Question about Canon PIXMA MP160 All-In-One InkJet Printer
Looks like a litle belt has come off ink cartride loader--how do
How do i put belt back on or where can i find a diagram?
  • 28 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-26
Posted on Sep 04, 2009
You arent happy......so keep pretending
Posted on Jul 25, 2009
Error 5...ink cartridge is not recognized after refilling
Clean the contact point of the cartridge to the printer before placing it, then **** some ink in the cartride by a cyringe to lessen the level of ink inside the cartridge. full ink cartridges encounter this error because the absorver inside the cartride overflows.
Mar 28, 2011 | Office Equipment & Supplies
Why it can't print?
It won't print if your ink cartridge is empty. Check the black and white and also the color cartrides by doing the following:
1. Slide your hand underneath the front cover and open up the case.
2. Find your ink cartrides usually located on the left on the inside of the casing.
3. Gently pull up (usually) on the cartridge and take it out and shake it. You will know if it is empty or full when you shake it. If the color is full but the black and white is out that is probably the problem. Many printers won't work if the black and white cartridge is empty because that's usually the primary color.
4. Go to Walgreen's or a similiar store and purchase a new cartridge and then just reverse the steps putting it back in. Make sure you take note where each cartride is located when taking them out and put them in their correct position when you put them back in.
This should solve your problem and you should be printing again in no time flat!
Dec 22, 2010 | Epson Stylus Photo R390 InkJet Printer
Even though I have install the ink cartride
Hi there please try this.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 01, 2009 | Dell 924 All-in-One InkJet Printer
Priter probblems
First, try removing and installing inks again, after that try updating FIRMWARE. Use this site www.kodak.com/go/downloads
Oct 19, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Help.... System error 09,036.44:11411
That is a magenta ink stick advancement failure.Look in your ink loader and see why the stick is notr advancing. It may be cracked, twisted or somehow just stuck. That code is telling you the ink stick is not advancing downward into the ink loader.
If you put in ink from a different phaser model, it will not read it either. To remove them, take a screw, like a drywall screw and twist it into the ink stick and back it out, then reseat the ink blocks.
Sep 22, 2008 | Xerox Phaser 8560MFP Laser Printer
Phaser 8200 printer error service report 09.008.43797s
The black ink sticks are jammed.
Open the ink loader and ensure that the black ink sticks are able to slide in the ink loading chute. Remove any broken of partial ink sticks.
One of your black sticks is not advancing properly.
Make sure one isnt cracked or twisted. If you happened to have put in a stick for a different phaser model, it may not be the same shape and would not hut the actuator at the bottom of the ink loader.
Raise your cover where you add your ink sticks and look at the black sticks. One is stuck somehow.
If you need to remove them, take a screw, a drywall type screw is best, and twist it into the ink block and slide it up and out, then reload the ink loader with good sticks. That shoulf do it. I ihave never witnessed the ink loader itself be the problem.
Sep 15, 2008 | Xerox Office Equipment & Supplies
How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
May 20, 2008 | Washing Machines
CAN THIS PRINTER BE REPAIRED?
37,009.45 All Ink Melt Heaters are drawing less power than expected.
Thats what you should get with the ink loader unpluged.
The 09, coded have to do with the ink loader but may not in and of itself be the ink loader.
Here is the documentation.
arrwup.gifInitial Action
  • Check that the Ink Sticks are genuine Xerox.
  • Check for obstructions in the Ink Wells.
  • Check the Ink Loader data ( P/J0150) and power ( P/J5) connections.
  • Verify the Ink Sticks advance in the Ink Loader.
  • If the problem persists, follow the procedure below.
Table 2. Process Drive Faults 9,0XX.4x Troubleshooting Procedure Step
Questions or Actions
Yes
No
Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Are the Ink Sticks loading properly?
Go to Step 2.
Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. This must be performed following an ink loader replacement.
Test the appropriate Ink Melt Heater.
Run the Service Diagnostics Ink Melt [1,2,3,4] test.
  • 1 = Yellow
  • 2 = Cyan
  • 3 = Magenta
  • 4 = Black
Did the test pass?
Replace the Printhead ( REP 2.0.2).
Replace the Ink Loader ( REP 2.0.1).
Apr 21, 2008 | Xerox Phaser 8500/DN Printer
Xerox phaser 8400
Replacing the pring head.
1. Remove the side covers.
2. Remove the ink loader assembly. There are 2 connectors on the ink loader. SO remove it slowly.
3. Remove the spring guides on the print head. One on each side, Held in my one torx screw.
4. Remove the spring bracked assembly on the left side of the printer, it puts pressure on the XY axis motor to position the print head. Just pop it off and position it up and to the left of the bracket.
5. Remove the steel square block on the left bottom side of the frame.
6. Unplug the harness and ribbon cables and then from the back of the printer, remove the print head, be careful not to hit the drum.
Install the print head, the ribbon cables are somewhat difficult to plug back in, Just be patient. and make sure they are conneted firmly. Also when replacing the cables and harness, be sure they are routed corectly so the print head does not get bound on them.
Set the print head into position and install the steel block, then the spring bracket on the XY motor, then the spring brackets in the proper positions. Dont forget to put that spring bracket back on, It is easy to over look.
Make sure all things are plugged in on the print head.
Next reinstall the ink loader, make sure all connectors are connected.
Install the covers and you are done.
Take your time, probably should take about an hour. Just to it carefully and methodically.
Nov 13, 2007 | Xerox Phaser 8400 Laser Printer
Replacing ink cartridges
WHEN YOU OPEN COVER IF THE PRINTER IS ON CARTRIDES WILL USALLY MOVE INTO THE ACCESS POSITION ONCE THIS HAPPENS FOLLOW PITCURE DIAGRAM ON THE UNDERSIDE OF THE COVER OR LOOK AT THE OLD CARTRIGES (already intalled for a release mechanism).INTALLSTALLATION IS OPPOSITE REMOVAL.
Oct 12, 2007 | Dell 924 All-in-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
212 people viewed this question
old marine
old marine
