Question about Frigidaire Washing Machines
Frigidaire model FTF 530FS wont do high speed spin cycle
  • 25 Answers
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Posted on Feb 16, 2008
  • 63 Answers
SOURCE: model 110 washer will not go into a final high speed spin.
is it top load or front loader kenmore what
Posted on Nov 12, 2008
SOURCE: Frigidaire front load washer model GLTF1670ASO
Check the shocks on the bottom of the drum. I had the same problem and had to replace the shocks because they were broken in half.
Posted on Dec 07, 2008
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
SOURCE: frigidaire washer model #fwt425rhso
This is the second time I have had to replace the drum/support shaft on this washer. Not only is it expensive, but very difficult to replace. Probably the very worst washer on the market for this reason. And I only do 3-4 light loads of laundry per week. A definate design flaw on the part of the manufacturer.
Posted on Oct 20, 2009
How do I change f to c
Thank you for your post, Joel!
From the information you have provided you would like to change the temperature on your Frigidaire washer from Fahrenheit to Celsius. I was unable to locate any information regarding changing the temperature on your washer. If you need any further assistance please feel free to reconnect. -Matt
Mar 18, 2015 | Frigidaire FTF2140FS Front Load Washer 10...
Frigidaire front load washer FTF2140 upon start it began filling and then turn off, did this everytime. Unplugged it and the same thing happened. Now the lights stopped coming on and it does not work.
Good Morning Heather,
I understand that your Frigidaire washer, model# FTF2140, begins to fill and then turns off. You unplugged it, trying to reset it, and now the lights are not coming on and your washer is not working. Since you have already reset your washer, by unplugging it, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of your washer not working is. Hope this is helpful.
-Best Regards-
WP
Apr 29, 2014 | Frigidaire FTF2140FS Front Load Washer 10...
How to clean it ask
Hi Heather, this is Z. Thank you for your post!
I see that your question is listed under a Frigidaire front load washer, FTF2140FS. Please help me understand if the question you are asking is related on how to clean the tub of your washer. If so, you may add a 1/2 cup of liquid bleach to the detergent compartment of the dispenser drawer and fill the bleach dispenser compartment to the Max Fill level and run WITHOUT a clothes load using the Normal Cycle to refresh the tub. I hope this is the information is that you are seeking, otherwise if you have further questions, please do not hesitate to reconnect!
Mar 05, 2014 | Frigidaire FTF2140FS Front Load Washer 10...
My front load washer wont go into final spin and clothes are soaked
What is the model number of the unit?
Try running it in a different cycle to see if it does the final high speed spin.
Post back the results.
Nov 08, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire front load washer will start and after about 2 seconds will stop. Lights will go from normal working to no spin
From what you have described I would have a professional diagnose the unit's timer and main control board for possible replacement of those parts.
Aug 31, 2012 | Frigidaire FTF2140FS Front Load Washer 10...
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
I have a Frigidaire front load washer. Model #: LTF2940EE0 Serial #: XC64319573 and it is not spinning on high speeds. It is spinning but only slow. When I put it on the rinse/spin cycle it spins in low...
Motor has some shorted windings. Timer switches to higher current for faster rotation and the thermal overload protection shuts the process off as the current is too high because of the shorted windings.
Oct 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
Won't go into high speed spin at end of cycle.Spins slowly and reverses direction instead of high speed spin to remove water from clothes
Hi.This is a common problem for this model.You have a bad speed control board.The board is mounted on the rear lh base of unit .Replacement is easy, part costly.Two screws hold the board to the base and there are 2-3 quick disconnect plugs.You'll need model number to get correct one.Hope this helps .Please rate my response :)
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will not go into fast spin cycle
SOUNDS LIKE YOU MAY HAVE TTO REPLACE YOUR BELT ON YOUR WASHER. I AM NOT A MECHANIC, BUT I THINK THIS WILL HELP.
May 13, 2009 | Frigidaire Washing Machines
Washing Machines Logo
52 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
