Question about Fahrenheat PLF1504 Baseboard Heater
If the white wire goes to the green wire, do you connect the copper wire to any wire on the heater?
Which way do the wires connect to a 3 tab lighted rocker switch using black white and green wires
Usually the center tab is COM... connect Black Hot wire
Other two tabs are switched... connect Black going to load to either of the tabs.
Connect White neutral to load neutral
Green wire is ground... connect to green ground screw or bare copper.
Test wires to see which is hot and neutral
http://waterheatertimer.org/Basic-house-wiring.html#test
http://waterheatertimer.org/How-to-wire-switches.html
Gene
Water Heater Timers Save Money
Dec 05, 2014 | Electrical Supplies
HOW TDO I HARD WIRE MY FISHER PAYKEL DOUBLE OVEN TO THE 220 THATS COMING FROM MY BREAKER BOX. IM TRYING TO TEST THE OVEN....IT HAS A GREEN BLACK RED AND WHITE WIRE COMING FROM THE FLEX OUT OF THE BACK OF...
Green and white from the oven go together and connect to the copper from the box, red goes to white and black to black. Be sure that it's 220 breaker your connecting to, for an oven it should be a 40 amp breaker, sometimes thirty
Oct 09, 2013 | Fisher and Paykel Washing Machines
LG Dishwasher Wiring issue
Yes the green goes to your bare copper wire, it is the ground. Black to black and white to white.
Jul 17, 2012 | LG LDF6920ST Stainless Steel 24 in....
Wiring Hunter ceiling fan into old house. My house was built in the 60's an the wiring is confusing. I removed an old chandelier and I am putting a new ceiling fan in it's place. When I removed the...
Your copper, green wire are the ground. I beleave that the white is the power, and the black is your neg. to make sure i would use a wire tester to determen the power. From there white goes to white, black to black, and green to copper. I am not sure on the white/black wire it maybe another power. Look at your instalation manual it should tell you.
Hope this can help.
Mar 20, 2012 | Hunter Dryers
I am trying to wire a new Emerson 230v pool pump to a timer. The pump has 2 red wires and 1 green wire coming from it. The timer has 3 wire terminals. The receptacle has 1 black wire, 1 white wire and 1...
You really need a 2-pole timer -- 2 wires in and 2 out. In that case the Black/White from the receptacle goes to the 2 "in" terminals and the 2 red wires from the pump go to the 2 "out" terminals. The WHITE wire from the receptacle goes nowhere - tape it off. The Bare wire from the receptacle goes to the GREEN (ground) wire on the pump.
A single-pole timer can be used, but in that case, you ALWAYS have 110 v on one side of the pump. Not safe, and not code compliant.
May 27, 2017 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
GE digital timer. Instructions say to: 1) connect Hot/live wire of main to black wire of timer, 2) connect neutral (White) wires together, 3) connect Hot/live wire of load to red from timer. 4) green to...
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Sep 25, 2010 | UPM Programmable Wall Switch Timer
Haw do i hook up the wires corectly for a hot water heater
I am assuming this is a large 240 volt water heater and you are asking about the connection at the water heater. First thing is to turn the power to the water heater off at the service panel of disconnect if it has one. You will see three wires that connect to the heater. Normally a white, black, and a ground that is usually green or just a copper wire. On the water heater when you remove the plate on top you will have 2 wires. A red & black or a white & black. You will see a ground screw. Connect the green or copper ground wire to that screw. The 2 wires left you connect either one to either wire. Makes no difference as each wire is carrying 120 volts. When you connect these wires secure them tightly with a wire nut, no wire exposed, and then, with electrical tape, tape them up so as the wire nut cannot come off. Push the wires back into the hole an secure the cover on top.
Jan 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Electric Baseboard thermostat wiring
what is the make of the thermostat? are the heaters 240 volts?
Jan 27, 2008 | Heating & Cooling
Fahrenheat PLF1504 Baseboard Heater Logo
27 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
