Question about Fahrenheat PLF1504 Baseboard Heater
The heater has 2 black wires with each having a red wire connected to it. The house has a white and a black wire. Does it matter which one gets connected to which?
    Top Expert:
  • Fahrenheat Master
  • 48,555 Answers
The heater is for 220 and the house is 110 , call an electrician to run 220 for you
Posted on Dec 11, 2016
Need to install a hot water heater; need electrical diagram.
Generally you will have three wires
1. bare or green wire this is your ground and is secured to the outside of the water heater usually with a green colored screw provide with the unit.
2. connect the black wire from the house to the red wire on the unit.
3 connect the white wire from the house to the white wire from the unit.
In general as long as you hook up the two power wires from the house with the two power wires from the unit it does not matter as one wire will supply 110v and the other wire will also provide 110v..
Verify check and reverify that the power is off anytime you are working with wires.
Sep 01, 2011 | Heating & Cooling
Hi I am trying to wire a laars lite pool heater LD 125N for 120 V. from the transformer has 4 wires coming out the one side white with black traser and a white with a red traser which one wires to the...
For 120V join like colors...White/Red and red together to line 1 and white/black and black to L2. It doesn't matter which line is the hot and which is neutral as long as you pair off the transformer wires as instructed.
John
Aug 18, 2011 | Jandy Laars Lite 2 Pool Heater 175,000 BTU...
I have a 12/2 (black/white/ground) power source to the leviton 1755 switch. And, I have two (2) 12/2's going to a Broan 100hl (vent, light, heater). Please help wiring switch and Broan; on...
The switch that you have works like 3 seperate switches. most of these switches will have gold screws
on one side and silver screws on the other side, lets say that the left is gold and the right is silver, and
the switch may also have a green screw for ground. your 12/2 with ground is your main hot, you may
want to mark it with a piece of tape, so you know it's the incoming hot. the ground off your hot will tie,
to the green screw on switch and continue and tie to your vent light which should also have a ground
the white coming off the hot is your neutral, it will go straight to your white or whites on your heater.
the black hot wire at your switch will go to each gold terminal on one side of the switch,there are two
ways you can do this, go to one side and just run a jumper, or put one wire on each gold screw and
tie in to your hot-black wire with a wire nut. now for the switch legs, you will need to run from your, switch
to your heater either another pair of 12/2s or a 12/3, each side of the switch that has one silver screw,
it's easier with a 12/3 normally a 12/3 will have a red,black,white,and ground.
top switch red to red on heater,black to black on light and the white blue on the vent,so from your switch
to the heater you would have to run a12/2 you would not use the black only the white and ground.
remember the white-neutral coming from the switch will be tied to all the whites at the vent,light,heater
except for the 10/3. the 10/3 is used stricktly for the switch legs. good luck!
Jul 09, 2011 | Leviton 1755 Triple Rocker Switch Decora
I am instling a whirlpool accubake double oven, my house wiring is 3 wire (black,black,coper) the instructions say coonect red to red, black to black and white and neutral to coper. If neither of my house...
Doesn't matter....hook one black to the black and the other black to the red....copper to the green,white, and/or ground...whatever you have...
then you are good to go...
heatman101
Apr 30, 2011 | Whirlpool Ovens
Just tried to install the fan and light, it doesn't work when power is connected. I have 2 white house wires, none black. I have rechecked the connections, no power to the fan
the white wires are returns they dont supply power .. you may have to take the fan back down in order to find the black or red wire that supplys AC power .. a red wire would come from a wall switch .. the black wire would usually be 120 VAC .. be careful .. you must first turn off power before working with that live wire .. the white wires are always paired with a black wire and a bare wire (safety ground) .. perhaps the black wire just got covered up when the fan was installed .. the black (or red) house wire should be connected to the black and blue wires of the fan .. the white wires should all be connected together .. the bare wire should be attached to the green wire or bolted to the fan housing ..
Jun 22, 2010 | Hunter (25417) Ceiling Fan
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Wiring a 240 to a heater. Where do the black, red, and white wires connect to on the heater?
White wire to the green ground screw. the black and red to the two wires on the heater and it does not matter which one to which wire.
Nov 05, 2009 | Fahrenheat Electric Hydronic Baseboard...
I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
you get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Mar 22, 2009 | Fahrenheat Electric Hydronic Baseboard...
Wiring a fan with two seperate switches
I am assuming that you have two 3way switches controlling this fan/light .. if there are more switches , then stop here and get back to me
connect the house wires red to red and black to black , then a house4 white to the ]fan white , the other house white connects to both the black and blue from the fan .. to be exactly correc the white fan wire should be connected to the white house wire that is the white power wire from the electrical panel.,
Jan 18, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat PLF1504 Baseboard Heater Logo
43 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
