Question about Health & Beauty
Does the altitude of 4000 feet has affect on someone with low blood pressure?
  • 36 Answers
I am not a doctor but I can tell you that at 4000 feet there is about 87% of the oxygen compared to sea level. High altitude is usually defined as 5000-11,000 feet. High altitude actually increases the body's blood pressure.
Posted on Dec 10, 2016
What to eat to raise blood pressure
nothing to eat unless you want to clog up the heart but dehydration or lack of regular water intake affects blood pressure
talk with a doctor as you need to fully understand "blood pressure" and what it means in the body
Low blood pressure readings are normal and it is the high pressure readings that are dangerous
Again talk with a doctor to be correctly informed and what your particular blood pressure readings should be
Jan 06, 2017 | Health & Beauty
Tip
?JCB FAULT CODES LIST
P0087 (flashing code 227) shared sump low pressure fault (for pump without pressure supply)
The main fault symptoms
• Engine severe vibration.
• idling unstable
• Output Fall
• exhaust smoke
• It may be too large output
P0088 (flashing code 118) shared the tank pressure is abnormally high (first or second stage)
• idle instability
• Output Fall
• channeling gas engine failure
• exhaust smoke
P0089 (flashing code 151) shared the tank pressure failure (for pump pressure supply is too large)
• idle instability
• Output Fall
• exhaust smoke
P0090 (flashing code 247) SCV drive system open, + B short circuit or shorted to ground
• Depending on the open / short situations, there may be an engine stall and / or launch
Machine channeling gas.
• exhaust smoke
• Output is too large
P0107 (flashing code 71) atmospheric pressure sensor circuit input low (open or shorted to ground)
Due to spare the equivalent altitude 2000 m (6562 ft)
• exhaust smoke at high altitude.
• insufficient output at low altitude
P0108 (flashing code 71) atmospheric pressure sensor circuit input high (+ 5V shorted)
• The high altitude exhaust smoke
• lack of low altitude output
P0112 (flashing code 22) intake air temperature sensor fault (low voltage fault, earth fault, short circuit)
• When cold starting, may exhaust white smoke.
More here http://truckmanual.weebly.com/jcb-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
Low diastolic pressure for what reason
That paper coined a new term, "isolated diastolic hypotension," which refers to a low diastolic blood pressure (less than 60 mm Hg) and a normal systolic pressure (above 100 mm Hg). Older adults who fit those conditions are at increased risk for developing new-onset heart failure, the researchers found.17 May 2015
UAB - The UAB Mix - Diastolic blood pressure: How low is too low?
https://www.uab.edu/mix/stories/diastolic-blood-pressure-how-low-is-too-low Low diastolic pressure for what reason Google Search
Dec 13, 2016 | Health & Beauty
What causes low blood pressure?
Some of the causes of low blood pressure are:
1. Genes- Low blood pressure can be genetic.
2. Aging- Aging can also cause low blood pressure, as the age increases blood pressure can either increase or decrease.
3. Medication- Some types of medication is also responsible for low blood pressure.
4. Dehydration- Low blood pressure can also occur due to fluid loss in our body.
Oct 19, 2016 | Health & Beauty
Recommended fuel pressure in psi for geo metro 1.0 l
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem. Best Manuals
Aug 01, 2016 | Geo Metro Cars & Trucks
Screen is black after sleep
Changes in elevation affect the body when going from a low altitude to a higher one. This can cause a number of problems because of differences in air pressure, temperature and oxygen levels. Preparing your body for a change in altitude helps it acclimate and keeps you safe, while out in the elements. You can protect your body by getting physically fit, dressing appropriately and keeping yourself properly nourished. Elevators
Mar 10, 2013 | Health & Beauty
What kind of health problems are caused by being very overweight? My dad has put on so much weight in the last few years and I am worried about him.
Being overweight has been linked to a number of health issues including;
- High blood pressure
- Heart disease and stroke
- Diabetes
- Cancer
- Gallstones
- Gout
Feb 20, 2013 | Health & Beauty
Alti does not read correct alti.
Don't forget that the altimeter is barometric, and therefore the altitude reading will change depending on the air pressure - i.e. the weatherman may give the 'high pressure coming through' or that there is a low pressure giving rain - to get the true altitude, you need to know the true air pressure at any given point on the earth ~(where you are) then set this as the 'normal'. you will then get the correct altitude. Don't forget that if you are in a pressurised aircraft - as in allcommercial flights, the cabin air pressure is artificially kept at appx 4000-6000ft altitude
Dec 02, 2008 | Casio PRG-40T-7 Pathfinder
WHAT WOULD BE CONSIDERED LOW BLOOD PRESSURE?IS IT NORMAL FOR MY TOP NUMBER TO CHANGE FROM 104 TO 129 IN ABOUT 5 MINUTES?
There are standard methods for measuring BP. One should be seated on chair, feet on ground, leaned back, relaxed for at least 5 minutes, at least 2 hrs after a meal, .... then repeating this procedure several times daily, and averaging will provide some ave daily BP value.
Using this procedure for hourly BP measures, one can adjust times and doses of BP medicines taken daily.
Nov 12, 2008 | Omron Healthcare 2007 Hem 711DLX Automatic...
Incorrect altitude changes
Here is the link to the user manual for this watch if you need it; http://www.lacrossetechnology.com/k2100/manual.pdf page 12 gives you all the contact details for lacrosse. I couldnt find the info online to be sure, but some of these watches do have a separate pressure sensor for altitude and barometric pressure, and sometimes the path to one could get blocked or it could become faulty. I would contact la crosse and find a dealer to get the watch serviced, you could probably do it yourself but you need to get replacement seals from them anyway (these are important). ask them to check if the sensor is clogged, it happens sometimes. Hope this helps :)
Jun 18, 2006 | La Crosse K2-100 Wrist Watch
Health & Beauty Logo
62 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
