My fire TV box won't stay powered up - Televison & Video
My fire stick remote won’t respond to Alexa commands from remote
hi Douglas298.
this is all i could find.
Fire TV Remote NOT Responding / Syncing / Connecting: SOLVED I've changed the Fire TV Voice Remote control batteries 5 times already but it still keeps disconnecting and now it's gone completely dead! Update 08/02/17: The most probable cause for your Fire TV remote not working is going to be the batteries. I know, you're thinking I've already changed the batteries twice already. The Fire TV remote is a fickle beast and only likes brand new fully charged batteries before it will re-connect to your Fire TV box. I've tried switching in batteries from other devices that are all working fine, but without any success. Brand new batteries are the key for this power hungry remote.
Has your Amazon Fire TV Box or Fire TV Stick become slow? See my Fire TV Slowdown Solution here.
This need for new batteries seems to be especially true when your Fire TV box is next to a complicated TV setup with AV, Speakers, WiFi Router all next to each other.
AMAZON FIRE TV 4K
AMAZON FIRE TV STICK
If you've tried brand new out of the packet batteries and it's still not working then you might have the same issue I had below. Don't forget to ask any questions you might have in the comments beneath this article.
Update: You can now control you Fire TV Device with the Amazon Echo & Amazon Echo Dot
If you've felt the annoyance of your Fire TV Voice Remote suddenly not connecting then I know how you feel. I've owned a Fire TV since October 2014 and up to now it's handled everything I've thrown at it. This is until one day last week when the remote suddenly kept disconnecting then died completely showing no signs of life.
I went through an array of different fixes to try and get it to work again but then finally I had a brainwave and managed to bring the remote back to life. It wasn't through trawling internet blogs and YouTube videos that I found this solution, it was actually from inspecting the remote more carefully. No, it wasn't Amazon's fault for building inferior products it was actually my own fault and partly the fault of cheap pound stores that litter the UK.
When I took the battery compartment off the Fire TV remote it looked completely normal. It wasn't until I raised the remote up to eye level that I noticed that there was a slight chalky residue on the connectors of the battery compartment. It then dawned on me as I looked across the room at a packet cheap pound shop batteries. One of the cheap batteries had leaked battery acid on to the Fire TV remote connectors blocking the current from getting through.
How to use your Fire TV when the remote won't turn on?
Luckily, Amazon have an App for that called Amazon Fire TV Remote that is available in the Android App Store and the Apple App Store. You can then control the Fire TV using the app and proceed to the next step below.
How to check if your Fire TV remote is connected to your Fire TV?
To see if your Fire TV remote is connecting to your Fire TV box or dongle you need to head to the settings menu.
  1. Settings > Controllers and Bluetooth Devices.
  2. Amazon Fire TV Remotes
This will show you what devices are currently paired and from here you can see if your remote is connecting. In my case when fiddling with the batteries my remote would appear here for a few minutes then disappear.
If all else fails, you can get an official Amazon FireTV Remote replacement.
The Solution
I took a flat head screwdriver and gently scraped the connectors of the Remote at each end. Wiping the residue off with a dry cloth as I scraped. The connector should look shiny and new again at the end of this process. I placed the batteries back in and the remote connected again straight away.
I've had no problems with the remote since and I guess the moral of the story is sometimes you get what you pay for... utter leaky batteries this time.
Fire TV Quick Tips
  1. Hold down the Select button for 5 seconds to put the remote into pair mode.
  2. Hold down the Select + Play buttons together for 5 seconds to Restart the device.
  3. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in.
  4. or try this link.
fire stick remote wont respond to Alexa commands from remote Google Search
Nov 29, 2017 | Televison & Video
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Went to settings and accidently turned off blue tooth wi fi now my fire stic remote will not respond air won'' scroll up or down and I can't get back to settings
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
Apr 03, 2015 | Amazon Fire TV Stick
My power switch won't stay on for less then a second
More than likely you have a bad flyback . Its a high voltage lead that fires the tube upon start up or you have a couple of bad capaciters on the board. you can tell the ones that go bad by the swollen tops. if your sharp you can replace these cheap
Sep 04, 2012 | Philips Magnovox Telivision Set With Vhs...
Won't stay on
3-blinks by the SONY TV error code indicates that there is an audio circuit problem, ether is a shorted audio amp IC on the main board, or the power supply that supply the power to the audio amp section is defective.
May 22, 2017 | Sony KDL-52EX701 52 in. LED TV
TV keeps shutting off.... won't stay on, any ideas?????
Check for bad capacitors in the power supply. Check for voltages. You can get a board at Encompas Parts.,
Nov 19, 2011 | RCA TruFlat 27F520T 27" TV
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Hi, i just purchased two LG LCD TV's the 26LD350 and the 32LD350 I'm worried that it does not have an off switch and only goes on to standby mode. you here alot about tv"s catching on fire because of this....
I have never heard of any LG TVs having a fire issue.
LG added this switch to help save electricity. "Going Green".
You see, this On/Off switch was added to kill the power to the TV when not in use. This switch stops the TV from consuming power by not giving it power to be in a “Stand-By” mode.
If your TV does not have this switch, you could simply unplug your TV to give you the added satisfaction it won’t catch fire.
I hope this information has helped.
Good Luck.
May 23, 2010 | LG Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
