Question about Philips Health & Beauty
The Philips shaver S1510 dry electric shaver wont charge up what is wrong with this shaver
  • 14 Answers
SOURCE: wet/dry Panasonic shaver stopped
My model is almost the same as your model ...
Problem: Model ES7037CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg 12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
Posted on Dec 27, 2008
SOURCE: Electric Shaver will not charge
There are 4 small philips head screws deeply recessed on the rear of the razor. Unscrew these and the back half of the case just lifts off. Unsolder the battery leads and fit new battery pack.
Posted on Mar 21, 2009
Cytherian
  • 124 Answers
SOURCE: charge
How long have you had the shaver? If it has been a couple of years, then it sounds like the batteries are exhausted.
The batteries can be replaced, although it's not as easy as changing them out of a flashlight. There is a way to disassemble the shaver and change the batteries. They are soldered in place at two basic points. If you obtain replacement batteries (on eBay you can get them for about $12 a piece), you can perform the replacement yourself:
Opening a Braun 7000 Series Shaver
1) Find a thin metal object with no sharp edges (such as a nail file). Use your thumb and pull on the bottom end cord socket part, enough to cause a gap between it and the back shell. Insert the metal object into the gap in the center of the part. THEN pry it off. If you use a regular screw driver, you will likely cause gouges in the plastic. And the best leverage is in the center.
2) The silver side parts are held on by two tabs at the top. With the bottom piece gone, the side parts swing off easily. Don't worry about keeping track of which sides the silver trim pieces go on, as they're designed to fit on only one side (you'll see the cutout for the shaver head stem is off to one side).
3) The case is held together by 4 small torq screws. Use a torq screwdriver--do not attempt to do this with anything else. Be careful to turn the screws slowly, so you don't strip them.
4) With the screws removed, the two halves of the shaver will come apart. The remaining parts can be extracted without any special tools. Keep note of how they are removed, as assembly will be the reversal of removal.
5) Note that if you are replacing the batteries (there are two of them), you will need a soldering iron to detach them from the circuit board, unless you're replacing the whole part.
6) Reassembly is pretty much what you expect--the reverse of disassembly. However, the bottom cord socket part is tricky to get put into place. Pushing straight down on this part will not get it to go in, nor any other obvious way. It's best to get the prongs inserted on one side, then while pushing in on the prongs of the opposite side, apply pressure on the top side surfaces. The part should snap right back into place.
Posted on May 23, 2009
VtToolMan
  • 704 Answers
SOURCE: Braun electric shaver will not charge.
Your batteries are no longer capable of being recharged and need to be replaced.
If you are handy and can dissemble and solder, you can do this yourself, otherwise, you can send it off to a repair service that will do this for you.
If you wish to do this yourself, you'll have to take the shaver apart. There are two (2) small plastic caps on the bottom of the shaver that can be removed with a small pick or flatbladed screwdriver. Once those are out, you can unscrew the two screws that hold the shaver together and gently pry off the side panels.
This will expose the internal circuit board and the rechargable batteries that need to be unsolded. You can then reinstall NEW rechargable batteries and solder them onto the PCB (printed circuit board). You can also purchase a complete internal PCB with the batteries and everything you need, you just swap out the electronics for the new one, although this costs about $39, while the batteries alone are much less.
Put the shell together and reinstall the retaining screws and caps and you're done.
Here's a link to get the replacement batteries for your shaver. They also do the repair service, if you don't want to do it yourself.
http://www.electricshaverstore.com/search.asp?p=1&w=%5F&c=battery&t=s
Hope you find this Very Helpful and best regards!
Posted on Sep 11, 2009
SOURCE: My shaver is a Philips HS8000, the shaver does not
I have a Hitachi RM8600 rechargeable shaver. It is charging well but suddenly stopped working. Motor doesn't run now.
May I know a service center here in New Delhi?
Posted on Apr 14, 2011
To charge
Men\'s Grooming / Norelco
1-800-243-3050
Monday - Saturday 9:00 AM - 9:00 PM EST
Sunday 9:00 AM - 6:00 PM EST
Excluding Major Holidays
good luck
Apr 19, 2014 | Philips arcitec 1060 Electric Shaver
When the "Philips Senso Touch 2D" electric shaver is fully charged should the charger be turned off
It is not advised that you leave the shaver charging after it has fully charged.
Apr 17, 2013 | Health & Beauty
When I charge my Braun it does not charge.But sometimes it charge. I do not know what to do
i have series 3 wet and dry braun shaver when it ison charge it only sends ared light to show on grip never it blue charge what is possibly wrong
Feb 23, 2011 | Braun 4775 Smart Control3 Razor Series 3...
I lost my Philips Coolskin 7775X shaver charger.
philips norelco 4222-039-10972 adapter charging cord for electric shaver norelco 7775x power cord replacement parts.
Oct 23, 2009 | Philips Health & Beauty
Not charging
Here is a link to the owners manual for the HQ7785 Electric Shaver. If this is the wrong model, your manual may be listed at this site as well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
Apr 15, 2009 | Philips Philishave HQ7782 Electric Shaver
Red warning light
Apr 06, 2009 | Philips Philishave HQ7782 Electric Shaver
Shaver head warning light
Mar 06, 2009 | Philips Philishave HQ7782 Electric Shaver
Health & Beauty Logo
59 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
