Question about Mitsubishi VS-50607 50" Rear Projection Television
I have a 2000 Mitsubishi 50607 vs and need to adjust brightness... Remote will get me to video/brightness adjustment. But I cannot adjust brightness with adjust button.
  • 1153 Answers
SOURCE: Mitsubishi VS-50607 Won't Turn On
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Posted on Oct 06, 2007
  • 1694 Answers
SOURCE: mitsubishi ws65909
Yes,but first it is necessary to repair the problem = replace
both STK392-570 IC's.............Then use remote to adjust
convergence............."inside the tv" is called servicer menu = adjust after repair is complete.You can expect to replace IC's
every five years or so.......................T.
PS Try to match your problem thread model # to actual model #
ie. VS-5043 does not match WS-65909........T.
Posted on Nov 29, 2007
  • 1153 Answers
SOURCE: 50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Posted on Mar 17, 2008
  • 927 Answers
SOURCE: vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Posted on Jul 31, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi big screen model VS 60601 convergence adjustment
you need new convergence ICs. If you can respond to this same post and verify the model number of your mitsubishi, I wll post the correct ICs that your model needs.
Posted on Aug 17, 2008
Blue Convergence chip will not adjust
In the Convergence Mode there are three main Functions (Categories). •Pressing "6" activates CONV MISC •Pressing "5" activates COARSE CONV •Pressing "4" activates FINE CONV
I don't know if this will help, sounds like you already know about the convergence tuning.
Jan 06, 2011 | Mitsubishi VS-50607 50" Rear Projection...
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Vs-45607 was a hand me down and did not come with a remote. the picture has very fast rolling vertical lines........Help!
Typically you can open the back case and you will see two screws, one for vertical scroll and one for horizontal scroll. with a rubber head flat head you can adjust this. Please be advised this is very dangerous and has high voltage. Please get a tech to look at this, he must be familiar with this TV.
Sep 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Best settings for moderate to low light viewing?
Using your remote, click the "video" button (mid area, Right hand side) and adjust the brightness, contrast, etc., to your liking. Only you know what you like. If your picture can be "plenty bright enough"...then just make the necessary adjusts to whatever looks best to you. If your picture is "very dim" no matter what the video settings are, you need a complete cleaning of all lens, mirrors, and screen...and possibly a new lamp.
Apr 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No problem==somebody gave me mitsubishi-vs-6043 tv and i need to
When new that unit sold for around $2000 and $3000. But that is an older unit and you'd be lucky to get $500 for it now. It was manufactured in 1996 making it 13 years old.
Dec 28, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mits m#vs-5007r convergence not inline
If you cant adjust it in . you most likely have a resistor on the convergence board that is slightly off. There will be 10 or 12 resistors in a row near the stks measure them and if they are off more then .3ohms replace it good luck.
Thanks doctor video
May 04, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS 50607 Problems
Vertical output IC most likely needs to be re-solderd. However this model is famous for the CRT leaking coolant in the area of the Vertical output IC and corroding the solder. Check for a sticky residule near the Vertical IC indicating a leaky CRT seal.
Apr 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 has Jitter at top of picture- intermitant
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 10.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs
http://servicemanuals.vstore.ca/
Jan 14, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi ws65909
Nov 25, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Open Questions:
See all Mitsubishi VS-50607 50" Rear Projection Television Questions
Mitsubishi VS-50607 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
