Question about NTI Backup Now 5 Advanced for PC
NTI Backup Now 5 file restore not starting
NTI Backup Now 5 file restore status remains at "ready", right click + "Run Job Now" doesn't help. How can i start the file restoration process?
The biggest problem I have encountered with back up now is when you try to run a complete restore the program just can't handle it. Try breaking the restore down into smaller jobs 2 to 3 gg.
Posted on Aug 31, 2009
  • onojim Aug 31, 2009
    then when you get youre data back use a different probram in the future.
My computer crashed, how do I recover my NTI Backup Now EZ program? My computer can't find the NTI setup.exe.
Many people confuse system back-ups with system restore and/or recovery programs. They are very different. A backup makes a copy of selected (or all) files and stores them to a disc, tape, hard drive, or other device that will allow you to protect your files in the event of data loss. Say you accidentally delete an entire directory instead of a single file. Your backup would allow you to re-load that directory. System restore/recovery files are used in the cases where you either want to reload the computer back to a certain condition (factory restore), or need to completely recover your computer in the event of a crash. These types of files usually need one of two things to work. If the recover/restore software was OEM manufacturer supplied, there may be a BIOS routine that, using a hotkey on boot-up, will allow you to access the recovery/restore file. If it is an aftermarket program like your, recovery/restore files usually need to create a bootable USB or CD/DVD that can be inserted on boot-up, and then the files on that device will perform the recovery/restore. If all you have a a system backup, you may have to reinstall the operating system, drivers, and then the backup software. After that, you can use you backup file to recover your remaining programs/data.
Sep 29, 2015 | NTI Computers & Internet
How do I stop backup in progress?
1.Log on to the computer by using an account that has administrator rights.
2.Click Start Collapse this imageExpand this im, type msconfig.exe in the Start Search box, and then press ENTER to start the System Configuration Utility.
·Collapse this imageExpand thisIf you are prompted for an administrator password or for confirmation, type your password, or click Continue.
3.On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (TheUse Original Boot.ini check box is unavailable.)
4.On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.
Note Following this step lets Microsoft services continue to run. These services include Networking, Plug and Play, Event Logging, Error Reporting, and other services. If you disable these services, you may permanently delete all restore points. Do not do this if you want to use the System Restore utility together with existing restore points.
5.Click OK, and then click Restart.
Sep 03, 2015 | NTI Backup Now EZ
I restored a backup from NTI EZ backup but my Outlook contacts and current emails were not recovered. Do I have any chance of restoring them?
You can search your computer for files with a .pst extension by doing a search like *.pst. Once located you can grab them and restore them by opening outlook and choosing to import those files. A bit of a techie solution can be found here How to import from pst file back to Outlook Express AnandTech Forums
Aug 31, 2014 | NTI Backup Now EZ
Nti backup now error message during installation
Install the software before plugging the device in. You may have to uninstall first. Right - Click on the installation file and click ' Run as Administrator'
Dec 05, 2013 | Computers & Internet
I used a Toshiba 1/2 TB external drive with NTI Backup Now EZ software for some years and then the laptop crashed. After byuing a new one the happy moment when all could be restored never appeared. The...
Maybe the restore function only works with the original piece of equipment. Ouch.
You might want to contact the manufacturer of the software to see if they have a fix or solution. Good luck!
Apr 10, 2017 | NTI Backup Now EZ
I'm running Windows 7 on a Dell laptop. It has not completed one backup since I installed Toshiba 500GB portable drive which came with backup software installed on it. While trying to run the backup...
This issue needs to go back to Newtech. They can guide you through the issue. Is the external drive LARGE enough? Windows backup takes huge amounts of room. I suggest Handy Backup Pro, it can pull backup across networks, and push the data to drives and ONLINE locations.
Jan 21, 2011 | Newtech Tech InfoSystems NTI Backup Now EZ...
Hi I'll briefly describe my problem I've an external HDD (Toshiba) with NTI Backup Now EZ software installed on it, and I used it to back up my files the problem is that I can't restore my files now...
You might need to get an older version of NTI Backup Now. I had the same issue. I was using Backup Now 4 which saved everything as .nbf.files. I downloaded a trial version of Backup Now 5.5 and tried to restore the files only to find .nbf files are not compatible with version 5.5!
I sent a rather facetious e-mail to NTI moaning about this issue and they sent me a trial version of version 4. If I were you, I'd do the same. http://www.nticorp.com/en/us/product/backup_now5.asp
All my .nbf files are now restored.
Jan 08, 2011 | Newtech Tech InfoSystems NTI Backup Now EZ...
How do I start making my Maxtor start backing yp
Do you want to create a backup file or do you want to keep your original files saved on your Maxtor? If you want to create a backup file for the files on your computer, type "ntbackup" in the "Run", the backup wizard will automatically start and click "next" > "backup fies and settings" > "Let me choose what to backup" and then select the files and folders you want to backup by click the snap-ins (+ signs) and check mark the files or folders and again "next". In the option "choose a place to save your backup" click "browse" (if you are prompted that the drive A:\ is empty click "cancel") locate your Maxtor directory, click "Ok" and name the backup file something you like, click "next", the backup process will begin with the status monitor. It may take several minutes depending on the files you've selected. That's all. If you wanna restore the backup files, just double click the backup file you've saved and when the wizard opens, select "restore files and settings" and follow the onscreen instructions.
Good luck.
Thanks for using FixYa.
Jun 21, 2010 | Computers & Internet
Flash drive not opening up properly
Every time you remove the drive - the pc will dismount it - -removed = dismount
when you install it again the pc just sees as a new drive and assigns it the letter it get's by default - this is normal as the pc will mount and give the unit a drive number by default.
It is an inconvenience so I wish you the best.
please vote me up if this helps
Mar 18, 2010 | Computers & Internet
The drive database cdrw32.bdb cannot be found i tied to replace file still didnt work now also says nti has stopped working
The following is installation instructions for CD-Maker Professional. For Backup Now, the instructions are the same, however, you will install it in the NTI Backup Now directory, rather than the NTI CD-Maker directory.
To install, please copy the "cdrw32.bdb" file use Windows Explorer or My Computer to copy the database file into the main folder for CD-Maker 2000 Professional. If you installed our software in a different directory then you will need to copy the file into your alternate location.
Example where database file is located:
C:\Program Files\NewTech Infosystems\NTI CD-Maker 2000 Professional
You can also use the find feature in Windows to find the exact location of the database file. Click "Start", the "Search", then "for Files and Folder", then type in cdrw32.bdb and click "Search Now". After it finds the file then you can read under the "In Folder" heading for the correct path where the database file is located. Use Windows Explorer or My computer to copy the database file into this location.
NOTE:
(1) It works only on full retail versions of NTI software
(2) For CD-Maker, it works for Version 5.1.1 or later.
(3) For NTI Backup Now, it works for Version 2.2.33 or later.
(4) For supported DVD burner models, CD-Maker V5.1.XX and Backup NOW! (and DriveBackup!) V2.X will support only the CD burning function of these models, not DVD burning. DVD burning is supported starting from Version 6.0 of CD&DVD-Maker, and Version 3.0 of Backup NOW! and DriveBackup!, respectively.
Thanks for using Fixya
Sep 13, 2009 | NTI Computers & Internet
NTI Backup Now 5 Advanced for PC  Logo
872 people viewed this question
Top NTI Computers & Internet Experts
Tproverb
Level 1 Expert
Mari Criss
Mari Criss
Level 1 Expert
CruzSophia
CruzSophia
Level 1 Expert
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
