDB4000 Built-in Dishwasher
Door leak
Br, couple of things you can look for here. Check the vent, you can just pop this out. Sometimes there is a buildup of gunk which will hold water during wash and leak down between the door. There is a seal there, part number 974782. Another thing is to check the upper spray arm for cracks or splitting. This can send a direct flow of water into the vent. There is also a seal at the bottom of the upper spray arm, part number 3376846. I was fooled by a leak like this once, it turned out to be a clogged vent...Catriver..post back.
Sep 30, 2006 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
256 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
