Question about Akai Televison & Video
AKAY Pdp4273m when I try to turn it off it turn back on after 3 sec. the key of tv do not respond it was lay flat for repair any suggestion if not can I leave it as is by using the switch on the side?
  • 192 Answers
SOURCE: can you lay a lcd sharp 82u flat
Yes.
We work on them face down and even store them in our shop like that. We've never had a problem.
It is never recommended to transport them laying down.
Did this answer your question?
Posted on Dec 18, 2007
centralhigh
  • 260 Answers
SOURCE: Gateway flat panel TV will not turn on, the front on and off switch doesnt work at all and when you use the switch in the back the front on and off switch lights up but tv still will not turn on. Is
This sounds like you have lost your power supply. The more expensive the equipment, the more sophisticated the power supply that converts the power from your outlet into your television. There could have been a lightning strike that has disabled the tv. Or it could be a faulty outlet.
Before called for a technician, I recommend plugging the television into a different outlet. use a good quality extension cord if necessary. You may find that your outlet is not polarized correctly. If this does not work, please try our premium service or use our online listing of technician for a professional near you.
thanks and good luck :)
Posted on Jun 20, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KDL40S2010 Bravia LCD TV... turns off / on on it's own
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
Posted on Jun 13, 2009
librabhoy
  • 31 Answers
SOURCE: layed tv flat while switched on lost picture
u need to replace the mylar capacitor near the flyback sometime the value of this mylar capacitor is 2kv.if still not working u need to replace the crt connected to the yoke.And u also need to readjust the fucos in the crt board of in the flyback.Try it
Posted on Jun 20, 2009
westytech
  • 120 Answers
SOURCE: westinghouse LCD TV turns off after 3 sec, sound
Hello Robert,
It sounds like your inverter board might have gone out. What you need to do is purchase the inverter board (your unit might have two master, and slave) and swap the board out. Some good places to find the board is www.shopjimmy.com, or www.invertercentral.com, to find the correct part # you can open the unit and the board is immediately visible, it is a long green board on the left side of the TV.
Posted on Jan 25, 2010
My AKAI PDP4273M 42" Plasma has thin horizontal lines that flicker across the screen and then the picture jumps and flashes red and green distortions on the screen acts like interfearance of some sort if i...
This sounds like a loose solder joint, or overheated component. I know this may sound like a **** question, but have you tried tapping the TV to see if it goes away? If it does, you will need a tech to re solder the loose component. I have also seen this type of line and color bleed problem, believe it or not from poor cabling or loose connections.
Mar 09, 2010 | Akai PDP4273M Television
I have no power to my Hitachi TV. It is plugged
try turning off main switch and unplug set then replug in wait 30 sec turn on main power and repeat then try if it works great if not power supply bad. i also suggest a ups universal power supply newer tvs sensitive to surges and brownouts also never turn tv off n on in short period of time will cause surge that trips protection circuit
Dec 29, 2009 | Hitachi 42HDS69 42 in. Plasma Television
I cant get the closed caption to work
Hi my name is Roety,
I can help you with your issue ,
Press the Tv remote menu button scroll down to setup, then captions.
turn them on there.
This is for s sony TV
If using a cable/dish box check the box remote too
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Oct 19, 2009 | Akai PDP4273M Television
Getting Akai model PDP4273M plasma to accept a new remote
Hold The Clear Tv buttom until all 4 light flash red , then press code search at the bottom right , then the up arrow until ur tv goes off and finally record , after that u only need to press the red tv buttom to open it or close , If it doesnt open it back its because u press the up arrow after the tv was shut off so do the same thing be using the down arrow .
Mar 19, 2009 | Akai PDP4273M Television
The tv quit responding to the remote
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
Mar 19, 2009 | Sharp LC52D65U 52 in. LCD TV
I have some issues with my akai hdmi model pdp4273m
You can download the manual from the akai website:
http://www.akaiusa.com/
I just did a search on "pdp4273m" at the akai website.
http://www.akaiusa.com/products_detail_features.aspx?cat=VISUAL%20ENTERTAINMENT&subcat=Plasma%20TV/Monitor&productno=PDP4273M
The manual is easy to download from there product page about the plasma.
The manual is a PDF, so I hope you have something like adobe acrobat to read the file.
http://www.adobe.com/
Feb 10, 2008 | Televison & Video
AKAI PDP4273M Plasma tinted red
TRY THIS BY USING YOUR REMOTE 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THIS WILL TAKE YOUR TV BACK TO FACTORY PRESETS. I WENT 3 MONTHS WITH NO TV BEFORE I FOUND THIS OUT.
Sep 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Blue Vertical Line- Akai PDP4298ED
I have an Akai PDP4273M that developed the same problem. Checking around some of the av forums, I found a couple of threads that indicated it could be dust or bad contact around the ribbon cable connections on the video control board. I removed the back, loosened the ribbon cables on the board and used my small compressor with an air gun to blow out the dust all around the board and the ribbon connectors. Reconnected everything, turned on tv and stripe did not come back. Problem fixed! Nice and cheap solution.
May 28, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
27 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
