Question about Sewing Machines
I'm getting system error #1. It worked fine 2 days ago and this morning won't sew. I've taken off plate and cleaned, not really any lint no threads. Still getting same error message. Can you help?
  • Jimmie Sill Dec 10, 2016
    Hi Linda Robben, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Need to know the type and model of sewing machine.
  • Linda Robben
    Linda Robben Dec 11, 2016
    It's a Janome MC 5700.
  • Sewing Machines Master
  • 12,296 Answers
Search the internet for:
Make Model error #1
or check the Troubleshooting Section of your owner's manual.
Posted on Dec 11, 2016
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
  • 323 Answers
SOURCE: Repeated message: "Please Check the Upper Thread."
The machine stops because the sensor near the check spring(in the tension area) tells it the thread is broken or not there.. You can try to clean it out again but it's probably going to have to go in for service.
sewman7
Posted on Jun 19, 2008
SOURCE: Singer 3962 Thread Catching Under face plate (catching on position finger)
I had a problem with the thread balling up under the face plate, too.
I have a Kenmore 385 16528000. I don't know if with other brands that this will pertain to them, but this was my solution:
I had the needle in the wrong way! The top part of the needle that is inserted into the machine needs to go in with the FLAT SIDE AWAY from you. So I hope that helps somebody!!
Elayna
Posted on Jul 13, 2008
SOURCE: sewing machine thread nesting
I have fixed it now the bobbin case didn't seem to stay seated during sewing or tangling i should say!. I decided to change the needle and from then on everything worked fine.
Posted on May 09, 2009
SOURCE: thread keeps breaking
check to see if there are any burrs in that area
Posted on May 25, 2012
I've a Brother XL 3500 sewing machine and when I
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Apr 11, 2013 | Sewing Machines
Singer 8763 Needle Won't Go Up and Down
read the user manual and if you do not get anything from the trouble shooting section take it back for a warranty check as something may have moved from the material jam
Apr 12, 2017 | Singer 8763 Curvy
When sewing, the thread keeps pulling the fabric threads and the result looks messy. I've tried playing with the thread tension but it won't help.
have you tried using a new needle- if the needle is the slightest bet bent or or damaged it can cause problem with the fabric threads
if the needle is not the correct one for the fabric, it can move or damage the fabric threads
also clean under the needle plate for loose threads or lint also in the bobbin area
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
Good day!
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
Good day!
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Out of nowhere, after working fine for weeks, the bobbin thread started breaking, and then stopped "wrapping" properly around the outside of the bobbin while I sewed. It keeps jamming to where I...
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
Check tension 3 or 4 is usually good
after you try all this & it keeps jamming then it may need to be serviced
Nov 24, 2010 | Husqvarna Huskystar 215 Sewing Machine
How to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Jul 24, 2010 | Kenmore Sewing Machines
What does E-1 mean? My CS8060 Wont sew. It has been f ine but now is very stubborn. Ive tried to sew on 00 and 04, now it won't cooperate.
E-1 is an error. You've probably pressed the foot peddle without the pressure foot being down. That will cause me to get the E-1 error. If this isn't the case, turn the machine off and then on again--that usually clears any errors.
When you say the machine is very stubborn and won't cooperate, what do you mean? I've found my CS8060 is extremely sensitive to lint buildup--that will make my machine get screwy really fast!
Take off the guideplate, the bobbin case, unscrew the throat plate, and take it off. Now use your little brush and brush out all the lint down under there. Brush off the bobbin case, guideplate, throat plate, and as deep inside the machine as you can reach. Don't use canned air--that will push the lint deeper inside the machine. You may have to use long tweezers to get some of the lint out.
Generally speaking, whenever a machine becomes uncooperative, the problem is:
  1. the machine needs cleaning/oiling (but our Brothers don't ever need oil!)
  2. the threading is somehow off--rethread the machine completely, even if you've used the machine a gazillion times (top thread and bobbin)
  3. the needle needs to be replaced
  4. the needle and thread aren't compatible (not nearly as common as the other three possibilities)
Hope this helps!
Dec 21, 2009 | Brother CS-8060 Computerized Sewing...
Sewing Machines Logo
60 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
