Question about Honda Electrical Supplies
I have a honda ex 5500 generator that keeps triping the on and off breaker to the outlets what could it be
    Scholar:
    New Friend:
  • 101 Answers
Hi there. 1) Remove all loads and start up.2) Connect a known working load and if it trips on a load too small then the tripswitch is faulty and must be replaced
Posted on Feb 07, 2018
    Sergeant:
  • 257 Answers
Sir it appears that you have a voltage overload in your generator once you find where the old load issue is you'll be able to solve your problem
My car won't do anything when i turn the key on
CarlGehrke
  • 169 Answers
SOURCE: North Star 5500/ lost one leg of the 220v
Small generators like this almost always have 2 stator windings 180 degrees out pf phase, that's how it makes the 220.
At the back (maybe side) of the outlet box should be a molex type plug that has the wires from the stator, get an ohm meter and measure them (with the generator shut off of course). You should find that you've got 4 wires in the plug, 1 wire for each end of 2 coils. From one end to the other of each coil you should measure less than an ohm, between the coils there is usually no connection, but some models have the neutral ends of each coil connected together inside the generator housing.
It sounds to me like you've got one of the power windings open...
Carl
Posted on Dec 05, 2008
CarlGehrke
  • 169 Answers
SOURCE: Honda EM 2500 Generator
I posted a general tutorial on troubleshooting this problem here.
Rate me?
Carl
SOURCE: Honda 5500 Generator
If you have checked the stator, rotor and brushes and they appear alright then it is probably a voltage regulator. The honda dealer can run a test and confirm the problem at very little expense. It cost me 25 dollars Canadian to preform the test and it was well worth the money because you cannot return electrical parts and they can be very expensive. Have a great day!
davedulmage@sympatico.ca
Posted on Aug 14, 2009
  • 5603 Answers
SOURCE: Honda motor runs fine but will not generate power
try this site:
http://www.endtimesreport.com/dead_gen.html
Posted on Nov 02, 2009
  • 12 Answers
SOURCE: RGH 5500 IE never used.
check to make sure your spark plug is clean and that your rpm is set right. if the rpm on the engine is not right it will not put out the right current and you will burn something up. take a lamp with 100 watt or higher bulb or an old power too and plug it in and turn it on and see if the motor speeds up. if it dosent then you have a rpm problem that could be as simple as the sparkplug or gas to the governor not letting the engine speed up. both are simple fixes. if the engine does speed up then you have either an armature problem or or a regulator problem. if it has never been used then it may be under warranty and should not cost nothing to repair it.
Posted on Sep 08, 2011
Tip
Generator runs great but produces no power
On Thursday last week I had 220 amp outlet being used and a 110 amp outlet being and overloaded the generator. It turned out to be the reset breakers failed to trip and blew the capacitor. The reset breakers I would suggest replacement after 7 years very easy to do on a 5500 Valsi generator 2010 model still running and now producing electric. And of course use only regular gas non Ethanol.
on Aug 19, 2015 | Electrical Supplies
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Breaker keep triping on screen light shows P-06
Is it tripping under load? or not under load. If it is under load have breaker checked and unit tested on a load bank. If it trips under no load check for wiring shorts on the main AC lines to the plugs
Oct 02, 2013 | Kipor Electrical Supplies
Breaker keeps triping
Did it work trouble-free before?! Is it on its own circuit?! Are you sure breaker is of appropriate rating?!
Jul 09, 2012 | Refrigerators
I have a Kenmore model 20802990 washer, it will run for a short while and then stop working, it is almost as if the circuit breaker trips because when I turn the circuit breaker of then back on and switch...
well you right in saying "its triping the braker off" thats what it is doing,,
there is a problem with the washer motor,,its pulling far to many amps so its a fulty motor,,,and it will just keep triping the trip out,,,
its a good job you have trips,,the motor could have gone up in smoke
Jul 15, 2010 | Kenmore 24032\24036 Top Load Washer
Honda ex 650 genorator carburetor not getting any fuel, and wont stay running
check the fuel filter and the fuel shut off to see if they are clogged
Jun 22, 2010 | Master Heaters MASTER HONDA POWERED...
Engine runs but no electic power,breaker are not triped any advice joe
i would look into the voltage regulator it may have fuses blown not sure on this particular model though
Oct 07, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Electrical Supplies Logo
51 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
