Question about Jet Plumbing
I have a utilitech jet pump and when I was running down a short and removed the 115/230 converter switch the wire came loose now I have no idea how to wire it back up
    Novelist:
    Champion:
  • 227 Answers
Look on the inside of the cover you removed. There is often a diagram on how to convert to and from 110v to 220v.
Posted on Mar 20, 2017
SOURCE: jet tech washer 737 dp
Ouch.
Before you start changing all sort of parts, correct your problem with the wires. You may have to change most of them, depending on how bad the chemical burned tru them.
A good cleaning is required because that soap is going to continue chewing on those wires.
You're right about a short causing other component failure. But first repair those wires
Robert Marsolais
Posted on Aug 01, 2008
asber
  • 291 Answers
SOURCE: FROZEN Jet......I have just had my samsung jet unlocked,
remove your sim and sd card, try to restore it to factory settings by typing this code *2767*3855#. if it still freezes, return to the one who unlocked your phone and have him reflash it to the latest firmware.
Posted on Feb 21, 2010
SOURCE: Only 2 black wires on current switch - Utilitech 0192773 has 4
Webpage explains wiring and has large print:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Posted on Dec 09, 2010
boysor2933
  • 293 Answers
SOURCE: I have a utilitech jet pump in which i have to turn off the power switch and wait ten minute, then turn it back on so it could run the water.
An electrical fault is tripping off the power relay. Check the current draw of the pump motor.
Posted on Nov 06, 2012
boysor2933
  • 293 Answers
SOURCE: I have a Utilitech 3/4 HP jet shallow well pump #0003134. On start up, it hums a long! time before turning, sometimes tripping the 15 AMP breaker. Anything I can do?
Try replacing first the capacitor. If it will not solve your problem, check the integrity of the motor winding insulation by doing a line to body resistance measurement. If it is okay, replace the motor bearings.
Where can I get a manual for model 0078551
I was able to locate a PDF file for the DAYTON Convertible Jet Pumps and Systems/Operating Instructions & Parts Manual...I located it here: http://www.grainger.com/ec/pdf/Dayton-Convertible-Jet-Pumps-and-Systems-OIPM.pdf
Hope this is what you were looking for?!
Jan 07, 2016 | Utilitech 1-HP Convertible Jet Pump...
I have a UtiliTech 1/2 HP Jet pump #0003124. I need a manual. Can I get a larger volume impeler for this mode?l
Put a vacuum gauge on the suction, see if it goes real low after pumping a couple of gallons. If so, your point may be stopped up. A 1/2 hp pump should pump 40/50 psi, fill a 5 gal bucket in a minute or so.
Jul 29, 2015 | Utilitech 1/2 HP Convertible Jet Pump...
Where do the wire leads connect to the switch?
Look on the id plate on the motor, and inside the cover on the back and inside the switch cover.
Jul 03, 2015 | Utilitech 1/2 HP Convertible Jet Pump...
Why does my pump loose pressure
Sounds like your not using enough water, and or your pipes to sprinkler is to to small, causing pump to build up to cut off head. I cant lay my hands on a performance chart for your pump, but 60 psi cut off and 20 on sounds about right. Try running another tap when your sprinkler is running, and see if this keeps your pump running
Mar 25, 2015 | Utilitech 1-HP Cast Iron Convertible Jet...
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
How do I tell the pump to shut off when up to pressure?
The black cover on the side is the pressure switch. Open it you will see two screws with springs on them. Don't touch the short one. The tall one will adjust the pressure. Clockwise for more, counterclockwise for less. Cover should have diagram.
May 10, 2014 | Utilitech 1/2 HP Convertible Jet Pump...
Utilitech jet pumps
This sound could be many things. It could be cavitation from a suction obstruction. IT could be a bearing or a bushing. IT could be something lodged in the impellors. YOu will have to take it out and disassemble it to see.
Dec 09, 2013 | Plumbing
Need manual for utilitech 43467
You might be able to obtain this directly from the supplier
Jan 15, 2013 | Utilitech 1/2 HP Convertible Jet Pump...
Plumbing Logo
109 people viewed this question
Top Jet Plumbing Experts
Lawrence Oravetz
bobalix
Are you a Jet Plumbing Expert? Answer questions, earn points and help others
