Question about Maytag Washing Machines
MAYTAG F2E1 ERROR ON MODEL MEW9530AS01 - HOW DO I FIX IT
2 Suggested Answers
jackiaria
  • 350 Answers
SOURCE: Error Code F2E1
Did you try unplugging it for a couple of minutes and replugging it?
This might reset the computer control.
Posted on Jan 17, 2009
Error code F2E1 on new Kitchen Aid KGSK901 Gas Range
This looks like the system buttons was all pushed at the same time,need to switch main power off and then on again so the board can reset it self
Dec 20, 2013 | Kitchen Ranges
F2 E1 error shows on display. KitchenAid model KESC308LSSO Electric range. Oven stops working after 90 minutes at 350 Def. F. Starts working again after cool down.
On your model the "F2E1" error is for a faulty control board and it will need to be replaced. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 24, 2012 | Kitchen Ranges
Err F2E1 stuck/shorted key
The control panel is either faulty and needs to be replaced. One can be purchased at repairclinic website or partselect.
Or you can dismantle it, and clean everything with rubbing alcohol and a cotton swab
Apr 27, 2010 | Ovens
F2E1 message on range
I have a repairman coming to check it out.
Jan 25, 2010 | Kitchen Ranges
Display showing F2E1
HI. This code will appear if the key pad becomes unstable. This may be a loose cable, or faulty control board. Use the procedure to isolate the issue.
1. Check The keypad connector, which will be located on the backside of the control board, for a firm connection. Pull off the connector, and re-attach. If the code comes back, after the re-attaching method, move on to the next step.
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models may incorporate the keypad and control board as one unit. In this case, replace the control board (also referred to as the ERC or clock).
Dec 25, 2009 | KitchenAid Kitchen Ranges
F2e1 error message
It is the only ribon cable coming off of the control panel to the control board. This error could also indicate that the control panel is bad.
Apr 12, 2009 | KitchenAid KEBC107 Electric Single Oven
Error Code F2E1
Jan 17, 2009 | KitchenAid KGRS807SSS Gas Kitchen Range
Oven on our electric kitchenaid stops working and f2e1 error message comes on. It does this frequently
F2E1 is a fault code that indicates the keypad my be unplugged or has failed.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jun 22, 2008 | Kitchen Ranges
F2E1, F3E0 Error Codes
Believe it or not, but on my Whirlpool Estate (Model: TES400PXHQ0)....after reading about this error, I looked at the sensor, and I noticed it was touching the metal on the inside of my oven. I moved the sensor away just by pulling on it to the center of the hole that was cut out for it, plugged the oven in....and didnt get a code at all....not even the PF code. So, I tried the oven out....expecting for it to beep at any second, and it didnt!!!!
So, in conclusion.....I guess by the sensor touching the metal on the inside, it couldnt get an accurate reading, so the computer threw out the infamous F3E0 error.
I've had this oven for 4 months and always had to stare at the F3E0 display (it was donated to me). Thanks for all who had done the research on this to point me in the right direction, as Whirlpool wanted someone to come out at $60 just to come out, then $80/hr!
Thanks again
~Luke
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
Washing Machines Logo
69 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
