Question about Dyna-Glo Heating & Cooling
My dyna-Glo 95-C wick ?? the wick assembly came off finaly, but without the wick... the wick is RUSTED to the fuel tank...
Any Ideas on How to Get the entire wick out?? Does the tower come out??? how far down does the wick go??? any help would be greatly apprecieated???
SOURCE: can not replace wick in dyna glo serial number RMC-95-C2
As "guest" reported, the wick replacement for RMC95 series is the same as his posting for the DH2301.
After calling my local Tractor Supply and searching the net, I had it but it ain't easy. My sleeve doesn't come out necessitating cranking the knob up (wick will be level with the top) find the three holes (more like two are slot and one is a hole) then where the diagonal grooves are, there is ANOTHER HOLE which you must snap the pin in both of those all at once!
The good news is, you get one in, the rest are cake. I was pretty frustrated so I hope this helps others.
Posted on Jan 14, 2009
  • 3 Answers
SOURCE: I have a Dyna-Glo RMC
Use this link, It will show you how, Just look at the pictures.
http://www.yourheater.com/WickChangingInstructions.htm
Posted on Oct 18, 2009
wilsodfarm
  • 986 Answers
SOURCE: Have a Dyna-Glo. Took it apart to change the wick
take the wick back out lower your nob and install wick, I hope this help you, I have made this mistake too
Posted on Oct 23, 2009
  • 3 Answers
SOURCE: Help
Dyna Glo 95 c4 Manual
http://www.owneriq.com/mdownloads/8979e0af-dfee-45f1-a8ba-c05c2f5ed4a8.pdf
Posted on Dec 07, 2009
  • 30 Answers
SOURCE: I have two Dyna Glo RMC 95-C6 round kero heaters
http://www.ghpgroupinc.com/heaters/manuals.aspx
The Dyno gow manuals posted under their parent group, GHP Group ..
Posted on Nov 06, 2010
Need to see pictorial instruction on how to replace wick in a Dyna Glo RMC-95-C2 kerosene heater
I think the Dyna-glow RMC95 series of heaters are equivalent to DH2300 series heaters.
In any event, the wick you purchased should have ahd the installation instructions included with the wick.
If it didn't or you tossed it, Here's a link to the DH-2300 series heater's Owners Manual, which may help you.
http://www.yourheater.com/DH2301-3%20owners%20manual.pdf
Good luck. Be sure to wear rubber gloves when you try to install the wick. Particularly, if you still have kerosene in the tank.
Feb 11, 2011 | Dyna-Glo RMC-8001SS Heater
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Kerosene heater
Jan 31, 2009 | Dyna-Glo RMC-8001SS Heater
Wick won't raise.
check with your local hardware ace store like I did my wiks for both my models come ready to install
Oct 27, 2008 | Corona 23-DK Compact Heater
Help
Aug 31, 2008 | Dyna-Glo RMC-8001SS Heater
Heating & Cooling Logo
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
