Space heater not working am I suppose to add someting to it or why is it not working
Garrison tower heater model 043 5961 0 manuel
What can I do if the thermal Fuse has shut down permanetly. is it someting I can fix on my own? The heater is the ceramic tower heater.
May 25, 2013 | Water Heaters
Fixya com
Copy following links for draining and flushing gas and electric water heaters:
http://waterheatertimer.org/Water-heater-will-not-drain.html
space line
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
Add a comment and describe what you are doing
May 10, 2013 | Water Heaters
Add zero start engine heater to e450 7.3 cargo van.
i would like to ask that , why you try do that .
Nov 07, 2011 | Cars & Trucks
Is the front of the fuel powered heater supposed to glow red?
Hi, and the answer is yes. All fuel powered type heaters will glow red, or bright orange. Example, a space heater that runs on #2 fuel oil, natural gas, gas, kerosene, ect. will glow this way, so do not be alarmed. This is normal.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jan 04, 2011 | Dayton Heating & Cooling
Does the blower and the fuel pump suppose to run at the same time?
well if your talking about the fan at the front and the pump on the back of the electric motor then yes they are supposed to run at the same time.... they are both attached and ran off of the electric motor
Dec 26, 2010 | All-Pro Forced Air Kerosene Space Heater...
Heater blowing cold air light on heater flaseing 4 times says someting about limit switch
the limit switch works on temp rise and temp fall , limit switch could be dirty on the sensor clean this and see if this hepls
Feb 09, 2010 | Heating & Cooling
Hello, I have a Lakewood space heater, Model # 792/JR, and one of my kids tried to dry her shirt by placing it over the heater and now it comes on but doesnt heat up. Can this be fixed?
The heater "over-heated". It's supposed to have a safety cut-out. The question is, can it reset itself? If there is no manual reset button on it, leave it unplugged for 30 minutes or so. If it still doesn't work, spend $20 on a new one.
Jan 19, 2010 | Lakewood Engineering&Manufacturing PHT150...
Add line thermostat to fahrenheat space heater
Just disconnect the other thermostat. You can leave it there just disconnet the wires
Nov 30, 2008 | Marley Electric Hydronic Baseboard Heater,...
Free space?
Try formatting the flash drive
Jul 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
