Question about Bulldog Remote Starter & T-Harness Kit for 99-03 Oldsmobile Alero; 97-99 Ol
Temperature gauge is rising to high
At first my temp. was always at 200 I recently had my radiator replaced and since then my temp gauge will fluctuate between 200 and 260. I took it in to the shop and they say everything is with in limits. My fan kicks on but I still think the temp rises too much. I also notice I am loosing water now. So I thought the rise in temp was because I lost to much water. Well I made sure the level of water was correct and my temp still rises. Could it be a bad water pump. Not pumping all the time?
  • 344 Answers
When you remove your oil cap is there foamy **** on the inside of the cap, if so you may have a crack in one of your gasket
Posted on Jan 25, 2010
  • MECP Guy
    MECP Guy Jan 25, 2010
    when you remove your oil cap is there foamy **** on the inside of the cap, if so you may have a crack in one of your gasket
The heat come on and then goes off and also the needle goes up to hot and come back down
Engine Temperature Issue - Please Help! - Mazda 6 Forums : Mazda 6 ...
forum.mazda6club.com > ... > Mazdaspeed6
Sep 12, 2011 - Join Date: Mar 2006 ... to the gauge) and then after being shut off for 5 minutes, show COLD. ... I'll also confirm, with my AP, that my ECT is around 200 like it normally is. .... VSS, and ECT signals and calculate radiator's heat the radiation ... I noticed my engine temp needle was dipping down and then came ... CEL - Throwing code P0126 (Insufficient Coolant Temperature ...
Nov 18, 2013
Temp gauge needle
Mar 14, 2013
overheating problems
Jun 5, 2010
Temperature Gauge
May 22, 2010
More results from forum.mazda6club.com
Temperature gauge going up and down - CarGurus
www.cargurus.com > Questions > Infiniti > I30
CarGurusAug 20, 2014 - Also as my temperature gage rises but car does not overheat. ... tempneedle gets up towards the red mark while you're driving, then yes, ... i have a 2006Pontiac Grand prix and my temp. goes up to the ... crzgrl637 answered 6 months ago ...the cooling fans won't kick on then you will see gauge over heat.
Car Engine Overheating - Causes and Symptoms of Over ...
Jan 17, 2016 | 2006 Mazda 6
My engine overheating problem is in my 2000 land rover. The fan is running and the electric fan comes on at correct engine temperature. After start up the engine runs normal the temp gage rises slowly to...
the usual suspects are:
stuck shut thermostat
clogged raiator
dead water pump
low coolant level
it's sunday, rovers don't work on sunday.
Then again, maybe its wednesday, rovers take half a day then. 25322555-21syibu3fgwpdxocjnkpw0ib-5-0.jpg
Dec 15, 2014 | Cars & Trucks
1993 toyota pick up temperature gauge problem
Or the thermostat might be faulty which raises the temprature at which the thermostat starts to open. Giving a high reading on the gauge. if it gets too hot you might be at risk of blowing a pype or head gasket. If so replace thermostat. Check for a loose wire to the temp sensor as well. See if the radiator fan turns on when temp rises. If not check a fuse or the radiator fan temprature switch might be faulty.
Oct 19, 2014 | 1993 Toyota Pickup
Is it normal on 94 grand prix 3.1 for the temp. gauge to NOT stay at a steady temp. all the time? mine seems to go up to 210 at a stop light then go back down after i start rollin again, i just had air...
Have you checked your cooling fan to see if it is working propely? Let the car idle and get warm and listen for the fan to kick in (if they are electric) or just watch to see if the fan starts to spin faster if it is the old school type with a clutch. Have you replaced the thermostat? A bad one will let the temp rise since it opens too late and then the temp will drop off. But it won't due this only at a light and it will do it infrequently.
Apr 18, 2013 | 1994 Pontiac Grand Prix
2004 Impala ls temperature dash gauge
fans came late on those car,like 212 and second fan comes on at 224,you reprogram it to come a lot sooner,,other thing is there might be gunk inside the block,and coolant has hard time to pass through,and staying longer than enough in block temp goes high,even tough the radiator is doing it's job,it is just coming out block lot hotter than it suppose to be,and gauge read the block not the radiator
Apr 18, 2017 | 2004 Chevrolet Impala
Cooling system problem for Pontiac Grand Am GT 1999, Starts overheating when sitting still but starting the A/C helps cool it.
If it has an electric radiator fan (not AC fan) The radiator fan is not working. Possible coolant sensor or switch.
Apr 02, 2017 | 1999 Pontiac Grand Am GT
Car revs up on its own, and also the temperature gauge never rises. it is always on zero.
If temp. guage never rises...most likely the radiator thermostat is stuck in the open position, therefore always running coolant thru the motor. Kills your gas mileage, because the engine is always running cold. And you won't get much heat when you turn the heater on. If this is so, have the thermostat changed.
Apr 01, 2010 | 2000 Dodge Intrepid
My 94 Tracer temperature gauge reads between 3/4 and 7/8 in the normal range before the radiator fan turns on. I have already replaced the fan temperature switch and the relay. Could my temperature...
Yes, it is possible the temp. sender is faulty, but I would do a cross check of the actual coolant temperature vs gauge reading using a cooking thermometer in the top of the radiator.
Take care not to get scalded - check it at about 180 to 200 deg.
Aug 02, 2009 | 1994 Mercury Tracer
1990 Corolla Cooling system problems
Your temp gauge reads low on the highway, and one-half in the city?
You need to replace the thermostat. It is sticking open.
Driving at highway speeds, the blast of air that the car is cutting through enters the radiator, thusly cooling it, and the coolant inside the radiator... In town, with the lesser amount of air being forced into the radiator, (slower speeds), the coolant temperature rises. Replace the thermostat, and you will be OK.
Dec 11, 2008 | 1990 Toyota Corolla
Bulldog Remote Starter & T-Harness Kit for 99-03 Oldsmobile Alero; 97-99 Ol Logo
95 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
