R & L are for the audio left and right and then Y is the green port and this carries the luma brightness signal, PB is the blue port that carries the signal between luma and blue and PR is the red port that carries the signal between luma and red. Your component cable should be color coded to match.
If you need further help, reach me via phone at https://www.6ya.com/expert/marc_162a3912222e83a4
The 1300 prints spot colors the same way as the other ALPS printers. To print spot colors, create a mask or layer using only black with your artwork. Select the spot color you want and the black areas on the mask will be printed in the spot color. Make sure that you check the overlay box so the printer retains the printer. You also need to make sure you are using the ALPS printer driver supplied with the printer and NOT the default Windows plug and play driver.
