Question about Cell Phones
Selfie stick paired with phone via Bluetooth (Samsung S5) but nothing happens when pushing button. Phone takes pictures when we touch the screen...
SOURCE: pairing samsung wep200 bluetooth with motorola V3xx Razor
hold that reciever button until the light is a still...you may have to hold it for about 10seconds and once the still blue buton has come then search for devices on your phone.
Posted on Dec 27, 2007
SOURCE: pair my samsung bluetooth to my blackberry cel phone ,
i found out that if you turn the bluetooth off and then turn it back, while turning it back on hold it until solid blue light and then try 2 connect with your blackberry i jus got mine and threw my instructions out. and i did this and it worked and if it should ask for a passcode i used 0000.
Posted on Oct 14, 2008
  • 10 Answers
SOURCE: Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
Posted on Dec 10, 2008
  • 10 Answers
SOURCE: Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Posted on Jan 28, 2009
SOURCE: headset buttons
press both the volume buttons together for a few seconds... light should flash red & blue
Posted on Mar 19, 2009
I want to share pictures from my samsung galaxy S5 to my samsung Tab S tablet
Check bluetooth may need to re pair bluetooth between both devices
Jun 02, 2016 | Samsung Tablets & eReaders
Vivitar selfie stick how to set it to my phone I have a zte
Fix for Selfie Stick Not Taking Photos on Android Devices ...
https://mattwoodsblog.wordpress.com/.../fix-for-selfie-stick-not-taking-p...
Dec 28, 2014 - I updated my HTC One M7 to Android version 5.0.2 and I've had to ...Also, it's worth noting that if you want to test that the Selfie Stick is communicating with your phone, ... First off, the Selfie Stick connects via bluetooth with no issues and it ... Settings. Then scroll down and select 'Volume button options':.
Selfie Stick with Built-In Button - YouTube
? 1:46
https://www.youtube.com/watch?v=z5kyCEimnaY
Apr 7, 2015 - Uploaded by PulseTV Deal
That's why every Selfie taker loves this Selfie Expandable Monopod. Now it's new and ... Wired Selfie Telescopic Stick - How to use it with Android Phones - Duration: 1:18. iChic Gear 237,902 views ... MY NEW SELFIE STICK!
Wired Selfie Telescopic Stick - How to use it with Android ...
? 1:18
https://www.youtube.com/watch?v=pmVmrpvO3D4
Jun 1, 2015 - Uploaded by iChic Gear
Feb 03, 2016 | ZTE Cell Phones
How to attach to a selfie stick
  1. Identify the type of selfie stick you are using.
  2. Pair the devices to enable Bluetooth function (or inserting it into the jack).
  3. Alternatively, set a timer of Bluetooth function is not available.
  4. Use camera apps such as Camera 360 for better overall performance (optional).
  5. Extend the selfie stick and adjust the angle based on your needs.
My Social Image Selfies and Selfie apps
Mar 11, 2015 | GoPro HERO4 Silver Action Camera
How do I get speaker to work with Samsung S5 with good sound quality
Be sure JBL is charged, press the power button on JBL, press the Bluetooth button on JBL. Turn on your phones bluetooth,make it visible to all devices, make it search for aplliances. When it finds JBL - pair it (you may have to make up a pairin number). The "sun" button controls different sound qualities. And turn the volume up! You should download the JBL MUSIC FLOW APP from the APP STORE to make the most of it.
Feb 19, 2015 | JBL Pulse Portable Bluetooth Speaker
How to pair the samsung galaxy s4 to the jabra cruiser
  • Touch Apps
  • 2.Scroll to and touch Settings
  • 3.Ensure Bluetooth is turned on
  • 4.Touch Bluetooth
  • 5.Slide the Power switch to turn the JABRA CRUISER on
  • 6.Press and hold the Multifunction button until you have a rapid flashing blue LED
  • 7.Touch the JABRA CRUISER in the list of devices
  • 8.The JABRA CRUISER is now paired
  • 9.The JABRA CRUISER and Galaxy S4 are now ready to be used
  • 10.Press the FM button in order to start streaming audio via the FM transmitter. The FM LED will turn red
Oct 01, 2014 | Jabra Cruiser InCar Speakerphone Black
U430 will not work with ford sync
I have the same problem. Trouble pairing but finally I got the SYNC to find my U430 and paired but the SYNC never connects with the phone.
Sep 17, 2010 | Samsung Cell Phones
220 plantronics bluetooth pin help
I just tracked mine doen it is "0000"
Jun 27, 2008 | Cell Phones
Samsung LE37R8 Picture in Picture
Sorry, meant to say you need to connect an external source (Video, Pc) then picture in picture will be available. You cant view tv channels via picture in picture
Oct 23, 2007 | Televison & Video
Pair Bluetooth Stereo
put the music player on and press down on the jogwheel, select 'Play Via' and change it to Bluetooth stereo headset. It'll prompt you to open the swivel and take you to the bluetooth devices screen where you select the correct device, it'll then prompt you to close the swivel and will start playing through your headphones :-) Is that what you mean?... It's a bit of a pain really :-(
Aug 04, 2007 | Samsung SGH-X830 Cellular Phone
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
