Question about Tablets & eReaders
Polaris office not listed as installed in my apps, why? Has a shortcut icon, tried to open it but it opens like it should hen just shuts right back off I have an Android tablet
  • Patricia stillwell
    Patricia stillwell Dec 10, 2016
    I have opened it before and it worked but not now
  • 274 Answers
SOURCE: when downloading apps I get message : there are no android phones associated with this account. Please sign in with different account.
Exit and try again, i think it'll be fine. If not, it's better to call the supplier for help.
Android 4.0 Tablet PC
Posted on Feb 10, 2012
SOURCE: my cruz tablet 103 won't keep app open, it just reverts to home page. Any suggestions?
You need to update your tablet, or update the programming on your tablet. Apparently all the android 2.2 tabs are considered "legacy" models and don't support the newest google and java script. Since this is what the net primarily uses, those of us with the Cruz are hosed.
Posted on Oct 13, 2012
SOURCE: i have a polaroid android tablet. it one day just started to not work anymore.
Just a thought, however, it might be that it automatically upgraded your Android operating system and now the apps are not compatible. Try deleting one of the apps and re-installing it. Hope this helps you - Learning Thermostat
Posted on Nov 19, 2012
  • 190 Answers
SOURCE: Onda v711
You need to perform a hard reset on your Onda V711. Here`s how: You can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down. When the tablet is turned off, keep home button pressed.
Now turn on tablet while still holding the home button.
When white android figure appears, release both buttons.
You will get into recovery mode, you can select "restore factory settings" there.
If that fails, try flashing new firmware.
Posted on May 03, 2013
SOURCE: irulu tablet wont open
there is no reset butten
Posted on May 03, 2014
Have echo and new apple i pad how do i install it to get wifi. i have 0 knowlwdge
Follow the small sheet of instructions that came with the ECHO.
if you want to hear music (and other audio) in stereo, attach a separate pair of stereo speakers to the 3.5 mm jack on the back of the ECHO (I'm assuming it has one like my Echo Dot does).
you may have to push the 3.5 mm plug in hard for it to connect to both stereo channels on the cable. If you only hear sound out of your left speaker, both channels aren't connecting. Disconnect and reconnect the 3.5 mm cable a few times, being sure to push it in hard. This will loosen up the jack so that the plug connects easier and correctly.
On your iPad, open the App Store by tapping its icon.
in the search box at the top, type Alexa.
From the list provided, click the Open button next to the icon for Amazon Alexa, and follow any instructions that may follow. The icon should appear on you iPad, most likely on the last screen of icons (assuming the you have more than one screen of icons). Sweep to the left until you get to the last screen of icons to see it. Then click on the icon to open the app. When the app opens, click on the "3 horizontal bar" icon in the upper left corner. A menu will drop down. Click Settings. Then, click SET UP A NEW DEVICE , and follow the instructions.
Nov 14, 2017 | Apple Tablets & eReaders
I have an iPadand would like to put my Kindle books here
Install the Kindle app from Apple's App Store on your iPad.
To do this, click on the App Store icon, click, the search icon (magnifying glass) in the lower right corner, type Kindle in the search box, then select Kindle App for iPad ... or ... Kindle for iPad from the list. Click the Install button.
Once the app is installed, open it.
The files that you already own should start to automatically download. You may only see the various cloud file icons in your list, and then need to click on them to start to download the files.
Updates to downloaded files can be done when they become available or may happen automatically depending on your iPad's settings.
Oct 30, 2017 | Tablets & eReaders
How do I insstall Alexa app on my ipad?
from the list provided, click the Open button next to the icon for Amazon Alexa, and follow any instructions that may follow. The icon should appear on you iPad, most likely on the last screen of icons (assuming the you have more than one screen of icons). Sweep to the left until you get to the last screen of icons to see it. Then click on the icon to open the app.
Apr 04, 2017 | Apple iPad Tablets & eReaders
How do i set my tablet to auto save to my SD card
There are several methods to help you set download application path to SD card by default.
Please follow the steps given below,
Method 1:
- Insert the SD card into the device, Touch 'File Browser' on 'Home screen'.
- Tap 'Apps', On Apps, select the 'App to be installed'.
- Tap OK to install the App to SD card.
Method 2:
- Tap 'Settings' on 'Home screen'.
- Tap 'Storage', Check to turn on SD card, and set 'SD card' as the default storage place.
Method 3:
- On your Android tablet or phone, tap the 'App drawer' icon from the home screen.
- From the displayed list, tap on the 'My files' icon.
- From the opened window, on the top right corner, tap the icon with four horizontal lines.
- From the displayed menu, tap the 'Settings' option.
- On the opened Settings window, under 'Select directories' on the left, tap the 'Set home directory' option.
- From the window that appears next, tap to select the desired folder or the entire external SD card where you want the files to be downloaded by default.
- Tap the Done button from the top right corner of the window when you are done.
Jul 22, 2016 | Polaroid 7-in. Internet Tablet - Other
To help you guide to delete the application or the games icon that are appearing on your tablet desktop screen, please follow the steps mentioned below:
- You can hold your finger on an app shortcut/long press an app icon on the home screen of your tablet.
- All icons will get smaller, a border will appear around the icon you pressed and you can see a trash icon displaying at the bottom right corner.
- Just drag and drop the app shortcut from desktop to the trash can or Recycle bin.
May 23, 2016 | Tablets & eReaders
How do I add my iPad to my Kindle account?
How to Install the Kindle App for iPad/iPhone The Kindle app can be used on any iPad, iPhone, or iPod touch with iOS 3.2 or greater installed. Installing the Kindle App Visit the App Store and download the Kindle app to start reading from your iPad, iPhone, or iPod touch. To install the Kindle app: 1. Tap the App Store icon on the home screen of your iPad, iPhone or iPod touch. You can also get the app through the iTunes Store. 2. Search for "Kindle" or find it in the alphabetical list of apps. 3. Follow the on-screen installation instructions. When installation is complete, tap the Kindle icon on your device to open the reading app. Registering the Kindle App To register your Kindle app, use your existing Amazon account e-mail address and password. If you live outside the United States and use the Kindle application, please see the Using the Kindle App if You Live Outside the United States Help page. Logging into your account through the Kindle app registers your device to your account. Once you sign in during registration, you won't need to do it again -- just open the app to access your Kindle Library. To register: 1. Tap the Kindle icon on your iPad, iPhone or iPod touch to open the reading app. 2. Enter your account e-mail address and password. 3. Tap the "Register" button. You can also tap the Settings icon (the cog) on the Kindle Home screen to view or change your account registration. Signing Out and Deregistering If you sign out of the Kindle app, your reading app is deregistered from your account. When you deregister, you can't download content to the Kindle app or send purchases to the app unless you register again. To deregister using the Kindle app: 1. Tap the Kindle icon on your iPad, iPhone or iPod touch. 2. Tap the Settings icon in the lower right-hand corner of the screen. 3. Tap "Update" under the Registration field and then tap the Deregister button. To deregister online: 1. Visit Manage Your Kindle on 2. Open the Manage Your Devices section and locate your registered Kindle app. 3. Click the "Deregister" link. installing
Dec 08, 2015 | Apple iPad 32 GB 3G Tablet PC
How do I delete an app?
Find the icon for the app you want to delete, and press and hold it for a few seconds. It (and all the other icons on the screen) will start to wobble gently, and a small cross will appear in a grey circle by each. Tap the cross, then confirm you want to delete the app.
Mar 01, 2015 | Apple iPad (16 GB) WiFi Tablet PC
App icon disapeared from display but it is still in app manager, cant open app without icon
Have you checked the app drawer?. If you see it there, long press it and you can add a shortcut to the home screen.
Feb 16, 2015 | Samsung Galaxy Tab on 3 Mobile Tablet PC
How can I restore a game my grand daughter deleted?
You must be using Android, if that is the case, then just open PlayStore, then tap at the top left to open another windows and choose Apps or My Apps, here is a list of all of your apps. One tab is for installed apps, the other on is for all apps, installed or not. You can tap the search icon at the top and write the apps game that you want to recover, tap install.
If you have an iPad, or any Apple device, open AppStore, look for the Purchase section, search by scrolling down for the game that you want to recover, just tap Get and it will re-install.
Best of luck.
Jan 29, 2015 | Tablets & eReaders
Can I delete a app & start back at level 1??
First delete the app by pressing and holding on the app icon. It will begin to wiggle and a small x will appear at the top right corner. Tap the x to delete the app.
Now visit the app store and install the app again. When you open the app all previous activity will have been removed.
Hope that helps!
Oct 13, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
26 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
