Question about LG 42LG50 42 in. LCD HDTV
How to replace a tcon board on a 42lg50 ua tv
I have the board exposed, how doy you release the ribbon cables
  • LG Master
  • 6,694 Answers
Check the Vidoe
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 10, 2017
lovejoy91
  • 691 Answers
SOURCE: has sound but no picture. lg 42lg50-ua. I have
Only Dlp have bulbs could be main logic board
Posted on Dec 06, 2010
  • 8457 Answers
SOURCE: BROKE OFF THE CABLE INPUT
Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.
Posted on Jul 12, 2011
caroldon
  • 17130 Answers
SOURCE: lg lcd can a bad tcon board kill all power
Yes , it can be a short on the board that will ask the SMPS unit to protect the power so as to switch off. So even with a multi-meter check you will be able to trace the short on the board, the drivers or any capacitor that is cutting off the power which must solve the issue.
Posted on Dec 15, 2011
SOURCE: lg263000
It could be a bad T-con, but it could also be a faulty LVDS (cable that connects the t-con to the main board), or you can have a main board fault. It sounds like your panel isn't getting power. The T-con board should be located top center on the backside of the set. It should be housed under a metal cover. BEWARE, some panel have the T-Con built into the LCD panel. If this is the case, you will have to replace the entire panel if the t-con is bad. Simply go to www.shopjimmy.com, and type in you actual TV model # in the search box. This will bring up all the parts available for your model. The results will also bring up pictures of the parts so you can see exactly what they look like.
Posted on Nov 24, 2012
Testimonial: "Thanks for the valuable info and your quick response!!"
gopakumarg43
  • 74887 Answers
SOURCE: How do I know which part to replace in my LCD TV...is it the backlight or t-con or main board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Posted on Sep 23, 2015
How do I fix my Samsung Tv.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 19, 2016 | Samsung Televison & Video
My tv model# 37lg50-ua. I have a dim picture black and gray
The TCON board or the LCD panel is faulty. You have to replace the TCON board to confirm. In some models TCON boards are integrated to the LCD panel if so you have to go for a new LCD panel.
If you wish to get some details; check the site linked here. Pull up older posts.
May 24, 2016 | Televison & Video
I have a 55" Seiki flat screen t.v. and after the movers moved it from my old home to my sisters house all of a sudden there is a vertical line that will not go away
It is definitely loose connection of ribbon cables connected to the TCON board.
See how to identify the TCON (Timing and Control board) and how handle the delicate ribbon cable
There are hundreds of video to help you identify the defects and parts if needed
May 13, 2016 | Seiki Televison & Video
Tv flicks after a couple of mins after being turned on
The tcon board of the LCD panel is faulty. Can confirm by replacing the Tcon board.
Apr 09, 2016 | LG 42LG50 42 in. LCD HDTV
Half of my screen goes out from time to time. how do i fix that.
This is likely a problem with your TCON circuit board inside the back of the tv.
The TCon board usually has 2 very thin ribbon like cables running from connectors on the board to the actual LCD screen panel. Each ribbon controls one half of the screen. If you are lucky, it's possible one of the ribbons came loose or is not making proper electrical contact with the connector on the TCON board.
If your tv is out of warranty and you are comfortable working safely with electronics then you may be able to repair this yourself with a few hours of screwdriver work. The ribbons may just need to be reseated in the little flip up connectors, or you may have to clean the copper at the tips of the ribbons gently with a pencil eraser to remove any oxidation.
If you are unlucky enough to have a bad TCON board or are not comfortable disassembling your tv yourself then you can bring it in to the shop and they can probably repair it for less than $150.
Good luck and please post back if this helps and with how you make out.
Jan 25, 2011 | Olevia Televison & Video
Only right half of screen shows
If this problem affects exactly half the screen, then there is likely a problem with your TCON circuit board inside the back of the tv.
Good luck and please post back with how you are making out.
Jan 24, 2011 | Westinghouse LTV-32w3 HD Television
I have a Sony Bravia 32" and half the picture is
Good luck.
Jan 20, 2011 | Sony Televison & Video
Samsung ln52a650
This is called the LVDS cable.........try Encompass parts.com they are samsung distributor........shopjimmy.com has salvaged sets where you can buy the cables and ribbons for a given model as a set
Jun 02, 2010 | Samsung Televison & Video
LG 42LG50 42 in. LCD HDTV Logo
62 people viewed this question
Computer Repairing
Computer Repairing
