Question about Dryers
I have a CG75-85 Continential Girbau dryer and it keeps giving the message "rotation fault". What does it mean?
Hi this the erro that appears on my Girbau dryer: Buner Control fault. can someone help me?
The gas heating element is failing to ignite. The igniter or gas valve could be at fault.
Oct 30, 2017 | Dryers
We keep getting a db message no matter what buttons we push it our Samson dryer
http://removeandreplace.com/2015/12/23/samsung-dryer-error-fault-codes-what-to-check-how-to-clear/
Sep 26, 2016 | Dryers
Maytag MEDC400 VWO Dryer drum keeps rotating when door is open and time still remaining on timer.
I think you have identified your problem. The button bay be stuck or the switch itself is dismounted.
Jan 26, 2015 | Maytag Dryers
Girbau ms 623 lc-E
my Englesh is bad, when i start the laudry machine GIRBAU MS623, the display show ALARM U00, i need help
Jan 15, 2014 | Cars & Trucks
What does the fault message "F dL" mean?
"Fdl" is a lock latch error code. This is an indication of either a defective door latch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resource websites in the link provided, if parts are required. If you have any questions, please post with your MODEL NUMBER and let me know. I hope this helps you.
May 03, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How can I find a supplier of a replacement door gasket for a Girbau 20lb commercial washer?
I would suggest staying on the web and doing a product search and you should be presented with suitable suppliers. Just type into your web browser 'girbau washer' and see what turns up. That's what I would do.
Sorry I can't be more helpful.
John C
Feb 16, 2011 | Washing Machines
My dryer keeps flashing f 11 wht does this mean
Fault code F11 means that the pump is not working,
check the pump connections and the pump itself.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Dec 21, 2009 | Hotpoint Dryers
Magtag Dryer MDE2400 Dryer won't turn off
On our Maytag dryer, the looping marquee lights mean that the dryer is in "wrinkle" mode. This means that the wrinkle mode has been selected. In this mode, the dryer continues to rotate on and off after the heat cycle has ended. It does this to keep the clothes from wrinkling -- and it displays the looping lights.
Jul 24, 2009 | Maytag MDE2400A Electric Dryer
My Neptune Dryer keeps giving message to "close door"
Call the repair number listed for your dryer and a technician will be able to come out and look at your dryer and identify the problem.
Jul 14, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
