Question about HP Officejet 5610 All-In-One InkJet Printer
I have a HP1200 series will not print,
All three lighs came on! and stay on . I try to reset it bu pupluging the BSU (no change) so I unplug the power & the USB this time they went out till I tryed to print. now I cant get a change after unpluging both
Any help Thanks
    Sergeant:
  • 168 Answers
You probably have a bad fuser. Replacement is the only option.
Posted on Jul 20, 2009
How do i get my hp1200 printer to print, is on a off line mode
Hi Joy,
Disconnect the printer completely from the PC.Unplug its power cable too.
Reboot your PC.
Connect everything again from scratch but use a different USB port to connect to the PC.Make sure everything is well connected.Try printing now.Cant print?
Under printers and faxes,check whether 'work offline' is checked by right clicking on the printers icon and 'Uncheck.Still cant print?
Uninstall the printer driver on your PC,reboot the PC and install software again.If you don't have the installation disks,install from this Hp Support site making sure you select the driver that corresponds with your Operating System[Windows 7,Vista,Windows XP etc]
Hope this helps.Thanks!
Please rate this answer.
Dec 02, 2011 | Office Equipment & Supplies
I change the ink jet on my dell 725 printer, and the printing is so faint.
Are you using Dell Series 6 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. This will reset any error messages the printer has.
Plug everything back in and power on the printer. Now remove the Dell Series 6 Color cartridge. Make sure the tape is off the cartridge and reseat the cartridge. Then close the printer and it will print an alignment page. Any error messages?
Dell Series 6 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges
Dell Series 6 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It is possible the cartridge has a bad sensor. Try taking it back to the place of purchase for a replacement.
Rick
May 14, 2011 | Dell 725 InkJet Printer
Tried to fix a paper jam and now I get this code C2FE0100 and the printer won't print. Unplugged it and still nothing
Found this link to reset an HP Printer:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers/
Good Luck!
Mar 01, 2011 | Office Equipment & Supplies
I have a hp1200 series all-in-one printer. I
Are these Original HP Cartridges, Hp recommend you dont us refill or generic cartridges in their printers. Check to make sure u removed the print head protective. Also try cleaning the copper side of the cartridge with a pencil head eraser.
Oct 10, 2009 | Office Equipment & Supplies
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp1200 every time print self text page
after the test page plz put the test page in the scanner and push the scanner button
Jun 30, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
