I have a Honeywell programmable Pro TH 4000 5-2 thermostat, it will not hold the programmed temperature. How do I fix the problem
  • 98 Answers
SOURCE: Honeywell Programmable Eletronic Thermostat model RTH230B
There are so many products, we cannot help without the model no. Try typing 'Honeywell programmable electronic thermostat' into google and searching for an image of your thermostat, then get the model no. Then you might be able to get some help.
Posted on Dec 23, 2007
  • 4 Answers
SOURCE: Honeywell Commercial PRO TB7220U Touchscreen
That one is fun. Touch the system cycle button. then touch the two spaces on both sides of the center button at the bottom hold them down at the same time. After 5-10 seconds the screen should flash and show numbers int the center of the screen touch the screen til the numbers 670 appear. then change the numbers beside it to 0. then click done. now you should be able to adjust temperature as needed
Posted on Apr 15, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 22 Answers
SOURCE: cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Posted on Jan 02, 2009
  • 252 Answers
SOURCE: how do I program my honeywell basic thermostat?
Go to
and search for a manual for your model number thermostat on the right hand side of the page.
Posted on Oct 10, 2009
Cannot program heat to come on
The flashing may indicate the need for battery replacement.
Oct 13, 2014 | Honeywell PRO 4000 Programmable 1 Heat/1...
Heater problem
Is the unit a heat pump? If so then check the aux heat relay to see if the electric heat strips come on.
Feb 05, 2014 | Honeywell PRO 4000 5-2 Day Programmable...
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
Program manual for honeywell thermostat model T8700C1005(1)
go here:
Nov 13, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
