Question about Cell Phones
Not holding its charge and I had reset three time
Master reset button sequence
backup all data first.
fully charge phone.
Hard Reset
  1. Shut down the device
    • Press and hold the End key, tap Power Off, and then tap OK
  2. Remove SIM card
    • Remove the battery cover, the battery, and then remove the SIM card. Replace the battery and battery cover.
  3. Three-key combination
    • Press and hold the Volume Down key, Send Key, and then End Key in succession. Make sure that all three are being pressed simultaneously and that the End Key is pressed last
  4. When the graphic is displayed, press the Menu key to begin factory reset
Nov 06, 2014 | Samsung SGH Cell Phones
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
Reset bct8 back to factory settings
Turn the scanner off, then hold down the 2 , 9 and HWY (State) button....all three at the same time and then turn the scanner back on. This does a full reset to factory settings.
with radio off, press and hold 2, 9, & hold button, then turn on and hold all three for at least two seconds to reset.
With the scanner off, firmly hold down 2+9+State at the same time while turning the scanner on. (You may have do it several times) When you see (Clear)
its reset.
Dec 24, 2013 | Uniden BCT8 Base Scanner
Reset code
You may want to have your phone to be flashed reset.. I will help you on how to do this process, but first things you need to have a full charged for your phone`s battery for this will not work well if not fully charged. Here`s how to do it, *Remove the battery, and then wait for about 20 min or so before putting it back *Press and hold these three keys together -Green dial key, Star key[*], Three key [ * switch ON the phone. * Do not let go the three keys until you see the Welcome screen displayed and just let it complete the boot process
Jul 25, 2013 | Samsung Star GT-S5233 Cell Phone
Blueant T1 bluetooth headset - pair list is full messege and unable to reset unit to clear error
You need to quickly click and release all three buttons together at the same time (do not hold down the buttons). Source: http://www.blueant.com.au/knowledgebase/reset/t1.php Works like a charm...
Jan 31, 2011 | Cell Phones
My kindle will not start up even though it has battery charge. Is there a soft reboot?
Yes:
  1. Get a watch with a hand for the seconds.
  2. Slide and hold the power switch for 7 seconds. After about 5 seconds the power light flashes three times. After 7 seconds, the screen will go blank and the device is switched off now. Release the switch.
  3. Slide and hold the power switch for 15 seconds (no more, no less). Do not hold the switch too long, the time window for the reset is not very big.
  4. After releasing the switch just wait. The Kindle will reboot after a few seconds.
Jan 24, 2011 | Amazon Kindle 3G
New Bigfoot toy for XMAS buzzes three times and stops working. Reset with power switch and does the same thing repeatedly. Made sure battery was fully charged.
There is a pen hole beside power switch........with the power off press and hold this button (with a safety pen or something)....while holding the button turn it on and hold the button for at least 3 seconds. Then push every button on the remote, then charge the battery until the indicator is "green". That will fully reset your Bigfoot.
Jan 02, 2011 | Mattel Fisher-Price Imaginext Big Foot
It is totally dead and will not charge.
Had same issue... this worked for me:
1. Snap into charger base & plug into wall. Screen still blank. 2. Press Lap/reset, Mode, & Power buttons all three at the same time & hold for 3 seconds - unit will reset. Hopefully then you'll get the 'charging in progress' message.
(also make sure copper points/connectors on unit and charger base are clean).
Aug 28, 2010 | Garmin Forerunner 305 GPS Receiver
Tire reset on in ford freestar
Reset without message center:
To reset turn the ignition to the ON position, depress and Trip/odometer
button (located in the instrument cluster) until “TIRE RESET” or
“CHECK TIRE AND RESET” is displayed in the odometer display window.
Once “TIRE RESET” or “CHECK TIRE AND RESET” is displayed,
press and hold the button for three seconds. The low tire warning indicator light will flash three times
as the low tire warning system begins to initialize.
Reset with message center:
To reset turn the ignition to the ON position, press the set up button on
the message center until “SYSTEM CHECK” is displayed. Press the
RESET button until “HOLD RESET TO RELEARN” is displayed, continue to hold the button for three
seconds. The low tire warning indicator light will flash three times as the low tire warning system begins to initialize.
Oct 13, 2008 | 2005 Ford Freestar
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
