Question about Dayton Heating & Cooling
Runs but sputters wiyh puffs of smoke Dayton oilfired space heater model #35219
  • 95 Answers
SOURCE: wat the hell is wrong
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
Posted on Jan 23, 2009
farfield
  • 462 Answers
SOURCE: ned a fan moter for dayton model 3vu36a heater
consult with WW GRANGER. They have Dayton as a line and will be able to tell you whats available from model number. They also have a web site with phone number to their stores. try it w dot com.
Posted on Mar 04, 2009
SOURCE: surges then a big puff of smoke and it shuts down
Surges then a big puff of smoke and it shuts down
Posted on Jan 05, 2010
roniecon
  • 6927 Answers
SOURCE: master heater only runs for 5mins
Check the photo eye to make sure it is clean,clean it with soap,and water,and add a additive to the fuel for gelling.
Posted on Jan 15, 2010
  • 2926 Answers
SOURCE: reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Posted on Jan 21, 2010
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
How to ajust dayton 155000 btu torpedo heater when running smell like kerosen
You say: When running it smells like Kerosene--
That is what you are burning in it, right?
Is it smoking--- like there is a poor combustion mixture?
-- like maybe not enough air pressure?
There is a pressure adjustment for both-- Please check the manual for adjusting the pressures for your particular model.
Jan 18, 2011 | Dayton E50 Heater
Ignites about every one half second puff blue smoke when fire puff blue smoke will not run continous
statelinespe,
You have a classic reddy heat problem. Daytons are made by Desa the same as reddy heat so they are the same. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to get the parts to fix it.
Thanks fo using FixYa and for the great rating.
hardrocko
Dec 29, 2010 | Dayton (3VE50) Oil Filled Liquid Fuel...
Reddy heater 55 runs about 5 mins the a puff of
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
Jan 02, 2010 | Reddy Heater-30-55,000 BTU Variable
Blows big puff of smoke on start up.
I have a all pro modelspc k100 will not ignite when pluged in
Jan 20, 2009 | Dayton E51 Oil Filled Utility Heater
HARD START AND BLOWING SMOKE
clean all of your filters and the spark plug and go back to useing K1 kerosene. Diesel fuel has a higher ignition temp. burns dirty and has a tendency to gel.
Jan 20, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Heating & Cooling Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
