Question about Hamilton Beach Coffee Makers & Espresso Machines
I have a new Hamilton beach can 0pener 76606za. I started it and a piece of plastic popped out of cutter. I tore it off and it will not start. What to do? I would like to repair it myself.
SOURCE: user guide for hamilton beach espresso model # 40729
If you go to www.hamiltonbeach.com you will find a user guide there for this model.
Posted on Jul 04, 2008
SOURCE: Hamilton Beach Stay or go Coffee Machine
I finally got in touch with the Hamilton Beach (1-800-851-8900 between 8:30-4:00 EST) and found out that Model 45235G replacement carafe is available for order from them for $25.98 (S/H included) plus state sales tax.
Posted on Jan 29, 2009
SOURCE: My hamilton beach brewstation is leaking.
There is a spring between the lever and the o-ring. It may have popped out when you cleaned the pot. That has happened to me before. The spring is necessary to hold the seal down until the lever is pushed.
Posted on Mar 16, 2009
  • 68 Answers
SOURCE: Hamilton Beach 40540 Brew Station 40-Cup Coffee Urn, Silver
Try to see your manual.
Posted on May 18, 2009
  • 4 Answers
SOURCE: Hamilton Beach Espresso Machine not working
I have the same issue -- machine is NOT clogged. I've torn the think apart, and looking at the way it is designed I am thinking that the pressure relief valve (at least that is what it appears to be) is malfunctioning.
The steamer will work briefly, but runs out of steam almost immediately. If your machine is having a similar problem, I suggest that you open it up and look at how it works (there are two screws on the top under the door for the scoop. You've got to drill out the cover caps to get to the screws underneath -- at least that is how I got them out...they covers are really long plastic plugs and trying to get them out with a thin screwdriver did not work -- but using a drill bit pulled them right out).
I don't know where to find a replacement valve -- sorry.
Posted on Mar 13, 2010
Hamilton Beach Blender Gasket
Possibly the gasket while it lasts on the cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-WAVE-ACTION-CUTTER-BLADES-REPLACEMENT-PART-/161615007502?pt=LH_DefaultDomain_0&hash=item25a1014f0e For an unused replacement, try typing in your model number at HB's parts site, located by clicking here . Many www sites like abtecparts.com and goodmans.net could help you. Besides matching description, I would match the pictures of what you are going for against what you've got as much as possible. Good luck!
Apr 09, 2014 | Hamilton Beach Blenders
Can't seem to find proper gasket and blade assembly to fit Ham Beach Blender #50100 Type B-12. Any suggestions?
Possibly the new wave action blade cutter while it lasts on cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-WAVE-ACTION-CUTTER-BLADES-REPLACEMENT-PART-/161615007502?pt=LH_DefaultDomain_0&hash=item25a1014f0e. For unused replacements, try typing in your model number at HB's parts site, located by clicking here . Abtecparts.com may also have traditional blades at http://www.abtecparts.com/commerce/search/products/?product_id=02AXHBha010&merchant_id=1933. Besides matching description, I would match the pictures of what you are going for against what you've got--unless you are trying something new--as much as possible. Good luck!
Jun 19, 2013 | Hamilton Beach 50100 BlendMaster Work Top...
Hamilton beach food processor won't turn on
DYI fix job on mine. DIsassembles base and switch assembly. Added a rectangular piece of plastic just above litlle balck trigger switch. Taped switch casing's side (not my plastic piece) so that my plastic piece would not fallout. Re-assembled. Voil?. Problem was that travel length of whole trigger mechanism was a bit too short to trigger the switch. With the added plastic piece, travel was extended a little to make the whole thing work, but not so much so that it would always unsafely stay ON when plugged. Tried various other gluing options on other pieces before that, but nothing would hold.
Jan 21, 2012 | Hamilton Beach Food Processors
Hamilton beach blender cleaning - food underneath cutter..does it screw off?
Usually the ring on the bottom of the jar unscrews. There is a rubber gasket beween the jar and the bottom hub holding the cutters.
Make sure you reassemble it correctly.
Apr 17, 2010 | Hamilton Beach Blenders
HAMILTON BEACH BREWSTATION LEAKS FROM SPOUTS
I had the same problem with this same machine. On this model there is a spring-loaded piece of plastic that operates the pouring of the coffee. After a few months of regular use, there is a design flaw in this piece that wears out prematurely, causing the pour to slow down. This is why the stream runs towards the machine and not in your cup.
Eventually the plastic piece will break at the weak point and will stop pouring altogether. To make matters worse, HB uses a weird screw that you cannot turn unless you have the right bit, and, once you do finally get to the piece, there is no where to order a replacement.
Summary: Hamilton Beach built an intentional flaw that is difficult/impossible to repair so you will need to purchase another machine in under a year.
Jan 24, 2010 | Hamilton Beach BrewStation 47224 Coffee...
It began with the stream of coffee slowing down, so I cleaned the urn with Brew Rite cleaner. I followed the directions, but when the process finished, it did not have a flow at all. The pot is...
I also had this problem, and reached the point where it was easier to pour the coffee out of the brew tank rather than going through the torturous hell of waiting for it to drip out of the spigot each morning. What I discovered was that the domed screen inside of the brew tank was plugged with residue. The screen can be removed and cleaned. You will see four plastic tabs holding the screen in place over the spigot. Gently and carefully pry the plastic edge of the screen nearest the wall of the tank with a small jewelers screwdriver or a sharp knife(steak knife worked). The screen will pop out and must be scraped (tip of a knife) and cleaned on the inside as well as the outside. The sceen goes back in the same way it came out by sliding the plastic edge back under the plastic tabs and push down the edge nearest the tank wall. It will snap into place. This was an easy 100% fix on my Hamilton Beach Brew Station.
Jul 29, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Need to replace the plastic lid. Anyone know
Call Hamilton Beach customer service. They usually will send the part free, you just pay shipping ($5.00 or less). 1-800-851-8900. I love hamilton beach. They love their customers and stand behind their products. 1-800-851-8900. Also check out hamilton beach.com and look up your product. most regular parts can be ordered on line thru hamilton beach. Good luck to ya.......katherine
Apr 26, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Mar 13, 2009 | Hamilton Beach BrewStation 47214 Coffee...
The small plastic washer is warped on mine and causes it to leak
I had the same problem only the small rubber gasket (looks like a hose washer) on mine fell out. I contacted the Hamilton Beach product support department and was tole the WHOLE TANE NEEDED TO BE REPLACED. BUT do not dispair. They are sending me a whole new tank for the cost of shipping only!!!! How's that for customer service. Shipping is only $5.00. Call Hamilton Beach ast 1-800-851-8900 and wait for instructions. In your case, if it's just "warped" they can tell you hopw to reinstall it. In my case, the part that holds it, a little ***** white plastic part with a star on top) broke off so for $5 bucks, I get a whole new tank! I love Hamilton Beach!!!!
klvillane
Mar 06, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Coffee Makers & Espresso Machines Logo
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
