Question about Samsung DV422EWHDWR/AA White Electric Dryer 7.2 Cu Ft, 9 Cycles
Samsung DV422EWHDWR/AA is not drying,and makes grinding noice
    Problem Solver:
  • 16 Answers
One witch rollers is broken and next heating element is broken when heat is not coming inside.
Posted on Dec 12, 2016
In a samsung yop loadinf HE wash machine, should there be water left under the drum after cycle is finished
Either clogged outlet or if you are running an aux hose to outside sometimes the water freezes causing an ice plug and wont drain .
Jan 23, 2016 | Samsung DV422EWHDWR 7.2 Cu Ft Capacity...
My WA456DRHDWR/AA Samsung Washing machine is making a grinding sound, like a belt is messed up. How do I diagnose the problem with no error codes?
open it up and watch while running .washers do not normally have belts would bet the bearings are going the trip
May 02, 2015 | Samsung Washing Machines
Clothes take long time to dry
A dryer with heat but long dry time will always be an issue where the moist air is not able to evacuate effectively.
This could be a restriction in the vent hose (smashed or clogged), blockage at the outside exit (lint build up or a bird's nest), an inordinately long run of vent hose (more than 12 feet) to name a few.
Mar 16, 2014 | Samsung DV422EWHDWR 7.2 Cu Ft Capacity...
Load noice when drying
The squeaking is likely coming from the drum rollers and the grinding is likely coming from the drum rubbing against the door frame. This can be caused by a badly worn roller or damaged felt slide. A repairable condition that should be considered before throwing out your dryer. You can obtain a kit for this at your local appliance parts store or order on line. If you or know of someone that is pretty handy, you can install the kit, and a new felt slide for less than 1/3 the cost of replacing your dryer. Remember to inspect the drive belt to ensure that it is not torn or about to break.
Mar 03, 2014 | Dryers
I have a mazda 6 s 2003 that make a loud humming sound wile driving but if I turn the steering wheel a little to the right it stop. if i turn left it doesnt do it but it started to make a grinding noice....
The humming might be an wheel miss-alignment. and/or
Grinding maybe the steering box (rack and pinion)?
******* ALL this could also be a worn out BALL JOINT, in which case you should have this checked out RIGHT AWAY!!!
VERY DANGEROUS to drive!!! ******
Feb 06, 2014 | Vehicle Parts & Accessories
Kenmore Washer 110.94818200 Spin Grinding Noice
the bearings are bad and yes they can be replaced but a service tech will have to do it. very big job
Jun 22, 2008 | Washing Machines
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Samsung DV422EWHDWR/AA White Electric Dryer 7.2 Cu Ft, 9 Cycles Logo
48 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
