Question about Samsung PN64D7000 64" Plasma 3D HDTV PN64D7000FFXZA
I have a Samsung Plasma TV PN64D7000FF that continually power cycles on and off. I need help determining which board is bad.
The TV power cycles correctly - logo screen appears and input indicator HDMI2 appears in upper left before unit shuts off and starts up again. I have verified key voltages Va, Vsc, Vs, and Ve at the available test points on the power supply and X/Y boards. Logic board LED indicator heartbeat blinks at the correct rate i.e. no drive failures detected while unit is on. I have also bypassed the main board short PS-ON to GND and jumped pins 3&4 on logic board and watched test pattern screens; I didn't see any anomalies in the video - no bad lines, no missing pixels, no missing brightness, etc. I also tested 5V and 15V pins between power supply and main board - all appear correct. I do not see any blown capacitors or burnt IC's from a visual inspection. Y board does hum while power is applied. Any help determining which board is bad or further troubleshooting steps would be appreciated.
4 Suggested Answers
  • 28 Answers
SOURCE: Samsung PN50C590G4F plasma TV turning on and then off with clicking sound after 6 seconds
Have you tried replacing the power cord or the voltage feed may be off replacing the whole cord should correct that
Posted on Jan 02, 2015
Testimonial: "If all the voltages are correct except the one on the VE, how can changing the power cord make a difference? The VA and VS on the power board are perfect."
  • 75017 Answers
SOURCE: PN50C490B3DXZA 50" plasma TV, has vertical lines on the left side of the screen after warm up. And lines appear on any input and screen test. So do I need the main logic board?
If you wish to get some details; check the site linked here. Pull up older posts. Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size..
Posted on Nov 22, 2016
  • 75017 Answers
SOURCE: I have a samsung PN43E450A1FXZA Plasma tv. I have no standby light, no power on. I do not have PS-ON voltage or VS voltage on board. Any idea which component on the power board may possibly be bad?
If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Dec 28, 2016
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
Oct 9, 2013 - Uploaded by
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
? 4:10
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
Samsung pn51 continuously cycles on and off (clicking).
Easy fix for new Samsung TV switching on and off power ...
? 4:41
Sep 15, 2012 - Uploaded by alwaysafix
Easy fix for new Samsung TV switching on and off power cycling.... My tv turns on and off by itself the ...
Samsung 46" LCD TV (LNT4665F) turns off and on over again -
Dec 09, 2015 | Samsung Televison & Video
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
Dec 22, 2012 | Samsung PN58A550S Plasma TV
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
I have a Panasonic TH-42PX80U TV. When I power up the set, after a few seconds you can hear the relay click and then the LED blinks 2 times in cycle. When I hold the power button for 10 seconds the LED...
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Oct 04, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
My TV can't turn on and getting clicking please!!!
I have a Samsung Plasma PN50A450 and one night the TV turned off and the result of trying to turn it back on was simply the set trying to turn on, making a click sound and nothing happened. I pulled the back off, and attempted the capacitor fix that is well documented on the Samsung LCD TVs. I did have a swelled capacitor that I replaced and also replaced the other capacitors that were the same Microfarad rating, temp and voltage which were replaced in a popular UTube video. That did not solve my problem, so I went onto Ebay and bought an entirely new power board for 69.00 plus 14.99 shipping. Replacing the board took about 3 minutes. TV is now working fine and will go back up on the wall in a day or 2. Note, the power board in my TV was a BN44-00205A. That board is no longer in stock anywhere ( I believe because it has been determined to be a bad board) I replaced it with BN44-00207A. Which I suspect is the board that is being used for replacements of the bad BN44-00205A. It fixed My TV. Hope this helps you. BTW, Both power boards are listed for replacing a board in the PN50A450, but the BN44-00207A Specifically states its for a PN50A450P1D. I took a gamble that the BN4400207A would work. It did.
Mar 01, 2010 | Samsung PN50A450 50 in. Plasma HDTV
Samsung PN64D7000 64" Plasma 3D HDTV PN64D7000FFXZA Logo
170 people viewed this question
Top Samsung Photography Experts
Tom Chichester
Are you a Samsung Photography Expert? Answer questions, earn points and help others
