There is a green cast on the left side of the screen. It has been stored on its end for 6 months.
3 Suggested Answers
  • 1694 Answers
SOURCE: green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
Posted on May 09, 2008
  • 167 Answers
SOURCE: We have a yellow spot
need to replace light engine to resolve this issue
Posted on Dec 19, 2010
Magenta cast on left side and green cast on right
We are OEM foundry adopting of advanced sol-wide (colloidal silica)investment casting process,produce castings of various kinds of carbon steel,alloy tool steel,wear-resistant alloy steel,heat-resistant alloy steel and all kinds of stainless steel &it's develped products,with an annual output of 600tons of investment castings production capacity,80% of them were exported to the United States,Germany,Janpan,Spain and other countries.
hot sale pneumatic fittings Pneumatic valve stainless steel casting...
May 26, 2016 | Canon LV-7265 Projector
Why is the left side of my AOC I2367Fh 23'' green, and how do i fix?
were I you,I would check into my warranty . that is not a normal thing and if only 6-7 months old will only get worse they should repair or replace it .
Aug 18, 2014 | AOC I2367Fh 23" LCD IPS Panel Monitor
Green screen
1.) Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
2.) Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
3.) Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
4.) Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
5.) Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made.
Now turn the T.V. off. When you turn it back on it should reflect your personal preference.
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM4Pfcki
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3rDVkt
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3hkBLp
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3VlPaY
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3H5rYm
Sep 19, 2013 | Samsung Televison & Video
I have a problem in my BPL TV(FHR-21) it showing a green color
How to Fix a TV When the Screen Is Green
A TV is calibrated by the factory to provide a "standard" picture that attempts to appeal to the vast number of buyers who take the set home. To adjust a TV picture that is too green, you must first enter the hidden "service menu" that technicians use. Adjusting the colors to remove the green cast will save you the cost that would otherwise be incurred from a TV technician coming to your home. No special tools are needed, nor any expertise in how the TV works.
Press the power button on the remote of a TV whose picture is too green in order to turn it on.
Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made. Turn the TV off.
Sep 14, 2011 | Audio Players & Recorders
MFC-7840W Printer Brother, we have replaced the toner many times and the printer always shows the message on its screen: low toner, and after that shows: toner life end, what we can do, because this is the...
Open the front cover. Remove the drum and toner. Remove the toner from the drum by pressing and holding the green/blue tab on the right side then lift the toner out. Shake the toner side to side for 6 times, and on the drum unit slide the blue/green tab on the far left side from left to right for 6 times also. reinstall the toner back to the drum unit. reinstall drum and toner back to the machine. Close the front cover. The display should show the date and time.
Hope this will help.
Mar 25, 2011 | Brother MFC 7840W Printer
Why did my pc notebook suddenly end up with a green screen?
Try hooking up the external monitor to it first to see if the external monitor shows the same symptom.
Are you getting green cast on the whole screen?
Post back.
Dec 04, 2010 | Acer Aspire 6920 Notebook PC
Spark plug wires crossed on 4.3 vortec
Not sure if this is a question or a comment.The firing order will be cast on the front half of the intake manifold .1-6-5-4-3-2. Looking from the fron end the closest two terminals on your cap,the one on the right is #1 the going clockwise #6 is the other on the left and so on.The drivers side of the motor in 1-3-5 and the passinger is 2-4-6.Well hope this helps and good luck.
Mar 24, 2010 | 1995 Chevrolet S-10 CA Edition
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Green translucient vertical bar on left side of screen
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
