The 0,00,.,2,3 keys do not work also the dept 1,2 7 do not work what should I try
  • 149 Answers
Try rebooting the machine (off, from the machine and the wall) then turn it back on. What keys do work? Is the display ok? It may well just be the key pad membrane that has cracked - not hard to replace once you've got the operations panel out.
Posted on Jul 20, 2009
Casio pcr 308 cash register
Per the instructions on the Casio4Business Support website, you can do the following:
PCR 308, 350, 355, 408, 450
TO PROGRAM STATUS OF DEPARTMENT KEYS:
1. TURN KEY TO Z MODE
2. PRESS SUBTOTAL
3. PRESS 02 FOR TAX TABLE 1, 04 FOR TAX TABLE 2, 06 FOR BOTH TAX TABLES, AND 00 FOR NO TAX
4. PRESS DEPARTMENT KEY
5. REPEAT STEPS 3 & 4 FOR MULTIPLE DEPTS.
6. PRESS SUBTOTAL
You can access additional information at the main support site: http://www.casio4business.com/sa/support/taxtable_programming.html
Regards!
Dec 17, 2013 | Casio Parts Cash Register PC Desktop
WE HAVE A SHARP ER-A610 CASH REGISTER WE WOULD LIKE TO CHANGE THE ITEM LABEL FOR EACH DEPARTMENT KEY BUT DON'T KNOW THE JOB # AND PROCEEDURE FOR DOING IT I DON'T HAVE ALL THE PAGES OF THE MANU
Sharp uses a 3-digit ASCII code for each character. The ER-A610 manual has a table of the codes, but if you've lost that part of the book, you can find ascii tables online, like this one:
http://www.ascii.cl/
Note that many of these show 2-digit codes; add a leading zero to those, so A is 065, B is 066, etc.
the 00 key on your ER-A610 has a special purpose here - it is used to enter each character's code, so to spell FOOD you'd enter:
070 00
079 00
079 00
068 00
where each of those double-zeroes is the double-zero key, not just two zeroes.
You need to know the number of each department you need to change. If you're not sure what order they're numbered in (It's completely customizable, so don't count on them being in order, unless you're sure.), print out your current department programming:
(In PGM1 or PGM2 mode)
1100 @/FOR CA/AT
will print out all the depts. CA/AT is the Cash key at the bottom-right corner of the keyboard. It stands for CAsh / Amount Tendered, which isn't exactly obvious, so some folks relabel it.
Note that on the tape you printed, the name is printed below the dept. number.
Now we're ready to start. In PGM2 mode, enter:
2114 . @/FOR (Is the decimal point after the 2114 visible here?)
[dept. number] @/FOR [character codes] SBTL
(etc. until done)
CA/AT
For [dept. number], enter the number on the keypad, not by touching the actual dept. key.
[character codes] is the sequence of 3-digit codes and 00 key presses, like the FOOD example above.
If the departments you're changing are sequential, life is a little easier. When you finish Department 6 (for example) by touching the SBTL key, it will automatically count up to 7. You can do a series of depts. by entering the first of them as above, then after using the SBTL key, go straight into the character codes for the next in line. Continue this way for as many are in series. You can jump ahead or back at any time by with [dept. no.] @/FOR and keep going from there.
SBTL in all the lines above, means the key that normally shows your subtotal including tax. It might be labeled #/SBTL. The MDSE SBTL key won't do the trick.
If you use PLU's in you register, their names are programed exactly the same, except that instead of starting with 2114, you use 2214. Simple, no?
Jan 11, 2013 | Computers & Internet
How much refrigerant does FRA296ST2 require?
Unfortunately, Frigidaire does not post their service manuals online. But, if you contact their Consumer Support Dept, they can help you. 1 (800) 374-4432 Monday - Sunday 8:00 am - 8:00 pm (EST).
Jul 22, 2011 | Frigidaire FRA296ST2 Air Conditioner
I'm working with a PCR T2100 and trying to re-program the unit price for each department. I have the manual so I've read the key set to pgm, press 1, subtotal, * (dept #/dept shift for upper departments),...
Turn the key to PGM mode. Type the new price without decimal point e.g 500 Press the dept key (item) you want to change. Press SUBTOTAL Turn key back to REG and test it.
If anyone needs a Casio PCR-T2100 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Nov 19, 2010 | Casio Parts Cash Register PC Desktop
Hi Mark. You instructed me to set the department names but i haven't got a clue if where is department key like the ones for Flat PLU button key. Please help! Thanks. Clarence
Sorry, I didn't know you hadn't worked with departments yet.
Key to program 2 SUBTOTAL Now type the dept number on the numeric keys (i.e just press 1 for dept 1) 05 SUBTOTAL Now type the new name for that dept 00 (double zero button) CASH SUBTOTAL
Sep 27, 2010 | Casio Parts Cash Register PC Desktop
Casio TE4500F Programming Departments & linking to PLU's
Hi.
To link a PLU to a dept:
Turn key to program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number and press the 'PLU' button (eg 1 PLU for the first plu)
Now type the dept number to link to. Use two digits eg 01
Now press 00 (double zero)
CASH
SUBTOTAL
To set a dept name:
Turn key to program.
2 SUBTOTAL
Type dept no in 2 digits eg 01
Type 05
SUBTOTAL
Type new dept name using character sheet
00 (double zero)
CASH
SUBTOTAL
That should do it.
Let me know if you have problems.
Mark
Dec 18, 2008 | Casio Parts Cash Register PC Desktop
18 people viewed this question
k24674
jasbo
jasbo
