Question about Brother HL 1240 Printer
I have the same problem with the same printer
If I turn off the printer, pull the toner cartridge, replace it, and turn the printer back on I can usually print one page. Then I end up with the same error.
    President:
  • Brother Master
  • 1,447 Answers
Please you change your printer drum unite then solve your problem
Posted on Jul 21, 2009
I have a brothermfc 7340 printer and cannot replace the drum
Open the front of the printer by pulling the front panel toward you and down. (where you replace the toner cartridge)
Remove the toner cartridge/drum unit assembly by pulling up and toward you.
separate the drum unit from the toner cartridge by pressing the green release tab on the side and lifting them apart.
place the toner cartridge into the new drum unit
replace back in the printer
press "clear/back" button and then press "1" to cancel "replace drum" message
close the front panel.
http://support.brother.com/g/b/faqend.aspx?c=au&lang=en&prod=mfc7340_us_as&faqid=faq00000154_039
Apr 04, 2015 | Brother DCP Office Equipment & Supplies
I have change toner but same massage given
Then you still might have a bad toner cartridge. Try the following in the EXACT order:
1 Pull out the toner cartridge.
2 close the printer back up and let it recognize that there is not toner cartridge.
3 turn the printer oss
4 insert the new toner cartridge
5 turn the printer back on.
if the above fails you will need a new cartridge, preferably a different brand.
Feb 18, 2015 | HP LaserJet 5200 Printer
My canon printer ir 2022 prints faint and blank pages, what can be a problem and how can i fix it?
Possible Problems:
1)Out of / Low on Ink.
Solution : replace the ink
2)Printer Setting
Solution : Check to make sure the lighter/darker slider is somewhere near the middle. This will be in the configuration screen on your printer.
May 02, 2011 | Canon iR 2022 Printer
How do I access and change out the toner cartridge? (brother HL-2140 printer)
1 Turn your Brother HL-2140 laser printer on.
2 Open the front cover by pulling the top latch toward you.
3 Pull the printer drum unit toward you. Put it on the clean, blank sheet of paper.
4 Push the green lever on the drum assembly down.
5 Remove the empty toner cartridge from the drum unit.
6 Shake your replacement toner cartridge gently to evenly distribute the toner inside.
7 Put the new toner into the drum unit and slide the unit back into your Brother HL-2140 printer. Close the top cover.
See also Brother user manual for this model at: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Feb 25, 2011 | Office Equipment & Supplies
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Toner cartridge needs replacing in brother hl-20
if you want to replace your toner,
First you just need to open your front cover and pull out the toner and drum.
after that, push down the blue buttom on drum and pull out the toner. Then replace the new toner into the drum.
finally, just push back the drum and toner back into the printer.
Apr 01, 2009 | Brother HL-2040 Laser Printer
Hi there I have a brother HL-2170 W and have a page in the machine that is jammed. I actually turned the power off in the middle of a print job. What do I do? when I turn the power on the error light...
You should be able to solve your issue by following the first 7 steps below for clearing paper jams. After that put your printer back together and see if it starts working. If not, follow the rest of the steps and you should be fine.
  1. Open the front of the printer.
  2. Slowly take out the drum unit and toner cartridge assembly. Some of the jammed paper will be pulled out with the drum unit and toner cartridge assembly.
  3. Set the drum unit and toner cartridge assembly on a piece of disposable paper or cloth in case you accidentally spill or scatter toner.
  4. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes inside the printer.
  5. Close the front cover.
    Note: Do not put the drum unit and toner cartridge assembly back in at this point.
  6. Pull the paper tray completely out of the printer.
  7. Pull the jammed paper down and out of the printer.
  8. Open the back cover (back output tray).
  9. Still looking at the back of the printer, pull the tab toward you to open the fuser cover.
  10. Pull the jammed paper out of the fuser unit.
    HOT SURFACE
    After you have just used the printer, some internal parts of the printer will be extremely hot. Wait for the printer to cool down before you touch the internal parts of the printer.
  11. Close the back cover (back output tray).
  12. On the drum unit you set aside, push down the green lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
    CAUTION
    Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
    To avoid print quality problems, DO NOT touch the roller part of the toner. Try to keep you hands, fingers and everything else away from there.
  13. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the green lock lever will lift automatically.
  14. Open the front cover. Put the drum unit and toner cartridge assembly back in the printer.
  15. Put the paper tray firmly back in the printer.
  16. Close the front cover.
  17. Make sure that the Error LED is now off.
Jan 11, 2009 | Brother HL-2170W Laser Printer
How to remove the toner cartridges
Close the cover to the machine and make sure you aren't getting any other error messages other than the toner. When the printer is at the ready state press the rotate toner button. You should hear the printer rotate the toner and then the light over the cyan cartridge will come on. Keep pressing the rotate toner button until you get to the color you want to replace. Open the top cover and front door where the KM logo is. You should see the cyan cartridge in place. Pull the cyan tab back toward you. The front part of the toner should release. Now pull the tab and the toner straight up and out of the printer. If you are having problems getting the toner out it is probably not in the correct position. There is a slot on either side of the printer that he back end of the toner cartridge needs to be in before the toner will come out.
Jul 10, 2008 | Minolta magicolor 2400W Laser Printer
Brother HL 1240 Printer Logo
50 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
