Question about Watches
Women's day magazine? Who do I call or get in contact with?
How to set day of the week
press mode 3 times , then press reset 5 times and press start to change the day
Aug 10, 2012 | Anne Klein AK SilverTone Diamond Accented...
I have a 3 dial AK watch. I can't seem to adjust the date and day.
You can pull out the stem on the side there is a halfway setting one click out, turn one direction for day and other direction for date, two clicks out sets time.
Aug 27, 2011 | Anne Klein AK Anne Klein Diamond watch...
Need new watch band for Armani AX4010. whom do I contact.
You may contact Armani by phone at: 800.277.4013
You may contact Armani by email at: emporioarmani@fossil.com
Feb 23, 2011 | Giorgio Armani A|X Armani Exchange...
My strap broke apart from the rubber part. Do I have to replace the whole thing? Do you have it available?
Hi  rmanllo
It seems that you need to buy a new strap for your watch.
You can go to the following link:
http://www.cartier.com/show-me/accessories#/contact-us/contact-us/send-a-message
Give details about your name , email id, country of residence.
Write in the message box that you need to buy a new strap for your Cartier 21 Autoscaph W10147U2 Watch for Women.
They will get in touch with you shortly.
Hope this helps
Regards
TDCL
Jan 29, 2011 | Cartier 21 Autoscaph W10147U2 Watch for...
Watch stopped working 11 months after purchase. New battery fitted - watch stopped couple days later. Another new battery fitted (both by jewellers). Again, the watch stopped within 2 days. Can't find a...
It is best to go to a watchmaker for this issue. If the battery was improperly installed, it can damage the movement or contacts, which will mean the movement must be replaced. We see this issue often. Another common problem is that the oils from the installer's fingers may be causing a bad connection if the battery and the contacts are not properly cleaned. We would use the Pulse test to see if the watch has current, if so, the movement is bad mechanically, it must be replaced. If it has no current, we would check and clean all connections and replace the battery. If there is still no current (using Pulse diagnostic) then the movement is bad and it must be replaced.
Jan 19, 2011 | Tommy Hilfiger Sport Stainless Steel with...
Steel mesh on strap is ravelling and cannot wear it
Thank you for contacting FIxYa.<br /> You will have to contact DKNY on this or take back to store you got. I dont know how long you have had it. Most watches warranties do NOT cover bands. <br /> Contact at:<br /> http://www.dkny.com/contact/<br />Best regards.
Aug 25, 2010 | Dkny Mesh Bracelets #NY3992 Watch for...
I have an automatic watch that shows the day of the week, I can't set it so that it changes from day to day correctly. I've changed it to correct day right after midnight and by the end of the day, it's...
hi,
first you kepp the day and date set yesterday's , for example today is 31st and monday so you set 30th and sunday , now keep rolling time by key till day and date has complitaly changed,remind that do not roll anty clock, it may be damages to your watch,now when you get change day and date its a midnight of 31st and monday, now set the time and get started ,
Aug 30, 2009 | Invicta Corduba Leather 3809 Watch for...
How to set day of week mini dial?
Pull out the crown and advance hands forwards. When the hour and minute hand will pass 12 o'clock (midnight), you will notice the day hand will jump to the next (following) day. Advance hands as long as needed to reach the desired day.
Rate me, please.
Jul 23, 2009 | Invicta Square Angel Diamond Chronograph...
Watches Logo
24 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
