Question about Dishwashers
I have a Miele Diamante G 2150 SCU Dishwasher problem. cleaned all filters,checked waterlines, drain pump, non return valve, spray arms, reset factory, have flashing light and no water in machine.
I believe the Celunol valve is shut and won't open any suggestions would be helpful. I have tried all suggestions on this page including cleaning and care in the manual pages 43-45 and factory default page 28
3 Suggested Answers
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
Daniel S
  • 4323 Answers
SOURCE: Miele Diamante G 2150 SCU
Hi
Plugged system or a jammed drain pump can cause these issues, also make sure the drain hose is not blocked. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance. Daniel
Posted on Feb 28, 2011
Dishwasher not completely drained and alarming
If this is an F11 mile dishwasher problem please do not make the same mistake as us and RECHECK the non return valve thoroughly. We had checked this before calling out the engineeer only to be charged 75pounds (as it was still under guarantee) instead of the normal 117pounds A tiny shard of pottery had become trapped, which my husband had not seen (when he took the non return valve out of the machine). After this was removed the dishwasher was fixed at an unneccessary cost of 75 pounds. A very expensive mistake indeed especially as we thought it was a pump problem and we had done everything by the book to sort the problem ourselves.
Feb 01, 2014 | Miele G 1472 SCVI 24 in Builtin Dishwasher
Our 2 year old Miele dishwasher (G1182/G2182) makes a strange popping/grinding glass noise when draining. We used 1 bottle of Finish Intensive care & clean with no improvement. Any suggestions?
there is a piece of debris in the drain pump. remove the triple filter from the bottom ( the one you are supposed to clean every week to keep debris out of the drain pump) under that filter and to the left hand side you will see the non return valve. squeeze the tab and pull the non return valve out. remove the broken glass or whatever is stuck in the drain pump impeller. replace the non return valve. replace the filter. if you need a picture go to mieleusa.com, and search for your owners manual. it has step by step tutorials on how to free an obstruction from your drain pump.
May 27, 2012 | Miele Dishwashers
Miele dishwasher drainage
there will allways be some water under the filter. when you remove the non return valve, there should be a rush of water coming back into the sump from the drain hose. if not, the seals in the non return valve are bad and you need a new part. they are not that expensive. switch to an appropriate detergent such as miele or finish all in one powerball tabs and the new part will last much longer. cascade and other brands are eating the seals in dishwashers faster than i can replace them.
Apr 03, 2012 | Miele Dishwashers
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Miele dishwasher finishes the cycle with water in the bottom and the dishes not clean
In the bottom of the dishwasher you have a filter. under the filter is a non return valve. it is a one way valve that keeps the dirty drain water from draining back into the dishwasher. if it is dirty or broken, the dirty water that your machine drains out, is running right back in as soon as the drain pump shuts off. this will keep happening and your dishwasher will just spray the dirty water back on the dishes over and over again.
to get to it, you will need to get the water out of the machine. if you have a wet dry shop vac use that. if not, you can bail it out with a cup, and soak the rest up with a sponge. remove the lower spray arm by pulling it up. remove the filter by pulling the handle in the direction of the arrow. lift the filter out of the way. get the rest of the water out of the sump. on the left side of the sump, you will see a silver wire bail holding the non return valve in. flip the bail towards the center of the sump. pull up and out on the non return valve. it has a rubber seal and a stainless steel ball inside. any debris between the seal and the ball will keep the valve from closing all the way, and allow the water to drain back. you can order a replacement if needed, directly from miele. 1800 842 7231.
Nov 19, 2010 | Miele G880 Dishwasher
I have a miele advanta g2170scvi dishwasher. it has three problems -- the top washing arm comes off its base every few washes; it doesnt clean well and there is an odor coming from the dw even tho i have...
Hi dear.Please do the following try to solve the issues.Please clean the bottom & upper spray arm.They must been blocked. That makes a lot of water pressure on top spray arm & it comes off.Also blocked spray arms resulting poor wash performans. With the odour,check the drain pump.It's non return valve.It should work properly.Also check for siphoning.That can cause bad odour.Please click the link below for meore help from it's user manual.Section: Cleaning & Care Page 42. I hope that helps.Thanks.
http://www.mieleusa.com/manuals_pdf/Residential/Dishwashers/English_manuals/Operating_Instructions/G1180_2170_2180_us.pdf
Jul 08, 2010 | Miele Advanta G2170SCVi Dishwasher
I have a Miele Inspira line dishwasher and it is making a horrible sounds when I turn it on - like the water is not getting through easily
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Apr 11, 2010 | Miele Inspira Series Dishwasher w/ 6...
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
F84 Error code Miele
This problem arises because the water inside the washer cannot get out.
Firstly......Make sure the salt cover if screwed on tightly (if you have one).
Then remove the filter(s) from bottom of the washer and clean.
Remove the drain pump cover and remove the one way valve (a ball bearing in a housing) and clean. Take note of rubber cover direction before pulling it out to clean.
Make sure the impeller (visible after you remove drain pump cover) is clean and spins ok. It will have a little resistance as you spin with your finger.
Make sure all is cleaned properly and it will all work fine again after replacing it all back in.
Jul 27, 2008 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
Owen Barnes
