Question about GE Microwave Ovens
GE mod# JVM2005K02 micro wave touch screen not working
  • GE Master
  • 9,047 Answers
Maybe the information here is what you're looking for:
http://www.microwavecontrol.com/jvm2070.htm
Posted on Dec 23, 2016
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    Ge profile micro wave above stove 1850SM2SS will not heat turn table works and lights work
    If you know DMM then only you can fix it. Check magnetron continuity and the transformer continuity. Mostly magnetron blows up. Danger microwave has 5000 volts in it Thanks Discharge capacitors
    Nov 13, 2011 | GE JVM1850 1000 Watts Microwave Oven
    Micro wave will not heat has a picture of a little micro wave on the screen
    Either the power board to supply the magnatron or the magnatron is defective.
    Check or have someonr check the output of power supply. If ther is a hi reading, then change magnatron
    Aug 05, 2010 | General Electric Microwave Oven
    My microwave starts however food does not heat up.
    Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
    Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
    Why would my microwave no longer heat or cook?
    micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
    Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Will not start
    I have the same problem, diagnosed as bad touch screen panel.
    Apr 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Micro wave stopped heating. All other features
    Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
    Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Sparks and strange noise when microwave is turned on even when empty inside. i have a ge jvm1850smss over the oven microwave.
    YOU SHOULD NOT RUN MICRO WITHOUT ANY THING IN IT / THIS WILL OVER LOAD THE MAG TUBE . AND SOME TIMES FRY IT .. The sparking and arcing is probably a bad wave guide . this is sometimes caused by food splater / it gets in the cracks and corners and then cooks till it truns to carbon which conduts the micro's and thus arching .. clean it good and touch up any burns in the metal and repl wave guide cover. mm hope this will help .. mm
    Dec 20, 2009 | GE Spacemaker Over-the-Range Microwave
    Need to replace handle on micro wave can not
    I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
    Dec 18, 2009 | Jenn-Air M439 Microwave Oven
    I have a micro wave oven model FM906815B it comes on and beeps the number F3 COMES on screen
    This is due to a Defective control board..You will have to replace it , it is a design flaw.This has been a longstanding problem on the control board. You can remove and replace it yourself ( you will not void warranty) or you can have a GE service tech do it.. Good luck !
    Sep 13, 2008 | GE Microwave Ovens
    Microwave Ovens Logo
    119 people viewed this question
    Top GE Microwave Ovens Experts
    D. E. Hev
     Larry
    Larry
    Shekar Avadhani
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
