Question about Malber Washing Machines
Help with malber wd1000 . just replaced lock and the machine won't do I know if the door seal is the problem.I was able to remove the spring.but can't seem to get the grey rubber seal off.
  • 209 Answers
SOURCE: bosch washing machine
i am recently retired appliance engineer of 20 years, the rear door seal clamp is generally nowadays a large thin spring that is slightly hidden by the concrete weights at the front of the drum, if thats the case the door seal will just come off with a good firm pull round the drum edge, fitting as a reverse of removal, place the door seal in the groove so it fits like it should, then stretch the spring and fit that into the outer groove round the lip of the door seal at the drum end, once that is done fit the seal on the front panel lip, then replace that clamp, check all is fitted securely before running machine its one of those jobs that hard to explain how to do it, hope i have helped a bit, its easier to work through the front door opening than from above? if i have please rate me thank you
Posted on Sep 13, 2007
SOURCE: washing machine replacement door seal
It is held on by a spring that stretches around the outside of the seal. The seal simply hooks on to a small lip so all you need to do is start in one spot and push it down and away. Then just work it around like removing a bike tire until it is fully removed. Be careful of the spring. It is hooked together so it may unhook once some of the tension is removed and snap around.
Posted on Nov 17, 2007
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
SOURCE: replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Posted on Apr 06, 2008
  • 135 Answers
SOURCE: Zanussi washing machine door seal removal
This is quite tricky, first take off the retaining ring on the front door port, remove the seal from this rim. The back of the seal is held by a spring band. the best way to remove it is to get a good grip on the seal at the top then lift and pull (thats the easy bit), to put the new one on i always lubricate the recess on the seal with washing-up liquid and feed the seal on from the bottom with one hand whilst following it around with the other hand to stop it coming off. Once it is fully on it can then be rotated easily into the correct position. Getting the spring back on will require an extra pair of hands for obvious reasons.
Good luck with it and keep the swear box handy lol.
Thank you for using fixya
Posted on Nov 26, 2008
Broke the door handle on malber wd 1000? Do they sell the handle or door?
Sorry to see this 16 months too late.
You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Oct 30, 2012 | Malber WD1000 Front Load Washer/Dryer
Malber combo doesn't start
This problem is usually the front door latch "interlock" is not engaging. This is the safety device which keeps you from opening the door and pouring gallons of water on your feet. When you close the door, if the machine DOESN'T recognize it's closed - all electricity is cut off and the machine does nothing. If the machine DOES recognize the door is latched, the latch will lock and you can't open the door (for about 90 secs after you turn it off or unplug it). Does the door LOCK when it's closed? If not, just close it harder several times. A medium "slam" almost always takes care of a "sticky" interlock - and it doesn't hurt anything.
Aug 01, 2012 | Malber WD1000 Front Load Washer/Dryer
I have the Malber WD1000,the wash cycle goes on but no water pumps out, a couple drops come out . How do i fix it?
No water fill
1.water valves closed----turn on valves
2. Hoses kinked---unkink hoses
3. Screen in fill hose clogged----clean out screen
4. No power to fill solenoid---replace solenoid
5. Faulty water level control---replace control
6. Machine did not turn on----check control & power outlet
Water will not drain from machine
1.kinked or clogged hose----clean drain hose
2.pump does not run----readjust & tighten pump-drive mechanism
3.suds lock----remove suds,, add cold water
4.faulty transfer valve---replace
5.defective timer----replace
6.loose belt---adjust belt
Sep 22, 2011 | Malber WD1000 Front Load Washer/Dryer
Hi, How do I open the door on a Malber wd1000 when is it stuck after the cycle is over?
Some machines require it to be empty of water to allow the door to open.Try dropping the drain hose low into a bucket to allow it to open, then clean the filter as it may be blocked causing this problem... Good luck
Feb 10, 2011 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Front door will not lock
The door lock may need to be replaced. It is a simple fix requiring only a screw driver. Contact Malber at 1-800-600-8913 and ask for Neil.
Dec 19, 2007 | Malber WD1000 Front Load Washer/Dryer
Where do i put detergent
Contact Malber USA ( to order a new Manual.
Dec 11, 2007 | Malber WD1000 Front Load Washer/Dryer
Gasket for Cleanout at bottom of Malber WD1000
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. (
Dec 09, 2007 | Malber WD1000 Front Load Washer/Dryer
Washing Machines Logo
29 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
