Question about Coffee Makers & Espresso Machines
Question about Simonelli commercial machine, the steam wand has a small amount of steam puffing out of it?
  • 25 Answers
SOURCE: steam wand
As the espresso is being made, you can steam the milk by opening the valve that goes to the wand. (sometimes there is a "switch")
To steam milk:
-Fill pitcher (or whichever container you want) with milk e**ugh for about 2/3 of your cup. A thermometer would be helpful.
-Place pitcher under the wand and lift it so that only 1/2 inch is under the surface of the milk.
-Open the steam valve. The milk will expand as it heats. Lower the pitcher to maintain the 1/2 inch depth. You should hear a "shushing" sound and have ** splattering.
-When milk is about 150 F (or preferred temp), close the steam valve and wipe the wand with a damp towel or else themilk will cake on the wand.
Good Luck
Posted on Mar 10, 2008
  • 1031 Answers
SOURCE: steam wand not working
The steam wand ejects steam in order to froth the milk. The steam wand should be cleaned after it is inserted into milk and at the end of each day. Do not allow the steam wands to soak in water overnight since some of the dirty water can be sucked into the boiling tank inside the machine this may cause the steam not to come out
Unplug the machine, take the case off, disconnect the switch wires and test it with a continuity meter. If you don't get any continuity, or if it is constantly closed and never open, the switch is bad.
this could have been prevented by regular maintenance and proper use. The usual suspect is a gummed up wand or brew line or user error. Here’s what to look for and how to avoid it.
First, notice what kind of wand you have. Most semi-automatic and porta-filter espresso units will have wands that resemble those on bottom or right, although the tips may be different. Some tips do not slide up and down to alter the aeration, as the one on the bottom does. If your wand is from an older (1990s) unit, it could have a more bulbous tip and a smaller hole in the tip. wandte1.jpg wandte2.jpgSome of the new wands give you a manual/automatic control.
wandte3.jpg Many of the new super automatics come with an automatic frothing unit, like this one from Jura-Capresso. The nice thing about the frothing wands on Jura-Capresso's new units is that they allow for even more control.
The "Dual Frother Plus" (top) works like the traditional frothing wand. The metal sleeve goes up for steam, down for foam.
The "Froth Xpress Plus" is a very handy device which can be used with the included sleek milk container or a distinct milk container, like a 1/2 gallon jug. The Froth Xpress has a tube (hard for using the included container, flexible for using a different container) that fits into the frothing tube behind the dial shown in the picture above. After selecting froth or steam, the milk is siphoned into a cup below the steam wand. We recommend steaming the milk first, then adding the espresso.
Whatever sort of wand you have, it is essential to keep it clear of solidified milk which can gum up the tip and even the wand shaft. Here are some symptoms of a clogged wand:
  • Little or no steam comes out of the wand
  • Hot water drips from the tip of the wand
  • A squeal or whistle comes out of the wand when the steam function is selected
  • A deep humming is heard when the steam function is selected*
*This is also a symptom of another more serious problem, particularly if you have a pump espresso machine; so if unclogging the wand does not solve it, you should contact a technician.
A good preventative measure against the clogging of a steam wand is regular rinsing in warm, soapy water of the tip and any other removable frothing part. This should be done after each steam wand use. If your machine has a Froth Xpress, it is important to clean all of the hoses, valve, and connectors (be very careful with the plug, however, because it is delicate). All wands should also have steam jetted through them after a frothing cycle is run.
Another preventative measure is to run a steam cycle for about twenty seconds before each new use. This will eject stray particles before they can build up and cause serious damage. There is also a cappuccino cleaner available which can be used in the automatic frothing devices. The solution is placed in a reservoir, and a full cycle is run until the reservoir is emptied. This can be done every few weeks or every few months, depending upon use.
Aside from prevention, there are treatments for a clogged wand. First, remove the tip, if the tip is removable. Usually they are, as in the case of the plastic tips above. The holes are usually big enough to run a pin or even a small paperclip through (emphasize small) to remove the gunk. If these items are too large, do not attempt to use them; instead try using a thin gauge wire from an electrical wire strand. Next, the metal wand itself can have a pipe cleaner run up into it. Start out by putting just about a half inch of the pipe cleaner up the wand, rubbing it around, then pulling it out. Gradually work more of the pipe cleaner up the wand, but never let the length of pipe cleaner in the wand exceed the wand length. We recommend the pipe cleaners with the stiff barbs attached, as opposed to the mostly soft ones. Do the same for all of the hard hoses and connectors. With respect to rubber or soft plastic parts, rinse them in soapy hot water. If flexible hoses form holes, replacements are available (give us a call) or we've even had some luck at aquarium supply stores.
PLEASE NOTE: if you own the Jura X7 or the Froth Xpress Plus, the diameter of the tiny holes is very important. We recommend trying not to put pins into these holes. However, if they must be cleaned and soaking won't work, a smaller gauge wire, a single strand, should do the trick. Always use a strand that is smaller than the diameter of the hole.
Frothing wand technology is advancing at a breakneck speed, but along with these advances come serious precautionary measures for dealing with these very delicate mechanisms. Follow the steps above, and your machine should be producing full-fledged froth for its entire life.
Posted on May 26, 2008
  • 5 Answers
SOURCE: Steam wand shooting water instead of steam
you should confirm right operation reference to instruction book,
perhaps need descaling for your machine.
SOURCE: Starbuck's Barista steam wand leak
remove the cover from the machine, loosen the allen screw that fastens the steam knob to the shaft, move it slightly and retighten to allow the knob to close the valve a bit more. I have had to do this a few times in the 9 years I've had my machine as either the knob loosens or the valve threads wear a bit.
Posted on Mar 03, 2009
  • 32 Answers
SOURCE: Too much water coming out of steam wand
I noticed the wand squirts hot water at first befor the steam comes out, sometimes for quite a while, so grab a bowl or something and let the water drain out until the steam comes and then put it in the milk. This is what I do and it makes awesome frothy steammed milk.
Good luck and enjoy.
Posted on May 12, 2009
Need replacement steam wand wega epu 2
wega epu. Commercial machine. I'd check Any faema, wega, nouva simonelli wand will screw into the wega valve.
They also have precision wands from japan. Sproline series i believe it is called.
I have no association with the site but i do know that any of the parts Listed will work.
Oct 04, 2013 | Wega Coffee Makers & Espresso Machines
No steam pressure
Leave the valve open until it starts slowly hissing, then shut off valve and wait for the pressure to build up.
Oct 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
We just bought a coffee shop with a Nuova Simonelli Premier Maxi. When we were looking at it today, we noticed one of the steam wands was disconnected. We are unsure how to put it back on. Is there a way...
I need more info on the machine and or steam wand, is it the screwed in type with the nut or is it in one piece with the holes on the side, they made 2 models.
Nov 25, 2010 | Nuova Simonelli Oscar Coffee Maker,...
It is dripping a little water out of the left head and dripping a little out of the left steam release in the back.
Replace the solenoid on the head and the swivel o-ring on the steam wand, if leak is in the nut, if it is in the handle then the 2 small o-rings on the plunger needs to be replaced.
Dec 01, 2009 | Nuova Simonelli Premier Maxi Espresso...
Steamer is not getting hot enough.
Try using the milk clamp on the tube going into the milk.Tightening it will make your milk hotter.
Your steam wand however, is a different problem.
First, check in the programming that the steam temp. is 125 celcius.
If it is, and none of the tubes from the steam wand to the boiler valve are blocked, your boiler temp. sensor may be faulty, in which case, you will need to replace that.
Mar 13, 2009 | Nuova Simonelli Microbar Espresso Machine
Old 1996 nuova simonelli mac digit no pressure or heat
There is a reset thermostat on the right side of the machine above the element, check to see if it tripped. If it did make sure there is enough water in the machine and when turning it on, open one of the steam valves and turn off the cup warmer. Leave the steam wand open until it hisses or small amounts of steam or air will vent out.
Feb 11, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
