Question about PRINTER Office Equipment & Supplies
I know very little about computers. How do I get my printer to print?
Cx5000 only prints headers why?
hello M,Nelson
I gonna need a little bit more information , but i supose it's a personal printer and you dont share it over your Network.
the solution is simple, close your printer and take the power cable off, after close your computer.
plug back the power cord for your printer and re-open your computer.
it's supose to do the trick. let me know.
look for the ink level, a simple way to notice if it is the printer or the computer the problem, try to print a test page.
Oct 21, 2016 | Office Equipment & Supplies
DO NOT KNOW WHAT PRINTER TO BUY FOR MY E-MACHINE COMPUTER
you can buy any printer you like. It will come with software that will install the drivers you need to operate the Printer. I reccomend Canon printers. They are a little more expensive than HP printers and others, but they are much better quality printers.
Nov 16, 2009 | Office Equipment & Supplies
How do I cancel previous prints.The printer prints old prints not the ones on the computer screen
Easiest way would be to open up the print queue and see if there's anything in there that needs to be canceled. If you have WinXP or Vista, it'll be a little printer icon own on the bottom right by the time. If that still doesn't work, reboot. If the reboot doesn't fix it, could be a driver issue which means reinstall the printer.
Sep 15, 2009 | Office Equipment & Supplies
Epson stylus 1400 printer
What kind of Port is the printer hooked up to? Computer should have usb port to printer. You also may be printing at 2800 dpi instead of the lesser quality with very little change in picture slower speed. Check those things and let me know if you've resolved the issue.
Mar 09, 2009 | Epson Stylus 1400 InkJet Photo Printer
The printer won't print.
problem with the pick up clean the pick up rubbers and something sucking in side can you tell me any folding end of the paper
let me know
Nov 09, 2017 | HP PSC 2510 All-In-One InkJet Printer
I need to know what connections i need to connect two computers to one hp printer
A 5 port switch (Hub) and network cables are about the simplest.
If the printer doesn't have a network port, you can add a small print server.
The print server is a little device the connect to the parallel port on the printer.
You then connect it to one of the ports on the switch (Hub)
Another way to share a printer is to connect the printer to one of the computers, and then share it. This is considering that you have the 2 computers networked together.
The drawback with this setup vs the first one, is that the computer that has the printer attached, must be on for the other computer to be able to print to it. The first setup, you only need to have the printer on, for either computer to be able to print to it.
Aug 16, 2008 | HP Office Equipment & Supplies
I am unable to cancel a waiting docment that i do not want to print
I shut my computer down unpluged the printer from the back of the computer then put it all back went to look on the computer to check that I had the right printer on the computer that is how I fixed it.
Feb 26, 2008 | Computers & Internet
I need to change to size of the print
When you are ready to print, go to the option above print, called page setup. Change the scale to about 150%, just experiment with that and it should help. There are other options in print preview that will let you change the size, but I would go with page setup. Hope that helps
Feb 21, 2008 | Video Game Consoles & Games
You have to change the size within the computer software (word?). Use a 11 or 12 size and arial or times as a standard. The mfc prints the job as given by software (with settings given by user).
Nov 27, 2007 | Brother MultiFunction Center MFC-440CN...
26 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Roger Knight
Roger Knight
Level 1 Expert
R Daniel Wolfe
 Andrew Henderson
Andrew Henderson
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
