Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hi:
Your computer will support an 80 gb hard drive. It will recognize up to 137 gb, and you could actually install a 160, with the included set up software that shipped with the new hard drive.
However, finding a Maxtor drive with an identical PCB is not going to be easy. Once you do, you can disconnect the "spinning" part of the disk-drive away from the PCB, and then swap PCB, and see if you can then QUICKLY(!) copy all 80GB to a "new" disk-drive.
It sounds like your hard drive has failed, IE.. the clicking/tapping sound. You could have the hard drive tested to be sure. You could swap out the hard drive to another machine and try it.
it really all depends on how far the damage is. I have swapped the controller board on a hard drive that had failed with one from an identical drive and was able to retrive the data. This is not a very common thing that works. Your data is most likly still entact on the platters. However, if the motor is damaged it would require expert and very expensive help to recover the data.
If you have access to being able to swap controllers then try it. This may get your data back.
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
