Question about Frigidaire Kitchen Ranges
Frigidaire gas stove, oven will not work. Shows F30 code
  • 36 Answers
That is an error with the temperature sensor.
Unplug the unit or turn the circuit breaker off for 60 seconds.
Restore the power to the appliance by plugging it back in or turning the circuit breaker back on. If you still have the problem here is a link to order the replacement part and a video how to replace the part which is fairly easy to do.
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/561286-error-f30.html
Posted on Dec 10, 2016
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
SOURCE: stove oven does not workit,s a kenmore stainless steel
I have experienced a f30 code on my oven...I was told to change the oven sensor probe which i did....The code still comes up!!! SEARS IS NOT ANY HELP
Posted on Jan 03, 2009
jumptrout51
  • 3361 Answers
SOURCE: Oven won't turn on, but the stove is fine!
Replace the oven glow bar ignitor.
Posted on Apr 20, 2009
  • 119 Answers
SOURCE: Error code F30 on a frigidaire ples389ecc oven.
THAT CODES MEANS EITHER THE PROBE SENSOR OR THE ELECTRONIC CONTROL IS BAD. UNPLUG. WITH WIRING DIAGRAM AND OHM METER, TEST THE TWO WIRES GOING TO PROBE. IF YOU GET ABOUT 1100 OHMS, YOU HAVE A BAD CONTROL. IF YOU GET 0 OR INFINITY, IT'S THE SENSOR OR THE WIRES BETWEEN THE PROBE AND THE CONTROL
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH IF NEEDED
Posted on Jan 14, 2010
My Oven is displaying a f30 ERR message and won't allow me to use my oven,,,the stove works fine....what do i do?
I have same problem, displaying a f30 err message and does not work oven rest is working. I have changed sensor still does not work.
Apr 17, 2011 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
How do i fix an f30 error code on my frigidaire range? it only beeps when i try to turn on my oven... and shows f30
Sorry to read about your problem, I hope this helps you out.
You have a shorted keypad membrane.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire Microwave Ovens
Frigidaire professional stove, Oven does not work, can't bake, self clean. get an ERR F30 code.
Is the clock set?
In mine - the clock has to be set - or it won't work;
Aug 12, 2010 | Frigidaire Ovens
Oven doesn't work. Display F30 code. Gas Range model: 790-78579405. First time usage for oven. All stove burners does work. Some blogs mentioned "reset" red buttom but couldn't find it from the back metal...
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here: www3.sears.com
Kenmore range repair in orange county, ca
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Our figidaire electronic stove/oven model PLES399ECD, serial number NF62311528, mfg'd 2/2006 has an error code for F30 when any program is selected. The manual does not list F30, what is F30?
Open (F30) or shorted (F31) RTD sensor
probe/ wiring problem. Note: EOC may
initially display an "F10", thinking a
runaway condition exists.
1- Press Cancel key.
2- Check wiring in probe circuit for possible short or open
condition. Check RTD resistance at room temperature
(compare to probe resistance chart). If resistance does not
match the chart, replace the RTD sensor probe. Let the oven
cool down and restart the function.
3- If the problem persists replace the relay board.
Sep 25, 2009 | Frigidaire PLEF398AC Electric Kitchen...
F30 Erorr on stove...
The fault code shows that your temperature probe opened.
1. Check resistance at room temperature & compare to RTD Sensor resistance chart.
If resistance does not match the RTD chart replace RTD Sensor Probe.
Check Sensor wiring harness between EOC & Sensor Probe connector.
2. Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Jun 29, 2008 | Frigidaire FGB24S5A Gas Single Oven
Stove oven does not workit,s a kenmore stainless steel
Jan 20, 2008 | Kenmore 46123 Stainless Steel Electric...
Kitchen Ranges Logo
56 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
