Question about Cameras
How to work a colorpix. LW DV310FB Camera. I put the sd card in it. It shows a picture from the camera but it just keeps a (Readcard) across the screen. It wont let me use any of the buttons like menu
2 Suggested Answers
t0ny_pars0ns
  • 5412 Answers
SOURCE: I have a colorpix LW DV310FB camera. On the screen it says reading card. I can see a picture behind it. But it wont let me do anything else.
Have you tried using a different card ?
Posted on Dec 11, 2016
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
THere are pictures on this card that load everytime to Picasa but don't show up when installed in my Canon S100. I want to delete them from the card so they don't continue to download everytim
There are several possible causes for this.
1a) The pictures are in a folder unknown to the camera. This could be due to the folder name, or its position in the folder structure.
1b) The pictures have filenames that do not correspond to the camera's naming scheme.
2a) The pictures were taken by a different camera. Many cameras will not display pictures that were taken by a different camera.
2b) The pictures have been edited on a computer. Many cameras will not display altered pictures.
Unless you have very strong reasons for keeping some pictures on the card, you should have the camera format the card after you download the pictures to a computer. Formatting wipes out all information on the card, preparing it afresh for further use. Failure to format the card periodically can lead to future problems.
If you need to keep some pictures on the card, format the card in the camera, then use a card reader to put the pictures back onto the card.
Aug 11, 2012 | Transcend Sd Hc Sdhc Class 10 16gb 16g 16...
Camera locks up with SD card
Put the SD memory card into an USB card reader and plug the card reader into the USB port of a working computer to check if the memory card is working.
If the computer cannot detect the memory card as an external storage device and cannot open the files or folders and it cannot be formatted in FAT32 then the SD memory card is faulty and needs to be replaced..
Mar 24, 2012 | Sanyo Xacti VPC-S770 Digital Camera
Took sd card out to put photos on computer. put it back in the camera and it only says no image when i tried to look at them. they are still on sd card cos they show on computer xx jv100 camera xx
I suggest that you make sure that you have successfully copied the photos to your computer from the SD card and then use the camera's format feature to reformat the SD card for the camera.
There's really no reason that you need to keep all of your photos on the SD card all of the time. As long as you backup your pictures and other data on your computer regularly, they will remain safe.
I found that the directions to format the SD card appear on page 75 of the user manual for this camera (click here for manual).
Thanks for using FixYa!
May 03, 2011 | FUJIFILM FinePix JV100 Digital Camera
Just put a new memory card in the camera but the screen keeps showing internal memory is full
How to switch the camera over to saving pictures directly onto the SD card.
    1. Menu
    2. Cam settings
    3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    PC transfers files to and from SD memory card but camera show "No image" on SD card. Why can the camera no longer recognise picture files?
    If you are putting pictures on the card using the computer and then expecting to see them on your camera, it doesn't work that way. You also run the risk of corrupting the card and even the camera.
    Dec 02, 2009 | Canon PowerShot A710 IS Digital Camera
    How do i get the RAW images
    if your camera is fairly new, it should have a usb port on it as most new digital cameras do. If so then when you plug it into your pc, the pc will open up a shared directory from your camera and you should be able to drag and drop the pictures over.
    If not then if you have an external sd card then you should be able to remove the sd card and put it in a card reader on the pc and when you do, the windows os will show the sd card as another drive and you can pull the pictures across that way.
    HTH.
    Feb 19, 2009 | Fuji Finepix S9600 Digital Camera
    Samsung s850 cant copy from camera to sd card?
    The Samsung S850 has an internal feature to do this. I have one. Put in your memory card and turn on the camera, push the button on the bottom right hand side of the lcd screen to view the picture, next when you see a picture (it can be any picture) push the OK button, this brings up a set of commands across the top of the screen, as you go across the commands one of them will be "copy to card". Select yes and the camera will copy the pictures to the card.
    Dec 09, 2008 | Samsung S850 Digital Camera
    Cameras Logo
    41 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
