Question about Seiko Watches
I need a bezel insert for my seiko 7t62 0lc0 where could i get one
How to remove the bezel insert
Hi Tim:
Seiko watches are fairly valuable. I've had one of the dive watches for close to 40 years with zero maintenance needed.
Unless you really know what you're doing, if it was me, I'd be taking it to a really watch repair person.
It's worth it, unless the watch is of no value to you.
But that's just my opinion.
Cheers.
Jan 22, 2016 | Seiko Watches
Where is sell the bezel of seko kinetic SQ 50?
The bezel is available through any certified Seiko dealer, though I would suggest using one with a Certified Master Horologist on staff.
Thanks for rating! Expert watch repair for Rolex Breitling Tag Heuer Movado
Jun 23, 2014 | Seiko Kinetic watch
How to get bezel for seiko SQ 50
All parts can be purchased by phone from the Seiko New York call line. They are extremely helpful and get your part as soon as it is available. This is the TRUE Seiko parts line - NOT an off brand. I have used this call line numerous times over the last couple of decades for my husbands Seiko watches. the phone number is:
(201) 529-5730 If they cannot get it no one can!
Need help identifying watch
Take it to a local jeweler and they will tell you all about it for free.
Search Results
How to tell when your Seiko watch was made (Part 1)
quartzimodo.com/how-to-tell-when-your-seiko-watch-was-made-part-1/ Sep 21, 2010 - If you can't see the serial number on the glass, then look for them on the caseback ... Every Seiko watch manufactured is given a 6-digit serial number. ...... Your old Seiko watch is likely to be from the Seiko Sportsmatic or the ...
WatchSleuth - Seiko Date Finder
www.watchsleuth.com/seikodatefinder/ Seiko Date Finder - Find out when your Seiko watch was made. ... In the example images the serial number is highlighted in blue. Every watch has a unique combination of reference ... the watch was made. Looking at the example images:.
Watch Finder ' Seiko
www.seiko.com.au/collections/seiko-watch-finder Watch Finder. Seiko Watch Finder ยท Seiko Clock Finder. Search by Model Number. Collection. - Any -, Grand Seiko, Astron, Prospex Platinum, Prospex, Presage
images below
older seiko watch with dubai australia chicago on bezel Google Search
Jul 31, 2017 | Seiko Watches
The black plastic ring, w/ white markings (bezel ?), that goes on the metal (dial) which moves around, fell off. Is this part avail., and if so, for how much ?
This part is called the bezel, you are correct. They are available to buy as a separate item for certain watches, but not all. You didn't mention what type of watch it was. Most major brands, like Rolex, Omega, Tag Heuer etc all sell bezels for their watches, brands though like Diesel, Rotory, Seiko etc, do not sell bezels as a stand alone item. Should you wish to let me know the make and model of the watch, I will see if I can obtain one, or failing that I will see if I have one that will fit.
Apr 24, 2010 | Casio Marine Gear AMW320D9EV Wrist Watch
I need a replacement-part of a bezel insert-ring for a Rolex
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 22, 2010 | Rolex Yacht-Master 16628 Wristwatch
Taking the glass from my watch
Rolex glasses are held in place by the bezel ( ring surrounding the glass ). Bezel must be lifted off first in case if the glass must be removed. Rolex bezels are friction fitted and are very tight. Usually special tools are used for bezel lifting, but in skilled hands the watchmakers knife can do the job as well (inserting the blade between the bezel and case and slowly prying up all athe way around).
In most cases the bezel still holds the glass when lifted off the case. To release the watch from bezel ring you will need a special press with dies as you will need it for refitting glass and bezel on to the case.
I would advice to find your nearest watch repair shop and ask for help, because without proper tools it is allmost impossible to remove and reset Rolex glasses without damaging them.
Do not forget to rate, please.
Jan 21, 2009 | Rolex Submariner 16618 Wristwatch
Replace bezel for omega seamater
I would recomend taking it to an independent watchmaker. It should only be $15, $30 to make the change.
Most bezels are pressure fit. Using a small jewelers knife to pry the bezel from the case is how most bezels are removed.
My friend is a watch maker and he has a special tool that removes the bezel however he told me he only uses it when he has customers watching. Because the old knife looks pretty brutial, but works better.
Dec 27, 2008 | Omega Seamaster 2541.80 Wrist Watch
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Apr 27, 2008 | Seiko 0512039FA Wrist Watch
Watches Logo
27 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
