Question about Canon Pixma MG6120 InkJet Printer
Canon Pixma MG6120 stopped printing in color.
Only Black and white. It doesn't matter if you chose color printing in settings. It will print everything in B&W only. Tried to reset it, factory reset. All cartridges are brand new and full.
SOURCE: NOT PRINTING COLOR
I have the same problem.  At first I thought the printhead clogged but dipping it in solvent did not work.  I guess the only thing we could do is to buy a new print head, but at the cost it's going at, we might as well get a new printer.  Other than that try sent a RMA.
Posted on Oct 27, 2007
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
old marine
  • 2122 Answers
SOURCE: switching between color and black and white
Go here. In the search box in the center of the screen, type "print with black ink only" and click Search. Choose the appropriate link, and you will get instructions for printing from either Windows or Mac.
Posted on Jul 03, 2008
nblady
  • 206 Answers
SOURCE: Why I can't print in black and white.
It may want the cartridge in to protect the heads. Put an old empty on in. Make sure to go to Start, Settings, Printers. Select the Pixma and go to Printing Preferences. Once here set the COLOR OPTIONS to Grayscale, print black ink only.
Hope this workds for you.
good luck
Posted on Feb 19, 2010
Testimonial: "Thanks for the fix, it worked. :)"
pineworks
  • 4041 Answers
SOURCE: Printer willl print color but does not print black and white
Hi There You can try/
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
My Canon MG6120, which worked on wifi fine for months, now doesn't. It still works with USB connection, but that's not the point of a wifi printer! How can I fix this?
First check with another device that your wifi is working if it is try resetting up wifi on your printer.
If someone changed your wifi password you will need to enter the new password.
Jan 28, 2013 | Canon PIXMA MG6120 Inkjet Multifunction...
Cannon MG6120 printer will not print text. I have cleaned print heads several times. I think I have a clogged print head. Which of the 2 black ink cartridges prints text? How do I clean a clogged print...
I think you need to do is reinstall you software driver for the print program and start with known parameters. Then you can try to clean the heads. You should get something out of the printer if the heads are plugged it might be a dot or smear on the paper.
Dec 31, 2012 | Canon Pixma MG6120 InkJet Printer
How do I put the Canon Pixma MG6120 in Service Mode
  • Copy + paste this link in your URL bar: club.myce.com/attachments/f123/260341d1374410670-cd-print-enabler-newer-u-s-canon-printers-cd-printtool-v7.zip
  • To start machine in service mode, with the machine off, press and hold the ON button (do not let go). While holding ON, press the Stop button 5 times. Now release the ON button.
  • Run the Print Enabler utility software that you got using the above link.
  • Select a region. Press Set. Cycle printer on and off to exit service mode.
Jun 16, 2012 | Canon Pixma MG6120 InkJet Printer
Need to print only black ink on canon mp510
in the printer set up ( normally in the print section , change the color to black and white , make default and ok
Jan 11, 2012 | Canon PIXMA MP510 All-In-One InkJet...
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Jun 06, 2011 | Canon Office Equipment & Supplies
good luck
Feb 19, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Feb 11, 2010 | Canon PIXMA MP470 All-in-One Printer
Always prints in color even while printing black and white
There are several setting for color printing ... first check the printer settings, then the programe setting, then the dashboard printer settings.
Feb 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Color ink cartridge out. Won't let me print in black only?
Do this, press and hold the "Stop" button on the printer for 10 seconds that should clear the fault set by the empty ink cartridge.
Jul 21, 2017 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Pixma MG6120 InkJet Printer Logo
75 people viewed this question
old marine
old marine
