Question about Radio Communications
I dont have my contreller on and i do what people say on YT, i have the correct dongle but it lits up on the second light but then the others flash and then it turns off :/ i need help
4 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Flashing power lamp
HI, the power unit has failed. you will need to replace this failed power unit if possible.
Posted on Jun 20, 2009
ccamstelveen
  • 201 Answers
SOURCE: modem is not connecting to internet. "ACT" light
Call your Internet provider.
Posted on Feb 13, 2011
  • 8404 Answers
SOURCE: I have a 1990 tw 200 yamaha turn signals in front are lit but dont flash the back dont light up or flash
Check the grounds on your 22 year old bike. The flasher works because of heat building up in a bi-metal strip in the flasher. It gets hot, breaks connection; it cools, makes connection, repeat. If the rear lights are NOT coming on, you are not drawing enough power to heat the bi-metal strip thus it is not heating or cooling, making and breaking connection, not flashing. Check ALL ground connections from your rear signal lamp back to the negative terminal on the battery. Dont miss one connection - lamp to lamp holder, lamp holder to fixture housing, housing to fender, fender to frame, frame to battery (minus side) and so forth. Corrosion is not your friend here - if you find it - clean it. I believe you will find that if you put a wire from the housing to the battery negative terminal, your light will come on. If it doesn't, check the hot side of the circuit.
Oh, by the way, your battery is in tip top condition, right?
Thanks for your interest in FixYa.com
Posted on Dec 02, 2012
I Got an speedlink SL-4451-SBK for ps3 and it wont connect
This works: Turn ps3 on. Plug the controller into the usb cable and into ps3. Then plug the dongle into other usb port. After a short time the dongle will flash quickly (this means it's in pairing mode - when the dongle flashes slowly it's too late). Press the PS/Home button as soon as you see the dongle fast flashing. All the LED's on the controller will begin to flash and after a short time one (or two) will remain solid. Immediately disconnect the charging usb lead from the controller and again the LED's will flash, push the PS/Home button again and after a short time one or two will remain solid. The controller should now be working. If the controller fails to respond repeat this process but make sure that you disconnect the dongle and reinsert (so you can see the fast flashing lights and try again).
Dec 02, 2012 | Video Game Consoles & Games
Gioteck vx1 wireless controller will not pair up to my ps3
Jan 04, 2012 | Video Game Consoles & Games
New mouse does not connect saitek wireless notebook mouse s/n:ho83671834
HI,
You have to manually pair the mouse with the dongle.
Follow this steps and retry them a few times and it will work:
  • Plug the dongle in.
  • Press the button on the dongle for two seconds so that the green light flashes on and off.
  • Press the button on the underside of the mouse once (short press).
  • Wait for the mouse to pair.
  • If it doesn't pair, press the button underneath the mouse once to continue scanning.
The whole process shouldn't take longer than 10 seconds
Hope it helps...
Jan 17, 2011 | Apple Mouse
When my son tries to play his guitar all the lights are flashing on it and we cant figure out how to get it working..
The flashing lights on the controller mean the guitar is not connecting to the wireless usb dongle connected to the PS3.
1. Verify that the wireless box is plugged in firmly to the usb port on the front of the PS3.
2. If that doesn't work, look on the wireless usb dongle for the guitar hero guitar controller. (It should be a black box with the guitar hero logo on it. You will find a small push button on the dongle. (Make sure your PS3 is turned on, though your guitar hero game does not have to be open. It may be a good idea to have the game running, so you can test your guitar or make sure it is really working). Press and hold the button on the wireless usb dongle for a few seconds. Five seconds should be enough. Doing this attempts to re-connect the dongle and the controller. You will know when the connection is good when the red lights on the controller go steady, as well as the LED on the small button you pressed on the wireless usb dongle. If either lights continue to blink, there is a connection problem still.
3. Try changing the batteries in the guitar controller. Weak batteries tend to cause connection issues.
4. Test the wireless usb dongle and controller with another PS3. This will rule out an issue with your PS3 system.
5. If the problem still occurs on another PS3, the wireless dongle may have gone bad. (This does happen rarely.) Replacements are cheap to find on ebay
Jan 11, 2011 | Activision Guitar Hero
I got a drum kit for the ps3 but the drum dongle won't sync with the drums. If i plug another guitar dongle in the drums sync with this and the drums work fine but it's not syncing with the drum hub the...
there are series of problem in ps3 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the ps3 repair guide that will help you a lot.....
Click here to download repair guide
Dec 24, 2010 | Sony Playstation 3 (PS3) Console
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Dongle
I believe that the information that you have been given is correct. The VIP dongle is no longer available.
As for the second part of the question, do you have a damaged dongle or has it been lost completely? If it has been lost, there is no way to replace it without buying a new software package.
Apr 19, 2009 | Husqvarna Viking 1
Guitar hero world tour for ps3
i had the same problem but with trial and error i came up with a soulution
1. Turn on the Playstation 3
2. Plug the dongle for the drum set into an open port on the PS3, the light will begin to flash slowly.
3. Hold down the button (where the light is flashing) on the dongle until it begin flashing very rapidly. Release the button and the light continues to flash rapidly.
4. Hold down the PS button on the drum set until the red light starts flashing rapidly.
5. Within a few seconds you will get a solid light on both the Guitar Hero World Tour Drum Set and the Playstation 3.
thanks
Jan 04, 2009 | Video Game Consoles & Games
Remote control code
Dish Netork does not have the code for Olevia
but you can scan for the code using the infformation
here
Remote Code Power Scan
If your brand is not listed, use the following procedure to scan through all codes.
If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
1. Turn ON the unit you want to program the remote to control.
2. Press the Mode button on the remote until the appropriate mode light is flashes
3. Press the Address button. The mode light will start flashing slowly.
4. Press the Power button. The mode light will stop flashing and stay lit.
5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8. Turn the device back ON by pressing the Power button.
9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10. If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Nov 23, 2007 | Olevia LT32HVM 32 in. LCD Television
Radio Communications Logo
35 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
